18" AMG wheel weights?
Does anyone know the weight of our 18" AMG wheels.
Anyhelp here as I know someone will have that before I go pulling the wheel?
Thanks - BTW - I'm having Chris @ C2D start with my Kleemann Stage 2 next Monday along with a few different ideas to run stronger thru the gears.
I'll fill you in if Chris @ C2 can get it to work.
I went from stock 18s with 245/40 and 275/35 (Pilot sports) to BBS LMs 19" with 245/35 and 275/30 (PS2s).
The weight of each wheel plus tire was:
Stock 18s- 52lbs (front)
57lbs (rear)
BBS LM 19s- 48lbs (front)
50lbs (rear)
I saved a total of about 22lbs in unsprung weight. You can do even better if you want to invest in HRE comp series (See member Vic55). Also, I think Volk makes some very light weight wheels for our cars.
Thanks for the info - On a different note - How do you like your Kleemann stage 2? Was it a big difference or simply a "nice" upgrade?
I'm a big fan of K2. Listed below are a couple of threads you may wish to review. They are about my experience with Kleemann and they may give you a better idea of what to expect from this upgrade.
https://mbworld.org/forums/w211-amg/121764-kleemann-transformation-starts-today.html
https://mbworld.org/forums/w211-amg/123941-kleemann-k2-time-slips-before-after.html
Good Luck.
This is absolutely great reading and has me itching to get my car to C2D NOW!! (instead of next Monday)...THANKS!
Your info and trap speeds @ 123mph has me re-thinking my slight change from normal LSD's that people are doing.................
I'll explain the whole transformation sometime in the next day or 2.
Thanks again - Your attention and detail of the K2 transformation along with explanations at every stage w/Dyno has put me much more at ease!!
