- Mercedes-Benz E-Class AMG: How to Reset Your ECU
Step by step instructions for do-it-yourself repairs
Holy Crap you guys.....sneaky ECU reset WORKS!!!
Any brains out there happen to know of any downside / cons to performing this reset. Will the dealership computers see these resets and cause any probs.?
THX Jakpro1
1. Bi-xenon auto levelling seems working funny or not working at all, one (or both ) of the headlamp light beam seems not pointing far enough.
2. The steering wheel seems not returning to the memorized location after door closed.
Is there any other function that's affected (turned off) by this reset other than the ECU?
Already a reset junkie. LOL.
Ted
Questions for those you have done more than one resets and also had experienced some other features statues were also being reset.
1. Does the same feature got accidentally reset will also get reset again at 2nd time of a reset?
2. Or does any 'new' features got accidentally reset at a 2nd ECU reset?
tks
It seems to work w/ my Maxima... and I don't think my 4th gen maxima is drive by wire....
The VQ engine is drive by wire
P.S. a member wrote this in the CLS 55 forums...under "Eletronic features"
Adaptive trannies are rolling memories ... i.e. if you drove it long enuf on a track it would adapt to that etc...
Resetting just clears the buffer ... and you use the basic program of the tranny. On my car I could not tell any difference really - thought shifts were maybe more harsh than before ... but feels fine now. Dont think I will try it agn.
Eric....
Anyone in la know someone that could do this for me?
*EDIT* Nevermind...California only has cheap azz 91...
*EDIT*
Originally Posted by regor60
That smells of massive b.s.
ditto!
We'll know about hp in a week as I am putting the car with cams (hopefully) up on dyno. I'll do first run as is....then reset ECU and let's see what happens. I assume nothing hp wise, but we'll see.
Thanks for the tip, I appreciate it....
oh yeah as far as the octane setting.... In addition to pulling harder, it's also runs much smoother as well, which is why I don't want to mess with it... If it's a full ECU reset, then it would seem all the settings would be resetted, including the octane setting (which is progammed into the ECU)
Eric...
Eric...
There are 4 options when it comes to changing the octane setting... 87, 89, 93, and auto.. The factory default is Auto, however if you're using fuel at one particular octane rating, there's more precision as far as timing is concerned if you specified to that particular octane setting... I'd just leave the octane setting untouched if only 91 was available...
Eric...
So I am on the dyno using their 1/4 mile feature and the car turns 2 11.2sec runs pretty much back to back. I ask them to hang on one sec and did the famous Sneaky tranny reset, and after a minute or so....WHAMMO, car pulled 11flat. (the feature is just for fun, but that was pretty dramatic) Remember, this is the with car piping hot on the dyno.
The Sneaky ECU reset.....(Twilight Zone Music), the mystery continues.
