Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Mercedes-Benz E-Class AMG: How to Reset Your ECU
Step by step instructions for do-it-yourself repairs
Holy Crap you guys.....sneaky ECU reset WORKS!!!
#204
CLS63
DON'T DO IT IF YOU HAVE A ECU TUNE!!! I have done this twice now in the past year with different tunes and both times it reset my tune back to crap mode. Took over 100 miles or so to get it back to beast mode. It is a fact...
#205
Super Moderator
can anyone with an aftermarket tune confirm???
#207
W211 E55 AMG, ML63 AMG, Past 996GT3,ZCPM3,Brabus C32,ML 500
You just tried this? lol
Yeha it works great especially if your better half has had the car for a bit.
#208
2003 E55 & 2014 GL550
Who knows what it is really doing with a 7 speed. Be careful with that.
#210
E55
I have the VRP/Powerchip tune. I do this once a week or so. I have not noticed any ill effects.... unless you consider shifting at higher rpm, and faster downshifts "ill".
#212
A couple people said that after the reset it leaves their car unstable? Is this supposed to occur? Also, when you wait the 2 minutes you can leave the car right?
Also, 2 minutes or more like 5 o.o?
#214
I am not sure if I had it in the correct 1.) on position. Is the on position ment to be the first click to the right or second click?
I think I tried both options, but both times I had opened the door - could that have any impact?
TY
#215
I notice something weird with the ecu reset....one most notibly shifting from 4th to 5th at WOT. It usually shifts at 135mph, but with the ECU reset, it shifts at 140, but seems to have a fuel cuttoff feeling for about 2 seconds and then shifts.
#216
Thanks for the tip! I just tried this with my G55K and wasn't able to feel any difference.
TY
TY
Don't forget your running shoes in Vegas.
#217
Second click. Just do what I do: Sit in the car, put the key in, go to second click, hold gas pedal down for 7ish seconds, turn key to "zero click" but don't take it out, then just sit there and listen to a CD for 3 minutes or so. Don't open the door.
Thanks a bunch - will try again without opening the door!
#219
#220
Hi,does this work on all AMG cars.
When you say turn the key to first position but not start, do you mean turn the key until all warning signs are lit, such as traction, or do you mean
first click when accessories are active.
Thanks.
Thanks.
#222
02 S500 Sport
"Second click. Just do what I do: Sit in the car, put the key in, go to second click, hold gas pedal down for 7ish seconds, turn key to "zero click" but don't take it out, then just sit there and listen to a CD for 3 minutes or so. Don't open the door. "
Means you put your key in and turn it twice to the 2nd one and not the first one.
