Adding Bluetooth, What do I need to know?
Does anybody know what I would need to do to get bluetooth working (I have a Verizon v710) in the car?
Is there anything in the armrest or elsewhere I should look at to to figure out what might be necessary?
Now if you don't have that, I believe you're looking at a few thousand dollars for the retrofit. I have heard $2300.
So there is no integration with the car at all right? What I like about the integration, not that its VERY important but ..
1) Mutes all other audio when you have incoming call
2) Being able to dial and browse using the Comand screen
3) Recent call list and addr book gets downloaded each time
I have no doubt that an after market unit will do a better job of handeling calls...
Deguero, on your install were they able to integrate the should with Command? Do your phone calls go through the car's speakers or did they install a new speaker just for your phone?
It doesn't integrate into Command, but it looks like this new version (3200) has a fairly large color screen and you can't beat the price vs the MB handsfree install. I had mine installed by Haas Audio in Culver City, CA, they do high end home and auto installs and was referred by the Porsche dealer, very knowledgeable and a nice CLEAN install.
Cyrus
https://mbworld.org/forums/attachmen...1&d=1167952073
It performs flawlessly!
2) Recent call list and addr book gets downloaded each time
3) Voice calling from address book (will not recognize numbers)
4) installed the unit in the ashtray - it is invisible when I close ashtray
I did not have the integration with the command system installed
Hope this helps. Most importantly it is a fraction of the factory dealer installed price and does more!
Ideally I'd like to go the factory route so I:
1. Don't have an appendage attatched to the dash
2. Can see calls coming in (maybe upload my call list) on the command screen.
Factory Benz bluetooth installed. Works flawlessly. Much less than the price quoted.
https://mbworld.org/forums/w211-amg/174831-mbenznl-ipod-bluetooth-install-done.html
https://mbworld.org/forums/attachmen...1&d=1168022267
http://www.parrotkits.com/donotcut.html
http://dz1.homestead.com/ParrotBluetooth.html
