How do you turn off Bluetooth when car is off ???
Old Aug 5, 2007 | 01:41 PM
Kort's Avatar
07' Mercedes E63 AMG, Lexus LS430, BMW 3, Jeep Grand Cherokee Ltd., Chevy PU
Question How do you turn off Bluetooth when car is off ???
I have an issue with the Bluetooth on my E63. It works great, but when I turn off the car and exit the vehicle if my phone rings and I'm within 30' of the car it grabs the signal. So far the only solution is to turn off the Bluetooth feature of the phone every time I get out of the car. Is there a way short of rewiring the power to the Bluetooth adapter to force power off when the car is off ??
-Kort
Old Aug 5, 2007 | 08:58 PM
Benz-O-Rama's Avatar
-Kort
The bluetooth puck in your car should power down about 2 minutes after you shut the car off. We all have the same problem and it's bit annoying. I've had bluetooth in my car for about 4 months now and I can count the number of times I've gotten a call before the bluetooth disconnected on one hand. It's a pain in the **** when it does happen though.
Old Aug 5, 2007 | 09:48 PM
juicee63's Avatar
2011 twin turboed prius
-Kort
Turn off your phone when you get out of the car. Press TEL button and turn it off
Old Aug 5, 2007 | 11:34 PM
rkao's Avatar
'12 ML350
Am having the same issue and with my home office immediately next to the garage, every time I opened the car door or trunk, the bluetooth connection would be activated!
According to the instructions that came with the bluetooth module, holding down the "TEL" button for 2-3 secs. will disable the connection so will try that next time before I stop the engine.
Old Aug 6, 2007 | 10:57 AM
Kort's Avatar
Thumbs up
Sounds like the puck must have a capacitor that has to drain before it completely shuts down. Thanks for the feedback I'll try the Tell Off solution.
Old Aug 6, 2007 | 04:51 PM
rkao's Avatar
'12 ML350
BTW, slightly off topic, but has anyone else noticed that the BT module looks a bit like the front end of a McLaren Mercedes F1 car?
Old Aug 7, 2007 | 02:57 AM
juicee63's Avatar
OMG , yep sik man just sik..
Only a mb would have a puck designed after thier race car
Old Aug 9, 2007 | 10:22 PM
kermalou's Avatar
2008 E350
this is pissing me off too.
Old Nov 3, 2008 | 09:23 PM
Zoom On's Avatar
'02 CLK55
OK so my wife has been nagging me about this same issue. If she gets out of the car, and a call comes in, the car picks up. This happens even minutes and hours after she exits the car. What your saying is that it should sleep after 2 minutes? What if it does not is there a setting or a reset?
Old Nov 3, 2008 | 09:26 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
or with iPhone, u have option to change source between iPhone and MB BT...
Old Nov 3, 2008 | 09:34 PM
NMT's Avatar
NMT
E55
MJ50 How did you get your 04 55 bluetooth ready? The dealer told me my 04 is not bluetooth capable?
Old Nov 3, 2008 | 09:37 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
dealer say million things that cannot be done...
i got BT puck with tail which will work with 03 and 04 models...
full BT integration for under 300 bux...
can't beat that!
check with benzworld.org.... there's a nice thread about it on 211 amg section...
Old Nov 3, 2008 | 09:39 PM
NMT's Avatar
NMT
E55
Does it work with your factory nav system? Im not a member on benzworld...Where do i get it done??? sorry thanks!
Old Nov 3, 2008 | 09:42 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
yes, i have US COMAND and works well...
after install (DIY), u need version coding in order to work...
Old Nov 3, 2008 | 09:45 PM
NMT's Avatar
NMT
E55
you are speaking french to me but ill do my best...should i just go to the dealer and say i need the "bluetooth with puck" installed NOW! or im buying a prius??? and slam my fist on the desK???
Old Nov 3, 2008 | 10:02 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
1) buy the BT puck w/ tail from the dealer. part # is B67875855
2) DIY install following the instructions at http://www.youtube.com/watch?v=ny352CxKbDQ
3) go to dealer and have them verion code it & voila!
Old Nov 4, 2008 | 02:23 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Here is more Info.
https://mbworld.org/forums/w211-amg/234094-2004-e55-i-phone-works-bluetooth.html
