renntech lowering module install
Old Aug 20, 2007 | 10:30 PM
rbtronnie5's Avatar
You name it i've had it or got it...
why are there 2 sets of instructions for the renntech lowering module on their site? which do i use on a cls55?
tia
ron
Old Aug 20, 2007 | 10:33 PM
Vic55's Avatar
Administrator
tia
ron
I think the unit is compatible with both Airmatic and ABC systems. Use the W211/W219 Airmatic instructions.
Old Aug 20, 2007 | 10:38 PM
rbtronnie5's Avatar
it's weird...one shows that more wires need to be spliced...like 2 for each wheel where the other is 1 per wheel. blah...i'll go with the airmatic as you suggest...what would happen if i use the abc one?
Old Aug 20, 2007 | 10:40 PM
Vic55's Avatar
Administrator
I installed mine on my 65 and used the ABC instructions but we all know that the 211 55's and CLS's dont have ABC so you should be fine unless Renntech has errors on their site directions?
Old Aug 20, 2007 | 10:46 PM
rbtronnie5's Avatar
yeah...man vic this is crazy..some of the lines are color coding right....a few are missing compared the instructions.
Old Aug 20, 2007 | 10:49 PM
Vic55's Avatar
Administrator
I would make sure cause you dont want to cut the wrong wires. Call Renntech tomorrow just in case.
Old Aug 20, 2007 | 10:51 PM
rbtronnie5's Avatar
agreed..was trying to size up the task...now it is obvious, i need to call them
Old Aug 20, 2007 | 11:53 PM
SUNILP's Avatar
2015 E250D
the wiring was changed midway on the w211 and w219 chassis cars. They went to less wires per sensor and so you have to wire the module in differently.
Old Aug 21, 2007 | 12:00 AM
Sunny55's Avatar
2005 SL55 AMG
lowering links are much easier....
Old Aug 21, 2007 | 12:27 AM
rbtronnie5's Avatar
so go with the simpler instructions that are under the abc instructions? if that is the case then it might work...because then i am not missing any wires. this shouldn't be this confusing. blah...i will square it away with renntech tomorrow i guess.
Old Aug 21, 2007 | 08:53 PM
Vadim @ FD's Avatar
S600TT, R350
I am doing CLS55 with RennTech ELM right now.
Call me if you still have questions.
