Aborted Dyno due to Lean Condition
#76
Out Of Control!
If money/price is NOT a factor, how would you rank the following tuners in rebuilding and radically upgrading the motor itself?
1) Brabus
2) Kleemann
3) Renntech
4) Evosport
5) VRP
6) Mechtech Motorsports
7) MKB
8) ??? Your other choice.
If money/price is a factor how would the ranking change?
I definitely want equal or better quality parts than OEM AMG, possibly more displacement, lower compression but extremely high output, EFFECTIVE yet SAFE TUNING and service reliability backed by a warranty. I also don't want games being played with bait and switch tactics (i.e. found more damage after engine removal, etc..). A bore scope and other methods to determine the extent of the damage such as scorched nikasil cylinder walls needing new a block should not be discovered later. Finally I don't want to wait 3 months or longer to get the entire job done.
One thing about Brabus is that they are local and the most well-known for engine upgrades/rebuilds but the quality and reliability may justify the prices.
1) Brabus
2) Kleemann
3) Renntech
4) Evosport
5) VRP
7) MKB
My suggestion. Wait for the new SL65 BS and try not to mod the engine. Should help satisfy your craving. Just my 2 cents.
#77
V12-Biturbo
After reading all of your numerous threads, replies and projects, i don't think there's any tuner out there that will satisfy your hunger for power. Doing heavy modding there'll always be an issue somewhere.
#78
1 Post
2006 Weistec 3.0L SC'd C55, 2006 MaxPsi PT6466 Turbo'd M3, 2019 Maserati GTS , 2020Alfa Quadrifoglio
I wasn't even considering RennTech/Kleeman/Carlsson. Honestly, i already said i wouldn't do it. It isn't worth the money. Buy a new C63 and move on. Now, why wouldn't i go with them? Because they haven't even shown good tuning on the OEM cars, much less a build up. I never liked how Kleeman handles their high end clients and all the issues are too much. Just too many CELs. RennTech has lost their focus and is simply concerned with MB dealership sales. Carlsson makes wheels. Heck, their ELM is still analogue. Keep laughing bro. The Shine has worn off of that penny. They want back in, they gotta win over the enthusiasts and not just the spenders.
Heck a Brabus 7.0 C55 with a Kleemann won't hurt the prestige/exclusivity factor either. I won't need to worry about the C63s that's for sure.
#79
05 ML-500 , 03 CLK5.5 AMG has left the Garage
My Two Cents
All This speculation and no tear down Yet ! It seems you are thinking it may be worse that it really is. Of the 3,engines I've rebuild in the last 2 years , 2 of the engines , each 1 needed a sleeve & 8 pistons, ( Nitrous gone Wild) !!! 1 needed to have the a 1/2thousand honed out with the special paste & Diamond hone stones, 4 new pistons assys with rings, Pins & Clips & 4 rings set for the passenger side pistons. My Guess is that you , had a little transfer of the alum piston to the cylinder bore. The piston is the weak link , It doesn't take much to knock the Iron plating off the skirt, Which then gets to the rings & screws up the sealing edge at the sleeve . You can safety remove .010 ths to clean up the sleeve .( Its tough Alusil) 70% special Alum alloy & 30% Silicone chrystals. .010ths / 1/4 mm over sized pistons are available for MB There not Cheap ($800.00) a piece . And it's a Hi Silicne content (13%) cast piston. You may also want to look at 2000 - 2002 E-55 N/A 10 to 1 c/r pistons. Work with VRP & Vadim. This may be way less expensive than you think , and provide other Opportunities for H/P enhansements
#80
2) Kleemann
3) Renntech
4) Evosport
5) VRP
7) MKB
#81
S600TT, R350
Before ring snaps and scratches the wall, my offer was to simply build a set of 9.5:1 forged pictons, tear motor apart, check for damage and put it back together with new bearings and rings. Nothing fancy, just a standard rebuild.
Than we can run higher boost on CA 91 gas and not worry about the being on the edge.
#82
This is the best soluion no question... at some point the cylinder wall is going get gouged ... THAT will be expensive.
#83
Why doesn't anybody get custom pistons/rods (i.e. JE/Carillo) to lower compression? They are stronger than using stock AMG components and maybe even cheaper! I think PTE used some badass custom pistons in his beast! Thats what I'm gonna do if I ever decide to run crazy boost or blow my motor.
AMGSC- if you are going to run high boost you will need to look into a 8 rib pulley system much like Ted Baldwin uses on his E
#84
1 Post
#85
1 Post
Thanks! I asked Cory about Ted's 8-rib setup and he was OK with it but he advised of another alternative which is to get more belt wrap by moving the tensioner pulley to the left.
#86
1 Post
Brabus pricing info!
Brabus engine replacment with 7.0 motor is $40K per Brabus Rep. Should I pull the trigger? I can still sell my motor for something to offset some of the costs. Worth it vs. buying a C63?
#87
AMGSC...Pat knows his stuff...I had one of those engines he rebuilt. My cost was so much less than getting a whole new engine or used AMG short block. A tear down would definitely be a route to consider to determine the true extent of your damage.
Good luck.
#89
1 Post
A Brabus 7.0 C55 with a blower would blow the doors off a C63 and just about any other car on the road. Besides, I'm looking for unique, not one of the masses...Thanks for your input anyway.
#90
V12-Biturbo
Good luck w/it man I know you've been thru a lot...
#91
S600TT, R350
The way the car is right now, even with hurt motor, with 438RWHP and 450RWHTQ, it will walk any stock C63.
#92
'10 Porsche Turbo PDK, 500e, GL450
someone in england
Has I believe a built brabus motor and has it supercharged on top of it. (this is in a SLK55)
Best 1/4mil run was in High 10s!!! Of course he had a lot of mods that also lightened the car.
Last I heard though was he was pulling it all out and planned to get another frame to put it in. (torque twisted his frame)
#93
2006 E55
since money isnt an object, and you're attached to your car, why not drop an SLR motor into it or something?? they did it to an SLK, Im sure it can be done in a C.
#94
1 Post
Cory said mine was a 2.6 litre twin-screw (Autorotor) and not the 2.0 litre roots (Eaton) that they currently sell.
If only you can increase the displacment to at least a 6.1 which Brabus also does, then my chips would be all in.
Otherwise, I'm thinkiing of a straight swap to a brand new Brabus 6.2 for $35K or a 7.0 for $40K.
I can probably sell my engine for $5K now instead of finding more extensive damage upon tear-down and paying perhaps $25K or more to rebuild it. A) $40K less $5K recovery nets $35K for a brand new 7.0 Brabus vs. B) $25K for a repaired/uncertain stock engine with slightly lower compression. Somehow I'm struggling to find the appeal of the repair option vs. the more appealing replace option even at a $10K higher net investment.
#95
1 Post
Brabus Appointment tommorrow
Going to see Andreas at Brabus USA tomorrow. Gonna just go for it! **** this 55 motor!
#97
S600TT, R350
Vadim,
I can build you 6.1L for a lot less.
But my recommendation is to keep 5.5L, and if budget is no longer a problem, keep the blower and add turbos. They will still come out cheaper than 7.0L.
#99
1 Post
Maybe. 2.6L did not come until a couple of years ago. Your kit is older than that.
A repaired 5.5L (same block) will not be able to withstand the power and torque of a turbo/sc combo. Plus the fact that this combo has never been successfully done with reliability that I know of...A Brabus 7.0 is a completely different block and is basically a converted 65 motor.
#100
S600TT, R350
According to Cory, they stopped making the twin-screw in 2005 and since then have only sold the roots versions. He knows my blower from the previous owner BillyBenz so it's a confirmed 2.6 litre. You still have my car so please check it physically yourself and let me know please. It will make a difference in my decision to keep it or sell it.
2.6L is a lot longer than standard 2.0L Kleemann. I have had it on and off many times. It is the same as older units.
