Where to get center console piece?
04 E55, 03 GSX-R600
My three old got a little excited and ripped off my center console tab that is triangle shaped then splits down the middle and makes up the arm rest. It has a sticker with "8371651" on it. Dealer say nearly $200 for both tabs that make the set. I figured it wouldn't hurt to look for an online source but no luck so far. Any pointers would be appreciated.
k
2004 E55
k
2004 E55
k
2004 E55
k
2004 E55
The only place to get those is the dealer and the replacements will not match the existing wood perfectly.
Take the advice above and use 3M double sided tape. The thinner gray exterior stuff works very well.
2004 E55
^yep.
Same happened to mine and super-glued the broken tab after the dealer told me replacements would cost nearly $300 (you can't buy just one part, they come as a set).
the dealer and super-glue!
