New '03 E55 Owner!
Old Feb 28, 2009 | 09:58 PM
bbearden's Avatar
'03 E55 (My Daily), '01 ML 320 (Wifey), Twin Turbo '69 Camaro (In Progess)
New '03 E55 Owner!
My insurance company gave me a very reasonable settlement after my CLK was totalled and I picked up an E55 in Phoenix today--love the car and it's a night and day difference over what I had! Few questions:
1)For those DIYers, is the preventative maintenance fairly easy with this car? I noticed it didn't have a dipstick and the red cap fooled me! I also noticed that it has a "C Service" as well. When I had the CLK430, I did all my own maintenance.
2) Does the supercharger run all the time? The engine has the whine at stop lights like the blower is running but I thought it only activated when a considerable throttle input was applied.
Thanks for your help with my dumb questions above and I am excited to learn more about this car and assist others in this forum!
Old Feb 28, 2009 | 11:13 PM
c32used's Avatar
LET C32 2002
Welcome
Old Mar 1, 2009 | 07:50 PM
FlatlineEF9's Avatar
1996 E320, 2018 Ducati Panigale V4S, 2012 1199 Panigale
the car doesnt have a dipstick, but the oil is measured electronically though your display and steering wheel buttons. the service intervals can also be reset if you do your own work. just do a search on this and youll see how to do it. there is also a fantastic DIY section above for belts and pulleys etc. Enjoy the beast, welcome to the family.
Old Mar 1, 2009 | 11:23 PM
str8ridin's Avatar
05 E55
Welcome to the W211 forums now.
My service C light just came on. From what I found, it is just a routine inspection of belts/fluids and change any that are needed. Something you can do yourself.
As for the whine at the stop light, you shouldn't hear it. In fact, I barely hear mine at WOT. Hopefully, someone else can jump in on that.
Old Mar 1, 2009 | 11:26 PM
bobgodd's Avatar
2004 E55
Is it the same whine heard at start-up? If so that isn't supercharger whine, it sounds more like a secondary air injection pump, or a power steering pump warming up. If this is the sound you're hearing, it should go away after the car warms up though.
Old Mar 2, 2009 | 01:07 AM
bbearden's Avatar
Whine
Thanks, the whine does seem to go away after the engine warms up. If I watch the clutch assembly of the supercharger, shouldn't part of it be stationary and not running when the engine is at idle? I want to ensure that the clutch didn't freeze up on me.
Old Mar 2, 2009 | 01:13 AM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
you can test the clutch. put the car in 1st gear and accelerate very slowly to prevent early s/c clutch engagement. as the rpms get to around 3500 you should feel a sudden jerk as the s/c clutch locks up. i've not heard of a frozen s/c clutch but if you don't feel that jerk, it's possible.
Old Mar 2, 2009 | 02:43 AM
bbearden's Avatar
Thanks, will give this a try to see if it engages at this rpm in 1st. Do you know if the supercharger has its own gear oil or does it use engine oil for lubrication. I thought Lysholms, like most Roots type blowers, had their own gear oil in the front and rear cases, but I could be wrong. I didn't know if it required an oil change after a specified interval.
Old Mar 2, 2009 | 02:54 AM
E55Pilot's Avatar
2004 E55
It has it's own lifetime oil supply
Old Mar 2, 2009 | 12:39 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
welcome aboard...
Old Mar 2, 2009 | 04:52 PM
AZIPOD's Avatar
W211,E90,E66,E39,E38,NSX,Z32-TT
You'll still see the assembly rotate when its at idle, that's just the way it is. As you accelerate from light crusiing, you will feel a slight jerk when the SC clutch engage.
Old Mar 2, 2009 | 09:18 PM
bbearden's Avatar
Thanks guys! This thing is a rocket! Am building up a twin turbo 69 Camaro right now, so my modding budget will go to it, but to have this as a daily driver is the best of both worlds.
Old Mar 2, 2009 | 10:28 PM
OXOJE55's Avatar
///AMG
Welcome and Congrats
Old Mar 5, 2009 | 12:00 AM
dlav06's Avatar
Dodge Challenger Hellcat Widebody, Porsche Cayenne, International Scout
Welcome to the neighborhood!
