Intercooler Delta Temp/ Heat Transfer and Effeciency?
Old Apr 19, 2009 | 10:39 AM
TexasSteele's Avatar
2005 e55AMG
So the more I think about an icebox in the trunk, and a split cooling system, the more I get back into physics.
Cooling is the act of drawing out and absorbing heat. Heat is energy.
On a 90* degree day, if the Supercharger discharge temp @ 14psi is 240 degrees (complete guess PV=nRT) and water passing through the intercooler is 30*, depending on the flow and efficiency of the intercooler core it is highly unlikely that the water returning to the heat exchanger or ice box will be over (or close to) 90 degrees.
If that is the case, then running the coolant/water through the heat exchanger at 90* is further heating the fluid before returning to the ice tank.
I understand the need for the heat exchanger for day to day use, but actually think it's hurting the "ice" effect with a trunk reservoir.
Also, with my nitrous setup, injecting air at a -200* will definitely aid in cooling, although it won't create more oxygen (short of what is being injected)...
Open to thoughts, and would love to see datalogs of ambient inlet and outlet air temp, as well as inlet and outlet intercooler and/or heat exchanger temps...
I did a quick search and there is no doubt chiro's kit worked-just wondering if I should bypass the H/E on the ice circuit. A couple of T fittings with ball valves and it can be set to kill or to cruise.
Old Apr 19, 2009 | 01:48 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
yes, i do believe the h/e will actually heat up the water when running with ice in the reservoir. however, since the ice lasts for such a short time (one run at most) it wasn't worth it to me to create a bypass in the system.
Old Apr 19, 2009 | 02:20 PM
2005 e55AMG
I was hoping someone had water temp logged before and after the intercooler...any idea how efficient the stock IC is?
And thank you for all your help and info...VERY much appreciated!
Old Apr 19, 2009 | 02:27 PM
chiromikey's Avatar
i don't know if anyone as water temp data......but you probably shouldn't use the word efficient and stock i/c in the same sentence.
Old Apr 19, 2009 | 09:49 PM
jangy's Avatar
2015 S212
I think the bottle neck is more getting the heat out of the IC and into the cycle.
Great topic! This is the next area where we will find consistent power, IMO
Old Apr 19, 2009 | 10:16 PM
Vadim @ FD's Avatar
S600TT, R350
Stock core is around 60% efficiency.
I will have an answer to improve that, tomorrow
Old Apr 19, 2009 | 10:32 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Vadim, are you still working towards the fedordesynSLRsupercoolertwinturboE55?
Old Apr 19, 2009 | 11:38 PM
Vadim @ FD's Avatar
S600TT, R350
Old Apr 19, 2009 | 11:49 PM
2005 e55AMG
I wanted to triple check for air in my intercooler circuit since installing the code 3 H/E and 180* PTE, CM30, etc..etc. The water DEFINITELY wasn't very hot...and it got me thinking about the basics.
A few years ago (8?-10?) I used this on a supercharged fox body and was able to get sub ambient temps, even without ice in the box. I know I was skeptic with the size of the cores-both H/E and I/C...but how about finding a more efficient intercooler core that will fit within the current housing? It's no SLR cooler, but could be MUCH more affordable and almost as effective...
Surely the cm30 and code3/spearco/any aftermarket heat exchanger will transfer better than stock OR that little piece Vortech shipped out.
Old Apr 20, 2009 | 01:22 AM
jangy's Avatar
2015 S212
awesome point! I'm dying to help the IC dissipate heat and to grow the outlets on the intake manifolds...
Old Apr 20, 2009 | 01:23 AM
jangy's Avatar
2015 S212
First.
