Oil change on an E63?
I have always done my own oil changes. I usually use Amsoil or Royal Purple. I will probably go with RP since its readily available.
So, questions are:
-How many qts? (my old E55 used 8qts, does this use 8 as well?)
-What grade oil? (i used 10w40 on my E55)
I assume the filter is the top mounted version in which i can just unscrew, swapfilters and o-rings.
Any other tips on doing the change? like should one side of the car be higher then the other due to location of drain bolt?
Thanks guys!
Aj
Nick
Nick
can anyone tell me what size the copper crush washer is? or do they just use generic sizes that i can find at any parts store?
thanks guys!
P.S i did a search and nothing comes up specific for an E63. lots on the E55.
1. Get 10 qts of 0W-40 Mobil1 European Formula or 10 qts of 5W-40 Mobil1 ESP Formula M. The first you can get at Walmart, the second you need to get from an online vendor. According to Mobil
2. Buy oil filter and drain plug washer from your dealer.
3. Get a big oil pan. 10qts is a lot.
4. Remove the rear plastic engine shield (under the car), the front one does not need to be removed.
5. Remove the front enginer cover (the one on top with the MB emblem) by carefully pulling up. Every time I remove mine I always feel like I will break it.
5. I would remove the oil filter first as it has a system designed to drain the dirty oil into the pan. Found this on the filter manufacturers web site.
6. Give it time to drain - while waiting, put in the new oil filter.
7. Put the plug back in with the new washer, re-attach the engine shield (make sure to tighten the screws, a couple of us had them back out and we ended up with plastic scraping the ground). You may find loosening the front shield makes putting the back one on easier.
8. Fill with 9qts, start up the engine to fill the oil filter, re-check the oil level and top off to get within spec on the dip stick.
9. Put the engine cover back on.
Did I forget anything?
5W-40 web search gave me
http://mooreballiewoil.thomasnet.com...ic-?&forward=1
Cheaper is
http://avlube.com/mo1espfom5wc.html
i just got lazy and didn't want to get under the car and do it myself. So, it cost me about 90 in parts (filter was $20 from dealer (DAMN!) and oil was $70 from parts store) quick lube place charged me $15. all said and done, lot cheaper then going to the dealer. what do they charge, like 200???
Aj
Do a search on the PL, I think there is a statement regarding draining rather than extracting.
Found it
Thank you very much for your post.
The drain plug at the front of your E 63 AMG engine is not convenient for draining the oil. Following the service instructions on the E 63 AMG, only the drain plug in the oil pan at the back of the engine is appropriate for draining the oil. Extracting through the dip stick is not possible either. A nearly complete emptying is guaranteed while your engine is at operating state temperature. A possible remaining quantity in the front area is negligible.
We hope this information finds you helpful.
Best regards,
AMG Private Lounge Team
The second time I put 7.5 quarts and the oil is right at the max sign. How 7.5 quarts could bring the reading to the max? Even if the oil cooler had 1 quarts, that would make it 8.5, not 9.5 as many folks state here.
Is the dipstick lying?
Also I don't want a quart of dirty oil mixing in with my new clean oil. I know it will happen with all the residual oil left inside the crevices on the engine. But to a lesser extent.
Both of these, and only these, will maintain your warrantee. The 5W-40 is the more recent recommendation, but the other has not been removed.
Cheaper is
If you drain all oil from oil pan, oil cooler, and extract oil from oil filter housing and through dip stick (for whatever is left over in the pan), car should be pretty much dry.
Then putting in 9.5 liter (not qts, liter) should get you right at the upper mark of dip stick.
I just did mine with 5W40 Motul 8100 Xceed.
I had Mobil 0W40 Euro before and it was okay.
But with Motul, I could tell the difference right away.
Perhaps different grade oil (0w vs 5w) caused the difference, but the car feels smoother all around and quieter as well.
Will be doing 3rd oil change soon and want to drain all the oil including the oil cooler this time. I cannot find a diy post showing the location of the oil cooler drain. Can someone either explain where the cooler drain is or link me to a good diy post please?
Also bought motul 5-40 this time instead of mobil 0-40 as a) it is warm outside now b) mobil is too watery to me.
The oil cooler drain plug is located basically right under the radiator, and the drain plug is located on the right side, look for the oil cooler lines. But you have to remove the from engine belly pan to access it.
Hope that helps.
It holds about a half quart of oil, remove your oil filter cap, and the cap for the engine oil, this will allow air in and help the oil drain better.
I then put 8.5 liters of Motul and I am above the max mark according to the stupid updated dipstick. I think it is not accurate as I can’t put more than 8.5 regardless I drain the oil cooler or just the pan. I wish I kept the factory dipstick
Hi, just wanted to thank you for the info on the cooler drain plug. Was able to find it easily. It looks like nobody ever touched that as I broke the seal around the bolt.
If you can only put in 8.5 quarts, your car will eventually tell you to add another quart. I would check with your local Mercedes dealer to see if you have the correct dipstick. Your cars hold more than 9.2 quarts....trust me.
Aluminum Washer - 12 X 18 X 1.5 mm,
Brand: Fischer & Plath
Part #: 12X18X15AL-M131$0.25
20
$5.00
Oil Filter,
Brand: Hengst
Part #: 000-180-30-09-HE-INT$9.75
5
$48.7
Engine Oil Flush - Liqui Moly Engine Flush,
Brand: Liqui Moly
Part #: 2037-M19$12.75
2
$25.50
CERA TEC 300ml
Part #: LQM-20002$20.95
2
$41.90
