Looking for evidence why this intake is not better than stock
Old Jun 29, 2009 | 12:14 AM
Juice1979's Avatar
E550
I put this intake together from some pieces I had laying around and what to get some info from those who have dyno/track tested or even runs a similar setup. I know many are concerned this intake will take in hotter air from the engine bay but once the car is moving I think the iat's will be close to stock as there will be plenty of air coming thru the grill area. I also know that this intake will definitely dyno higher than stock as most dyno their cars with the hood open.
I have alot of experiences with american v8's both N/A and FI as im sure others on here do. In almost all cases intake setups like these outperform stock setups on both the dyno and track. Im curious as to why it would be different on this car?
I have been driving around with it on my car for a couple of days and cannot notice a performance difference from stock. Could just be that the butt dyno isnt calibrated sensitively enough. With as much power as these cars make a gain of 10whp would be hard pressed to feel. The only noticable difference is the much more pronounced supercharger whine.
Any input from tuners would be much appreciated as well..Thanks
...yes the stock filters are removed...
Old Jun 29, 2009 | 01:29 AM
AZIPOD's Avatar
W211,E90,E66,E39,E38,NSX,Z32-TT
With 500+ HP, any gains from air filters you will need be able to tell or accurate tell with a butt dyno. I think the only real way is to do a pre/post test-run on a dyno.
How does it sound? Is there a deep sound when the engine is under load? If there's a down side to this I would have to say its the heat underneath the hood.
Old Jun 29, 2009 | 02:07 AM
jturkel's Avatar
02 C32 AMG
i dont think you will see larger numbers on the dyno. it seems more of a ram style intake or cold air intake. if you could some how do a dyno when you were actually moving, and compare before and after install, you might see something. i dont think a fan or two can replicate the volume of air that can fly into the engine bay at high speeds so you might not be able to see results you like on a dyno.
Old Jun 29, 2009 | 02:57 AM
acb's Avatar
acb
2005 e55 amg
I could look at your sig all day jurkel
Old Jun 29, 2009 | 03:39 AM
jturkel's Avatar
02 C32 AMG
lol.... i do. thats probably why i never got off mbworld. i'm on here all frickin day haha.
Old Jun 29, 2009 | 03:53 AM
acb's Avatar
acb
2005 e55 amg
it would be one disadvatange of flat-badging your car - licking that just wouldnt have the same effect
Old Jun 29, 2009 | 05:50 AM
Wryfox's Avatar
2004 E55 AMG
Here's why no gains. You've traded a flat filter for round but basically same filter area. no net advantage. You've traded colder front grille air for hot engine air, particularly air that has already passed your radiators, let alone radiant heat from engine. The air slipping in through various openings in front of car won't make up for that.The only thing you have really done is shorten the air path by maybe 8 inches in an intake path that is something like 6 ft long before it gets to the cylinder. BUT, it does look cooler!
Old Jun 29, 2009 | 09:30 AM
Juice1979's Avatar
E550
I understand why everyone thinks this may or may not be benficial, but i was hoping there would have been someone on here with real data to share...hopefully some of the tuners can chime in here
Old Jun 29, 2009 | 09:40 AM
iconoclast's Avatar
Audi BMW Ferrari MB & RR
what data specifically are you looking for? noone is going to dyno before/after open element filter install... but more importantly the amount of hot air you would be sucking in with those filters is unreal. theres a reason why so many well paid engineers designed what they did.
Old Jun 29, 2009 | 10:06 AM
Juice1979's Avatar
E550
Do you really think that on a vehicle in motion the iat's are that much higher with my current filter location (6 inch difference) than with the stock setup. I am pretty sure that once the vehicle is moving that the air passing thru the front grill etc will be the same temp as stock. I know there was a thread recently posted by "sneakyneon" (i beleive) where he tested IAT temps with various different setups. If i remember correctly IAT's seemed unaffected with stock intake scoops removed.
Old Jun 29, 2009 | 10:47 AM
itsmeek's Avatar
Nissan GT-R cobb/midpipe/ic piping/wastegate actuators/tials
Because you're taking hot air from the engine bay rather then cold air from outside.
Old Jun 29, 2009 | 11:38 AM
TopEndS62's Avatar
2005 BLK/BLK E-Double Nickel.
also that chrome piping will raise air temperature....
Old Jun 29, 2009 | 11:49 AM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
any reason why you can't dyno and simply report your own findings?
Old Jun 29, 2009 | 12:31 PM
blackbenzz's Avatar
haters crazy
Taking it to the track and swapping setups between runs would be your best indicator of whether it works well or not
Old Jun 29, 2009 | 12:35 PM
lowprofile's Avatar
E55
^ I agree. Track results are the way to go if you want real world answers.
Old Jun 29, 2009 | 12:45 PM
Hammer Down's Avatar
2015 E63S, 2018 E63S
https://mbworld.org/forums/w211-amg/...g-results.html
Is this what you are looking for?
Old Jun 29, 2009 | 12:53 PM
bassn_07's Avatar
2006 E55 AMG
I also agree. If you dyno your car with this setup could you please do both with the hood open and shut. With this type of system you would definitely benefit from the hood being open but you wouldn't see these same type of condition during normal driving. The intake would have endless amounts of ambient temperature air with no engine heat. Just a thought for testing.
Old Jun 29, 2009 | 01:09 PM
chiromikey's Avatar
you know I totally agree but my point is why go through the labor of doing the mod then get lazy and ask others for info regarding it's benefits...finish the project properly by obtaining and sharing your own objective data!
Old Jun 29, 2009 | 01:29 PM
Juice1979's Avatar
E550
Of course I could but I was hoping that someone would have already tried this and had some results they could share
Old Jun 29, 2009 | 01:55 PM
Autoscope's Avatar
Former Vendor of MBWorld
E350 Sport & Rs6
Someone said it....
Colder CFM is better than MORE CFM........
Especially on the SC cars....
Does it heat soak real fast? I bet it growls more....
Old Jun 29, 2009 | 02:00 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Doctor says you have K&Nitis.
https://mbworld.org/forums/w211-amg/...ntake-55s.html
And a little more refined effort here,
https://mbworld.org/forums/w211-amg/...-benefits.html
Old Jun 29, 2009 | 02:50 PM
Juice1979's Avatar
E550
Originally Posted by Adam@Autoscope
Someone said it....
I plan on taking it to the track and swapping to the stock setup for sameday comparisons.
No noticeable heat soak, however, I dont drive that much and the few days that it has been installed have not been terribly hot.
Definitely growls alot more than stock!
Old Jun 29, 2009 | 05:30 PM
Thericker's Avatar
V12-Biturbo
Try this, my post from Mushroom Filter thread...
I totally agreed w/both you guys, I always thought these types of kits were crap, but done my way works, I tested it back to back same day vs same car on 12 tot dif runs/races pre-post mod = multi car length gains...
MAIN differences in my choices are, ditch the equiped metal pipes (they're just heat sinks) w/supplied silcone couplers (Ebay kit) you can use existing plastic tubes, the supplied Foam Cones are better than K&N or other Cone type variants because they're wrapped in folded metal/weave/mesh which = more Heat Sinks.
Lastly you have to DREMEL OUT the plastic walls inside the factory airboxes, there are multi-90 deg bends/plastic wall-restrictions routing air-flow due to OEM filter placement, once removed it's straight thru ram air...
I have 1 more idea that may improve it even more (I'm testing it this wknd) that basically encapsulates the new Foam Cones w/bigger 5"-6" diam flexi-plastic tube routed directly to factory holes then C-clamped in place so NO hot engine air mixing...
Link to kit I used, http://cgi.ebay.com/ebaymotors/Merce...Q5fAccessories NOTE: toss out the metal pipes! these filters flow so much more cold air vs K&N, just holding them in your hand shoot compressed air thru each type w/other hand feeling air exiting other side of filters dif is HUGE! Also after driving for few minutes the K&N metal weave type heat-up like crazy vs Foam Only Cones after driving 2 hrs in traffic they're cool to touch, lastly I wanted to see if my new set-up was letting fine dust inside airboxes? after 3 wks use I opened up both sides they were sparkling clean, vs stock OEM set-up there would be heavy sand/little rocks on the bottom of boxes under OEM filters.
These Foam Cone filters STOP any of those foreign contaminants from ever entering airboxes. I checked my stock OEM set-up regularly, the rock/sand build up would be their in few wks, just imagine how clogged up & further air restricted this makes OEM set-up?
Old Jun 29, 2009 | 06:06 PM
chiromikey's Avatar
Originally Posted by Thericker
I wanted to see if my new set-up was letting fine dust inside airboxes? after 3 wks use I opened up both sides they were sparkling clean, vs stock OEM set-up there would be heavy sand/little rocks on the bottom of boxes under OEM filters....These Foam Cone filters STOP any of those foreign contaminants from ever entering airboxes. I checked my stock OEM set-up regularly, the rock/sand build up would be their in few wks, just imagine how clogged up & further air restricted this makes OEM set-up?
think about what you're saying. the reason you used to find that debris in the bottom of your airbox is because the filters were doing their job!!!!! do you really think that new filer is that good or is it likely that now instead of staying trapped in the airbox the dust and debris is going straight into the motor?
Old Jun 29, 2009 | 06:34 PM
blackbenzz's Avatar
haters crazy
Word, I know.
