Couldn't get a good launch at all last!!! Traction off vs. traction on??
Old Aug 26, 2009 | 12:15 PM
TopEndS62's Avatar
2005 BLK/BLK E-Double Nickel.
Couldn't get a good launch at all last Night!!! Traction off vs. traction on??
I'm new to the whole automatic launching thing, and couldn't get a good launch at all last night.... All runs were with EPS off, car lowered position, sport2 suspension, and transmission in sport..
1st run:
staged at 1500rpm
spinned too much tires, the rear even came loose a bit on me
realized that I slammed to the gas too quick....
2nd run
staged lower at around 1300rpm
still spinning more than i should of
3rd run
Staged a little more than 1100rpm
came out the hole pretty good, but by the time i was ready to fully depress the accelerator, car bogged for a split second causind a slight delay...
I read the sticky on How to drag race.... IMO i figured launching with T/C off is the best way, but it seems as though im still doing something wrong... I would like to hear a recipe or two on launching.... Plus Traction on vs. traction off...
Just when I thought I got over missing the M5, I have this issue LOL
Old Aug 26, 2009 | 01:10 PM
prodigymb's Avatar
997TT, C192 GT63, W464 G550, MS Plaid
i usually run with car raised up, suspension in comfort mode, trans in S mode.
1 sec tire spin before the line, torque to 1200 RPM and then about 75% throttle to quickly100% throttle.
Old Aug 26, 2009 | 03:01 PM
TopEndS62's Avatar
Do you click down to 1?or leave in D?
Old Aug 26, 2009 | 03:09 PM
skratch77's Avatar
2005 E55
what were your trap speeds?Im going to the strip tonight,I know how these things sux getting off the line.
My best was 12.6 with tc on.I have drags slicks for tonight so traction shouldnt be a problem
Old Aug 26, 2009 | 03:14 PM
TopEndS62's Avatar
No track.. It was in Mexico, 12.6 with t/c on is good. I asuming your not 100% stock, but how did you launch With t/c on to get that time?
Old Aug 26, 2009 | 03:22 PM
prodigymb's Avatar
12.6 is actually not that great at all for a stock car. mine did 12.7@109 when my SC pump was broken and the supercharger was shutting off (when i first got the car). an average OK run for a healthy stock E55 on street tires is a 12.1-12.2.
Old Aug 26, 2009 | 03:24 PM
skratch77's Avatar
2005 E55
the car is bone stock lol,I have a pulley coming,just sent back my 172 for an upgrade to the 180mm.
Iv tried every setting,nothing really made a big difference.It was like 90 out tho with 80% humidity so hopefully tonight ill get better times
Old Aug 26, 2009 | 03:33 PM
TopEndS62's Avatar
WOW! I have alot to learn more than just launching, i was under the impression that stock our cars run around 12.7... Thanks for the info.. That is also another isssue, between runs 2 and 3 last night my supercharger shut of, so CM30 is first on the list to get
Well report the times tomorrow. now you guys got me curious....
Old Aug 26, 2009 | 03:45 PM
skratch77's Avatar
2005 E55
I will def,just to let you know,me.my brother and friend all got e55s and all 3 pumps were dead.
My car is an 05 had 38k on it,If your sc is shutting off you should def log it with a obd2 scanner and look at your aits
Old Aug 26, 2009 | 04:08 PM
TopEndS62's Avatar
THanks man i'll do that today... where should iats be at?
Stupid question...
Would a failing H/E affect launching/performance(while supercharger is running)?
Old Aug 26, 2009 | 06:26 PM
bassn_07's Avatar
2006 E55 AMG
To the OP. When I was racing with my street tires I used a countdown to the floor. A 2-3 second burnout depending on traction with suspension raised, comfort, ESP on, S mode, and make sure to start off in first gear.
This countdown to floor really helped me in dialing in my car. The very first time I took my car to the track (VR600 on Toyo T1R's 18" stock chromies) I started off with a 1 second count that got me a 13.2. I was using the one Mississippi counting method (seems lame but it ended up working well for me since this was my first time to the track) and my times to follow were 13.00, 12.5, 12.00, and my fifth run was a 11.7. Not that shabby for the first time to the track with all that added power. If anything it help control that urge of just wanting to smash the pedal to the floor. Sounds lame but it worked for me, and please don’t make fun of me…hahaha.
Old Aug 26, 2009 | 07:19 PM
Hammer Down's Avatar
2015 E63S, 2018 E63S
Here's what you do:
suspension shock setting to 1
transmission set to sport mode
if you have street tires get a good burnout (about 5 sec)
power brake up to 1000 (no higher)
let off the brake and roll into the throttle fast (do not mash) until you hit the floor.
keep her pointed straight until you cross the line
I now consistantly run low 1.8 60' on Nitto 555's (not the softest tire)
and I run 12.0-12.2.
It took me 4 trips to the track and about 20 or so passes to figure out how to launch it. I'm shooting for 11's next time out on Sept 4 up in Sac!
as for trap speed...see my sig!
Old Aug 26, 2009 | 11:35 PM
juicee63's Avatar
2011 twin turboed prius
I would say a 12.1-12.2 in a stock car is way better than average. Average is 12.5-12.8 for a stock E55 a 12.2 is a very very healthy run in good conditions
Old Aug 27, 2009 | 12:23 AM
skratch77's Avatar
2005 E55
just ran a 12.5 @113
Old Aug 27, 2009 | 08:03 AM
TopEndS62's Avatar
Thanks I will try the mississippi method Along with ESP on....
Originally Posted by Hammer Down
Here's what you do:
Did you do esp on or off????
Old Aug 27, 2009 | 08:06 AM
TopEndS62's Avatar
was that the best pull or the only one? Still not bad
Old Aug 27, 2009 | 09:21 AM
prodigymb's Avatar
agree to disagree. there is no reason why a healthy E55 wont run 12.1-12.3 with some practice. on 19" wheels and with a broken pump mine went 12.7@109 with a 1.98 60'. if the 60' was better (1.85) it would have done 12.5 with a broken pump. that was also my first time at the track with this car so i had no clue how to launch it and what settings to use etc.
Old Aug 27, 2009 | 10:18 PM
itsmeek's Avatar
Nissan GT-R cobb/midpipe/ic piping/wastegate actuators/tials
It's pointless to do a burnout on street tires. Unless something has changed but an 11.7- holy SHEEIT. Nice!
Old Aug 27, 2009 | 10:20 PM
itsmeek's Avatar
Here's what you do:
esp on or off??
Old Aug 28, 2009 | 05:26 AM
Originally Posted by itsmeek
esp on or off??
ESP on for the run but turn it off for the burnout. (dont forget to turn it back on after the burnout)
Old Aug 28, 2009 | 05:31 AM
good run but its about average. try doing the sneaky ecu reset (do a search here on the forum)
Old Aug 28, 2009 | 08:49 AM
TopEndS62's Avatar
LOL.. before you posted "esp on", I tried it "on". Seemed like a better launch than the ones i was doing the other night... Getting ready for a next mexico run, So i'll see.
Old Aug 28, 2009 | 09:00 AM
itsmeek's Avatar
With the ESP off, you will most likely kill yourself. Especially if you're in the right lane
Old Aug 28, 2009 | 09:58 AM
enzom's Avatar
2005 E55
Getting a good run is not easy. The best place to run is at rentals. You can go as often as you'd like, and back out of runs where your 60' isn't so hot. Plus (and this is a big plus), your car will "open up" as you run more and more often. The sneaky ECU reset is nice, but it can't replace what the ECU is ready to do for you after 5 open runs down the strip.
As an example, at an Atco rental I attended two years ago, I had my best 60' times ever on my first couple of runs, but didn't crack 11's on my first. As I ran more and more, the car got faster and faster (even as the temp and DA rose). My fastest runs came a few hours later with worse 60' times.
Once you get the hang of it on a sticky track, it is pretty easy.
BTW - My fastest runs were with ESP on. Not sure why anyone would want to risk it without ESP. Not worth it, imo.
Old Aug 28, 2009 | 10:07 AM
skratch77's Avatar
2005 E55
oh trust me Iv done everything,this is with drag radials and perfect grip,it was 86 with like 90% humidity.
the da was like 2100
evos that night with 35rs were only trapping 115-116 and the fastest one couldnt get into the 11s.
This is the way my car gets its best times.
ecu reset
tranny in S
D on the dash
T/C off
suspention lowered
This is also with drag radials,this will give you a 14 second run on normal tires lol
