Star Diagnostic How To DIY with lots o pics
Old May 23, 2017 | 08:51 AM
  #1126
seanol's Avatar
2004 AMG E55
BoostedAero,
Thanks! You are right in that I am looking into it but Dallas, while not as hot as your locale, can get pretty warm and humid. Traffic is also an issue and poor airflow across the front of the car could mean the difference in comfort commuting to work.
We spend an inordinate amount of time standing still here!
Old May 26, 2017 | 11:13 PM
  #1127
ben73's Avatar
W108 3.5 - 2005 E55
Today I noticed that my instrument cluster display no longer shows "vehicle rising" when I press the button to lift the car.
I did recently do the star mod to add the fuel remaining display, but I can't see how that would have affected it.
Any ideas? 05 E55
Old May 28, 2017 | 10:15 PM
  #1128
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
722.6 transmission clutch and brake packs wear
How to check your 722.6 transmission clutch and brake packs for wear prior to failure.
https://mbworld.org/forums/w211-amg/...rmination.html
Old May 30, 2017 | 12:21 PM
  #1129
compaddict's Avatar
2016 S63, 2013 SL63
I coded in our TPMS sensors correctly!
Just had a low tire warning.
Very happy!
Old May 30, 2017 | 04:14 PM
  #1130
ben73's Avatar
W108 3.5 - 2005 E55
Very happy!
Excellent news!
Are these the ones you bought from https://tpms247.com/ that we discussed here https://mbworld.org/forums/w211-amg/...s-sensors.html ?
Old May 30, 2017 | 05:13 PM
  #1131
compaddict's Avatar
2016 S63, 2013 SL63
Yes they are! I has just about given up as I never did see the low tire warning at pre-start.
I sold my 2005 S55 without them working (I think).
Vince
Old Jun 7, 2017 | 01:25 PM
  #1132
06cls55amg's Avatar
06cls
has anyone successfully lowered a 07 s550 with star/das? im assuming its a similar procedure to w211, but what about the inclination angle values?
Old Jun 7, 2017 | 01:30 PM
  #1133
skylinrcr01's Avatar
2004 E55, Triumph Speed Triple
They use ABC though don't they?
Old Jun 7, 2017 | 01:44 PM
  #1134
Mackhack's Avatar
Yes
Old Jun 11, 2017 | 02:45 PM
  #1135
mAMG's Avatar
SL55 2003
I have a problem, i bought only c4 multiplexer 3 months ago and it was working fine. Now suddenly it shows me an automatic updating altought the laptop was never connected to the internet ?
I've tried other multiplexers of my friends and they work fine ..
Any idea ?
Old Jul 26, 2017 | 05:29 AM
  #1136
Austin2014's Avatar
X5
Solution
Any idea ?
00 is incorrect, it should be 21, if you could not reset it to 21, please take the photo of screen display and show me.
Old Jul 26, 2017 | 05:33 AM
  #1137
cocoh's Avatar
W203
Hi
Give me TV on PM.
I can fix it.
Old Jul 26, 2017 | 01:02 PM
  #1138
GatorMB's Avatar
2002 CLK 55 AMG cabriolet Eurocharged
Yea, I have never seen that one.
My system gives a failed to update flag along with all the other old Windows XP flags.
You really dont want XP online. It was an Icon for windows in computing but extremely vulnerable to todays criminals.
For those with XP, it should be run with Maximum firewall for VPN, and if the PC absolutely need help get TOR browser.
Most of the Hard Drives for C4 do not have enough storage but a networked Virtual Box image will keep it safe as well.
It takes some knowledge, but an easy way to get outside help on a secure server would be to create a VPN database with Apache.
Hope this gives some a few ideas.
Cheers
Old Jul 26, 2017 | 01:23 PM
  #1139
Mackhack's Avatar
Any system number is fine. The numbers are only there to identify the system in large dealerships where there are more than just one SD floating around. Pick any number.
The update can easily be deactivated. A better way is to actually update the SD Connect properly with this update. It will not hardware block it. Send TeamViewer login via PM if you wish to get help.
There was a reason why an original SD system could not go online natively, but only through the dealership's secured network. And even that was only limited to a few MB specific websites.
Now on win 7 they changed that philosophy tremendously and not necessarily to the best. I personally never had to go online with my SD laptop. Everything is on the laptop that is needed to work on cars. But a VPN is def. a good way of doing it.
Old Aug 21, 2017 | 02:08 PM
  #1140
larsianer's Avatar
w211
exclamation mark on exentry quick test
i have a mercedes w211 220cdi 2003, that only want to start sometimes
i have tryed to scan the system, and i can get readings of the fault codes on the gearbox, the transmission has a exclamation mark on it, and no F!!
what does that mean??
when i use the magnifying glass, to check the codes, i got these strange codes
p2300
p2310
p2311
p2312
p2313
p2314
p2315
p2316
Old Aug 21, 2017 | 02:16 PM
  #1141
Mackhack's Avatar
p2300
p2310
p2311
p2312
p2313
p2314
p2315
p2316
Event!!!
Old Aug 23, 2017 | 07:17 PM
  #1142
larsianer's Avatar
w211
Marry ecu and eis/key
I need to change engine control module.(near fromt sam)
So how do i marry these, i will take the ecu with the key and eis
From a wrecked car
Its a w211 220cdi 2003
I guess i just need to code the new vin, but where!
Xentry
Control units, and then?
Old Aug 23, 2017 | 07:25 PM
  #1143
Mackhack's Avatar
From a wrecked car
Xentry
You have to go to the dealership with registration and ID. This is a theft relevant part (EZS, CDI ME) and requires SCN coding. Used CDI ME might not even be possible but you'll find out one or the other way.
Good luck.
Old Aug 23, 2017 | 07:36 PM
  #1144
larsianer's Avatar
w211
Thank you mackhack
Any suggestions on what i should do?
Give that car, or go to the dealership?
Good luck.
Old Aug 23, 2017 | 07:42 PM
  #1145
Mackhack's Avatar
Thank you mackhack
Just what I wrote!
Old Aug 26, 2017 | 07:24 PM
  #1146
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Assyst Plus - Plus Check it out
Valuable tool to verify maintenance if hard copies are not available. Only applies if work performed via dealer or a conscientious owner/maintainer.
Playing around with the system and found this via the simulation. Tried it today while performing a B service.
Go to:
-Information and Communication
-Assyst Plus - Plus
-General Servicing
-Service Memory
Peruse the entries that show number of days since Central Gateway enabled, days since last service, mileage at time of service, shop designator, and service items confirmed during the service.
If you don't have access to the hard copy records, the Central Gateway maintains all services in memory so long as the Flexible Service System procedures are followed.
Very nice feature. Makes me look forward to my next Mercedes.
Attached Thumbnails Star Diagnostic How To DIY with lots o pics-img_20170826_151142047.jpg   Star Diagnostic How To DIY with lots o pics-img_20170826_150939589_hdr.jpg
Old Aug 29, 2017 | 12:30 AM
  #1147
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Thank you mackhack
Check with Jerry at Eurocharged. He has the ability to reset an existing (used) ECU to virgin status which can then be initialized to your motor without SCN coding.
Old Aug 30, 2017 | 09:15 PM
  #1148
St.laww's Avatar
w220
Does this Work For w221 also?
Originally Posted by aleksandar1099
So I thought I would help out a few MB brothers with a couple star diagnostic tutorials...
First, Lowering the car.
Get to the 211 Section
Attachment 383602
You will get to the main menu
Attachment 383603
Then go to Func perf by more than...
Attachment 383604
Then Chassis
Attachment 383605
Then Level adj
Attachment 383606
Then Suspension
Attachment 383607
And here is where people have problems, they just go to actuations and then lower it, IT WILL NOT STAY LOWERED this way, you have to go to initial startup
Attachment 383608
Then Initial with manual settings
Attachment 383609
Then F2
Attachment 383610
Here you will see a screen that shows the voltages which correspond to the height of the vehicle. they must be within the given ranges in the left hand column. use the + and - buttons to lower the car (In my screenshot I am in the car with a friend in the back seat, so that is why it is at 3.27, it should not exceed 3) Then hit F2
Attachment 383611
Enter in these inclination angles and if the car is within the voltages supplied in the page before, the car will accept the new lowered setting, if not it will reject it.
Attachment 383612
Now, how to activate the unlock and lock beep (honestly, one of the best mods to do if you have an older model e55 )
First Control units
Attachment 383613
Then Body
Attachment 383614
Then rear SAM
Attachment 383615
Then Control unit adaptations
Attachment 383616
Then national version of ATA function
Attachment 383617
At this screen you will see a pull down menu with a list of different regions on it. The only ones you need to worry about are USA with buzzer and Netherlands. If you choose USA, i will give you three short quick beeps when you lock the car and one short when you unlock it. Netherlands will give you three longer beeps when you lock the car and one long when you unlock it. Personal preference on which one you like. Then hit F3
Attachment 383618
Then F3(YES)
Attachment 383619
Hope this helps out some people. I really did not find a good DIY for Star Diagnostics, so I thought I would help out!
Aleks
EDIT: Info for -10 Mod added
Old Sep 17, 2017 | 03:43 PM
  #1149
SICAMG's Avatar
2005 e55 AMG
2.82 gear codeing
Getting ready to swap out rear diff from 2.64 to 2.86 in a E55 and was told I can get into Star and there is a menu for it. Searched and can't seem to find it. Anyone know what menu I need to be in? The screen shot I saw had a whole list of gear ratios listed.
Old Sep 17, 2017 | 04:13 PM
  #1150
Mackhack's Avatar
Should be 2.65 to 2.82.
You have already rated this thread Rating: Thread Rating: 15 votes, 5.00 average.
