Star Diagnostic How To DIY with lots o pics
#1403
More of a general question. By default like most cars when you tap the turn signal stalk it blinks the turn signal 3 times. Is it possible to change so that it blinks more than 3? I ask only because on my wife's Lexus, I was able to use Techstream (think Toyota's version of STAR/DAS) to change the 3 default blinks to 4. I find that 3 seems to not be enough to let people know around here that I am changing lanes and 4-5 seems like the happy number, without getting flashed/flicked off.
Just wondered if this was possible to change in STAR or where I would look to make the change, I didn't see anything in gauge cluster.
Thanks,
-Nigel
Thanks,
-Nigel
#1407
Funny thing is every time we have a loaner during travels I wanna use SBC hold or tip blinking. No SBC hold and the car rolls a few inches at a red light. No tip blinking and we accidentally don’t blink at all until we get used to it.
#1409
Received 1,488 Likes
Thanks,
-Nigel
Thanks,
-Nigel
#1410
As others said, 3 is perfect. If you need more, you're taking too long to change lanes. I basically signal and switch lanes. I don't use it to ask permission, I check to make sure I can do it, then I just do it. If I can't, I don't signal. If you signal too long in advance here, people will move up to stop you.
#1411
Star tool
Hi can anyone point me in the right direction , I'm interested in a star tool for my 2004 e55 , I would like to use it for troubleshooting and testing modules as well as coding as I do all my own repairs . I'm also installing long tube headers soon and would line to turn on off my rear o2 sensors. Thanks
#1412
#1413
I posted the following on another thread;
There is an outstanding posting / thread on another site{which this site mbworld.org will not allow to be named, it get blocked when you post the sites name. Do not know why?
The Titled of the post is "SD Connect C4 -- avoiding garbage"
Perform a Google search {"SD Connect C4 -- avoiding garbage"] , should come right up.
Anyone who is interested or considering any Mercedes Multiplexer clone should take the time and review that entire thread{"SD Connect C4 -- avoiding garbage"], it is a long thread took me 3 hours of reading. And well worth it in my opinion.
The unlocked software{and keeping it unlocked] is more importation than the multiplexer. Then there is a learning curve on the software as you do not have real instructions on how to operate.
If you ever used AUTOCAD you know what I mean.
Regards
Joseph~
Regards
Joseph~
#1415
Regards
Joseph~
Regards
Joseph~
#1416
As the Xentry software is capable of locking a user{ usually a non-licensed, meaning non real license from MB] out. Possible at both ends.
Most expensive program do; AutoCAD, Chief Architect, CATIA, could keep naming, all are caplable of the same. But you are aware what I am saying. As they all operate (licensing that is) on the same way / system / or as I think the correct word is "security scheme."
I do know that as of 03/2020 the Xentry software key system was / is being changed again.
I am always looking to learn.
The abysmal quality of clone multiplexers dose not not help.
The MB hardware's equipment with legal license $30,000 for 3 or 4 years is out of line,. Even the "pass thru" is $4,000 per year.
Would you spend $4,000 per year for a legal MB license to work on you owned vehicle? This is assuming you already have the correct hardware.
You comment, thoughts, opinions
Regards
Joseph~
#1417
Could you please clarify / correct me?
Regards
Joseph~
Regards
Joseph~
Your question about “would you spend 40k for a legit system” must come from a bad upbringing.
Do you steal a 40k car if you can’t afford it because everyone should have to right to own whatever he/she pleases? In all honesty and with due respect, what makes you think it is ok to justify a stolen/cloned system for private or business purposes because you don’t agree with the sticker price?
Don't get me wrong I’m not justifying the price of a legit system either but the thought behind justifying a clone for that matter. As a matter of fact I believe they legitimately steal money from the dealerships bc forcing them to lease a system for $30-40k. If MB pulls the plug and says you need to lease a new system because we tell you so makes it even worse.
The dealerships therefore charge an arm and a leg just to read out the fault codes. Here MB charges $185 flat rate. I even understand, they have to recoup the money somehow.
In the end it’s all about shareholder value. Nothing else. You as the customer mean nothing to anyone.
That being said you have no right to own a legit or clone system if you don’t have a automotive business. That is all clearly written in their disclaimers. Lawyer galore.
Last but not least, don’t take this personal. I simply stated the facts.
bbirdwell (03-15-2020)
#1418
None of the bootleg versions lock the software out. If the key runs until let’s say 2040 then your system will run til then. A new key and it runs even longer. There is no magic involved to understand this.
Is that what you are stating?
Joseph~
#1419
#1420
KPH to MPH cluster swap. Main board moved trying to correct analog speedo
I just purchased a 2005 e55 with 67k miles. It is a Canadian spec car with a KPH analog speedometer. I purchased a MPH cluster and swapped the main board over. The dash is back in and working great except for the needle which is obviously going to be off against the MPH scale. I figured I’d use star to code it but I’m a little over my head. I thought that I could correct the analog needle position by changing the national variant. The car originally was set to canada with SA code 461 set to “not present”
So I changed the national configuration to “USA” and set SA code 461 to “present”
The analog needle seemed to say the same and the digital speedo (which is set to mph already) started displaying double what ever the analog needle was indicating.
I changed the coding back to its original state and no damage done. For you guys who know there anything I can do on my end or is this going to be a developer version of star diagnostics to fix?
#1421
The following 2 users liked this post by Mackhack:
5ohTreeAMG (03-25-2020),
compaddict (03-25-2020)
#1422
Thanks for the reply. I’ll shoot you a pm a little later. I take it your going to reset the Motorola chip to reset the miles and go from there. Sounds good to me. But I am still curious why what I did didn’t work. Seems like it should have any thoughts?
#1423
Because all information that your cluster needs is spread across multiple locations. That’s why you can’t just swap a board.
I’ll wait for your PM and we go from there. I have helped countless people with that and similar issues.
#1425
PM sent. I’d love to sit down with you and a case of beer and learn more. I get that the cluster is tied to the different modules. That’s why I swapped the board. But one would think that the drive for the analog needle would be isolated in the gauge cluster and be coded there. Unless that information is sent from the abs controller and the cluster responds to that. But then again I’m not and expert and talking out my *** at this point. Anyways I’ll wait for your PM and we will work something out and as a plus I’ll have my original cluster for backup/parts down the road.
