Lowering and wheel alignment
Old Dec 18, 2009 | 07:59 PM
Objectionable's Avatar
E55 AMG
I did Star lowering a very small amount. I took it back to the shop to have it aligned, but after two days of trying they can't get it done correctly. They have suggested that it isn't possible with the car lowered any amount. Is wheel alignment impossible or do I need to find a new shop?
Thanks.
Old Dec 18, 2009 | 08:41 PM
jdeastbay's Avatar
2005 E55 / 2008 E63
I received the same feedback. Could address using bolts etc then life got busy forgot about and keep drifting right. Will try and get the details.
Old Dec 18, 2009 | 08:51 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Yep,
and you may need crash bolts
https://mbworld.org/forums/3344784-post11.html
Old Dec 18, 2009 | 10:20 PM
E55 AMG
Originally Posted by Yacht Master
Yep,
Thank you sir!
Old Dec 18, 2009 | 10:48 PM
bobgodd's Avatar
2004 E55
Hey YM, I had an alignment shop put in those bolts (I bought them from MB myself) and my car still pulls slight right. Any idears?
Old Dec 18, 2009 | 10:58 PM
ohlord's Avatar
Camber eccentrics
camber rear links from speedybenz or lensolo.
Or camber bushing from K-mac all around.
How much did you lower it?
How negative is the camber?
Find a better shop.
One with the new hunter machine that also knows how to properly align a Mercedes.
allenjdmb's Avatar
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
Yes, the crash bolts will help. The right pull....
is not so easy. Some cars seem to have it worse than others, and some tire brands are certainly worse than others. The lower you go, the more likely she goes that way.
Old Dec 20, 2009 | 08:49 AM
DAGREEKNYC's Avatar
Registered User
2019 s560 sedan
wtf are crash bolts ??????????????????
Old Dec 21, 2009 | 12:15 PM
Busta Riles's Avatar
1969 280S, 1991 300E
How many bolts do i need? 2?
Old Dec 21, 2009 | 01:39 PM
Max.H's Avatar
E55
Mine pulls slightly to the right as well. Had it aligned and still the same.
Old Dec 22, 2009 | 04:41 AM
NSX2NV's Avatar
03' E55 Techtite Grey
Mercedes aligned my car and they said it was fine. I'm pretty dumped too.
Old Dec 22, 2009 | 08:01 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
I had my car lowered using the SDS, secret menu. Anyway, my Tech said that the E63 doesn't need re-aligning, because of the air suspension. And he's right, I have no pulling issues to date. The E63 tracks straight as an arrow.
Old Dec 22, 2009 | 09:29 AM
emoving's Avatar
3-five-five/ TUNDRA/ 07 997 cab
Hotrod-relator just picke up my 55 that was star lowered and thought it pulled slightly to the right. Maybe he can chime in here after the 8hr trip home. I never really noticed it pulling at all though. It also depends on what setting I was in as far as height.
Old Dec 22, 2009 | 10:02 AM
Marcus Frost's Avatar
Real Cars
Shop I use has a new hunter machine and did not complain about my car being difficult to align after being lowered via STAR 1". My car does not pull in any direction. Another reminder of why it pays to have a good shop...
-m
Old Dec 25, 2009 | 07:22 AM
NSX2NV's Avatar
Yeah mine doesn't seem to pull. Maybe slightly to the right sometimes but I heard they are suppose to pull a little to the right so if you fall asleep you don't go into on coming traffic. I really only was worried about tire wear due to negative camber. My stock wheels wore really bad on the inside cause I never got it aligned and that's a waste of tire on top of traction.
Old Dec 25, 2009 | 04:00 PM
AZIPOD's Avatar
W211,E90,E66,E39,E38,NSX,Z32-TT
My cambers are a little bit off maximum specs for both/rear, but not by much -- I think its livable. However, I DO NOT have any pulling to one side. That just doesn't sound right.
Old Dec 27, 2009 | 04:21 PM
E55 AMG
-m
Amen - I've got to get one. Who do you like - it will be worth the drive for me.
Old Dec 27, 2009 | 06:01 PM
AWOL's Avatar
e55
My car is lowered, no pulling to the right. Straight as an arrow. I did it via washer method
Old Dec 27, 2009 | 08:35 PM
r-magic's Avatar
2004 E55
+1 looks good. I did the same thing and worth every cent. I think its the best mod you can do for cheap. There is no load on the links so you really dont have to worry about the nut coming off. Just put loctite on there and your good to go.
