exhaust manifold removal and reinstallation
Does anyone know how much the dealer charges for removal and re-installation of exhaust manifolds? About how many hours does the book say? (FYI this is for an '04 E55K)
Also, I found these nice write-ups, but don't know if i can tackle the job with my big old clumsy hands and sausage fingers:
https://mbworld.org/forums/w211-amg/...r-install.html
To those of you who have tackled this before, does removing the air filter assembly and coil packs really give you that much more room to work? Just looking at the engine bay with everything installed, it doesn't look like removing them would give me enough room to work.
If I have access to a lift, does that change everything? (meaning I can do everything from underneath the car) or do I still need to remove everything to get to it from the top side?
Why are you removing stock manifolds and then re-installing them? Seems like if you go to the trouble of removing them, you'd at least want to do a set of bolt-on shorties. Just wondering.
anyways, i just wanted to see how tough the r&r process is on these cars... i may go down the aftermarket route in the future, but I'm really just trying to see how easy it is to get the problem fixed in order to pass inspection
You might want to have the current owner repair it before you purchase, as the variables could eat up any savings you may see buying a damaged car.
Good luck!
