Custom FREEZE trunk tank in!
Old Jul 19, 2010 | 07:52 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Well, not installed yet but arrived on my door. This is a custom made surge tank , designed to fit inside my fullsize spare.. It will be easily removable and the spare will of course be out during racing..Just in case you ask..
This tank is made by Donny with Dads custom intercooler tanks.. Great guy and compnay to work with.. Prices are great and workmanship is of extreme quality standards!
I had room to go to 7 gallon tank inside my spare but decided to stay with 4.5 gallons..
Picture of tank inside my fullsize spare, inside trunk..
Side view.
Another shot inside trunk..
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Jul 19, 2010 | 08:02 PM
HadiLaw's Avatar
2004 E55
So how can i place an order?? That looks very nice and I can't wait till we test it out on the track!!
Old Jul 19, 2010 | 08:03 PM
vietjdmboi's Avatar
'04 E55 AMG
oh my. i think im in love. hey brooke, can you pm me a price? would this thing fit in my e55?
Old Jul 19, 2010 | 08:16 PM
98aggie's Avatar
Chevy Camaro
How many beers will fit inside?
Old Jul 19, 2010 | 08:18 PM
PLATINUM SPONSOR
2003 CL55
Here is the link to his site and he list all over ebay.. I think a few other members on here have bought tanks from him already.. Quality is great!
http://dadscustomintercoolertank.com/
vietjdmboi oh my. i think im in love. hey brooke, can you pm me a price? would this thing fit in my e55?
Today 08:02 PM
You are in luck, he makes all kind of tanks that fit right into your spare tire box.. His standard sqaure tank , runs around 150 bucks and goes up from there , depending on customization.. You ask me, these are a great bargin~!!
__________________
www.ultimatepd.com
Old Jul 19, 2010 | 08:20 PM
PLATINUM SPONSOR
2003 CL55
Lol, I plan to use a bye pass fitting, so the tank can double as a custom cocktail chilllllllller!
Old Jul 19, 2010 | 08:43 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
lol
Brooke the tank looks nice. Now create your own ambient conditions!
Old Jul 20, 2010 | 12:05 AM
vietjdmboi's Avatar
'04 E55 AMG
i have been looking for something like this to be used as a water/meth tank. completely out of sight. i did not want a tank to clutter the trunk..and there's just no room up front for any kind of tank. we'll see what happens when donny gets back with me. thanks again brooke.
after looking, i may go with a half moon shaped one. 4.5gal might not be necessary. but we'll see.
Old Jul 20, 2010 | 10:08 AM
shardul's Avatar
this maybe a viable option, have a 2 compartment tank built. The larger one being for coolant and the smaller one being for meth.
Old Jul 21, 2010 | 03:59 AM
AdrockTT's Avatar
SL65
Nice looking tank. Why did you go with the smaller tank size when larger would have fit?
Old Jul 21, 2010 | 09:22 AM
PLATINUM SPONSOR
2003 CL55
I am real cautious with adding weight to the car, so I feel that 4.3 gallons is enough to do the job..It also gives me extra room for my lines, pump (if I need one) and also to drain water from tank.. It is Peeeeeeeeerfect for me needs..
I weighed the tank and it is 7lbs even.. Not bad! I estimate the total system , filled with water and installed; to be right at 50lbs.. That takes about 5hp to move the extra weight.. My guess in warm weather , this tank can net 30-40hp and in cold 10-15hp..
Old Jul 21, 2010 | 09:53 AM
BenzCLS06's Avatar
CLS55
Wow! That thing is beautiful!
Old Jul 21, 2010 | 02:57 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
Looks like so many people will be going for the record this winter
Old Jul 21, 2010 | 09:11 PM
AdrockTT's Avatar
SL65
Great work. If you wouldn't mind - I'd be interested to see pics/explanation how you run the lines/pump. Thanks!
Old Jul 22, 2010 | 09:56 AM
prodigymb's Avatar
997TT, C192 GT63, W464 G550, MS Plaid
I had a 9 gallon tank made by Donny and it was amazing. welds were top notch and it was made to the exact dimensions i gave him.
Philly Single's Avatar
Supra
Just can't resist the mods huh!? A setup like this is on the short list for my S65 too. The amount of cooling and resulting gains is tremendous...I should dig up some logs I have from my Supra showing how cold the air gets running through a big water/ice cooler!
Jay
Old Jul 22, 2010 | 08:07 PM
AdrockTT's Avatar
SL65
Ha! Just researching I need to drive/enjoy the car first, but wanted to have a logical approach planned out if I were to have the mod bug bite. I'm most concerned with warranty coverage, (unlike my supra), so I am proceeding with total caution.
Adam
Old Jul 26, 2010 | 08:01 PM
PLATINUM SPONSOR
2003 CL55
After speaking with Carl Meziere, with Meziere pumps, I decided to go with an intank pump. Thanks to Bassn07 for explaining in detial what has and has not worked for him..
I almost tried a single front I/C pump but now convinced that would not work or work long term.. Our I/C pumps are made to push and with a rear tank, not much water moving to a front pump and with a rear only (external) , same issue , although better as it is closer to the source.
I thought my tank would be in now but again, trying to customize a system, has caused delays on finding the right parts..
Here is pic of my 1200 GPH intank bilge pump. It`s job is to just keep a good steady flow to my front pump, so it can push a ton of water into my Supercharger! These pumps are light, inexpensive and easy to change and clean..
__________________
www.ultimatepd.com
Old Jul 26, 2010 | 09:23 PM
Roverron's Avatar
ML63
this is the formula for heat transfer
Wouldn't it be better to run 1 inch line and coil it in your tank say like 15 to 20 feet of line. this would be no restriction to your pump. this will also transfer the temperature to the fluid for a longer period of time. use a more stable fluid like "water/glycol mixture" for heat transfer and then pack your tank with ice and water to maintain temp and balance. Right now I'm assuming that you pack with ice it melts you repack with ice, your main fluid would be water which isn't the best for stability the heat will transfer from H/E under charger to water to tank, over a period of time heat will end up in the rear and you will have a reverse hot water heater. I don't have a rear set up.
so don't take this as a knock or put down I'm throwing ideas out of what I'm trying to make for myself. I used some thing like this in a cool can for cooling off fuel in a 1/4 mile drag car.
Old Jul 27, 2010 | 02:50 PM
PLATINUM SPONSOR
2003 CL55
Not an expert on thermo engineering but our/my heated S/C coolant is cooled by two large heat exchangers before going back into the tank.. So, not really a reverse heat pump..
My current water loop system is about 1.5 gallons and I run 15-20 degrees over ambient in this 95 degree heat. If I do a boost run from 40mph to 110, I am seeing 155 deg. or so. So top of the run, almost all timing is pulled in the heat..
Adding 5 more gallons will greatly curtail those peak spikes on day to day summer driving.. If I add ice, then 1/4 mile runs will be held in a very nice IAT range..
__________________
www.ultimatepd.com
Old Aug 11, 2010 | 12:55 PM
W219CLS55's Avatar
06' E55, 10' Harley Davidson F-250 6.4L TT
How much for this tank?
