Frozen Boost Heat Exchanger
Old May 15, 2011 | 02:40 PM
tbal's Avatar
Haters crazy
Question Frozen Boost Heat Exchanger
I know there is one person on here who installed this puppy.
http://www.frozenboost.com/product_i...0b4fee25778e3a
Anybody else have any input on this HE? The price is unbeatable, or would you recommend a different HE? Fitments, parts needed for install etc? The 3.5" thickness seems kinda of big, and locating the oil cooler behind the HE going to cause any problems?
I'm changing the IC pump, and coolant so figured might as well do this as well and get the cooling mods out of the way... (for now, haha)
Thanks in advance tech gurus
Old May 15, 2011 | 04:42 PM
pbsis's Avatar
Interested in this as well!
Old May 15, 2011 | 05:10 PM
TTMotorsports's Avatar
Former Vendor of MBWorld
Whatever we're tuning!
The NPT fitting are only 1/2" ports whereas the stock circuit uses 3/4" hose. That will be a major pressure restriction.
I would pass on this and get either the C&R Racing built one that EC developed/sells(I actually bought 2 this week from them) or the Ebay special PLM.
Old May 15, 2011 | 06:04 PM
sneakyneon's Avatar
Bicycle
There is two people that I know of that have it, me being one of them.
Old May 15, 2011 | 06:14 PM
BenzoDoc's Avatar
2015 E63S 4Matic
So would you mind sharing your thoughts?
As Bruce mentioned, the fittings are a bit smaller - did you opt to change the fittings, if that's even possible?
Old May 15, 2011 | 06:47 PM
tbal's Avatar
Haters crazy
+1
There are these aswell..
http://www.zzperformance.com/grand_p...=857&catid=139
http://zzperformance.com/cobalt_ion/...=895&catid=178
Old May 15, 2011 | 08:02 PM
sneakyneon's Avatar
Bicycle
Its NPT you can change the fitting but the ID will always be the same.
I would not use it if I had to do it over.
Install is covered Here
https://mbworld.org/forums/w211-amg/...r-upgrade.html
Old May 15, 2011 | 08:06 PM
tbal's Avatar
Haters crazy
So no point doing the FB HE?
What about the other ones I posted links of?
Old May 15, 2011 | 08:09 PM
sneakyneon's Avatar
Bicycle
more usefull info
https://mbworld.org/forums/w211-amg/...exchanger.html
Old May 15, 2011 | 08:13 PM
sneakyneon's Avatar
Bicycle
ZZ maybe a better bet,
Read this: http://zzperformance.com/cobalt_ion/articles1.php?id=65
I went with the FB because I'm perpetually broke and it fit my budget after this mishap with a semi truck tire
IMG00217-20091007-1308.jpg?t=1305504729
Old May 15, 2011 | 08:15 PM
sneakyneon's Avatar
Bicycle
What are your peak IAT temps now?
Old May 15, 2011 | 09:49 PM
tbal's Avatar
Haters crazy
I appreciate the help! I know we started off on the wrong foot... Lol
I'm still confused on the FB, Npt you can change, what's ID?
Some of the links I posted are from that thread. I'm confused on which one to get...
Old May 15, 2011 | 10:00 PM
BenzoDoc's Avatar
2015 E63S 4Matic
http://en.wikipedia.org/wiki/National_pipe_thread
ID = Inner Diameter
Old May 15, 2011 | 10:07 PM
tbal's Avatar
Haters crazy
Lol thanks
Old May 15, 2011 | 10:18 PM
alexoE55's Avatar
e55 2005
WOw BS same thing happened to me , what the hell man , they should put some kinda law for that god damnit.
Stupid tires just poppin out of nowhere
Old May 16, 2011 | 01:00 AM
guysandiego's Avatar
2006 E55 AMG --old cars -- E39 M5, 2.7tt Audi S4, E36 M3 **Ducati 996, 748
i got this HE -- Riveted it to the bumper support... had to do some minor trimming on the bottom of the 'skid plate' --- had to really tuck the oil cooler --
No problems with this massive HE-- but I never had problems with the OEM HE either -- even in the Vegas summer.
Old May 16, 2011 | 01:02 AM
tbal's Avatar
Haters crazy
Okay so FB is out of the question.
How about the Zz performance one???
Old May 16, 2011 | 01:59 AM
sneakyneon's Avatar
Bicycle
Honestly the best money spent now would be on logging softwear. Have to know were your at to be able to improve on that.
Old May 16, 2011 | 02:26 AM
ShangoAshe's Avatar
2020 AMG GT-R PRO
+1
Old May 16, 2011 | 03:14 AM
tbal's Avatar
Haters crazy
What about the NPT fittings, using 1/2" over the stock 3/4" wont that restrict flow?
I am looking into datalogging possibly, but wideband for sure afr/iat monitoring at the min.
Old May 16, 2011 | 03:25 AM
tbal's Avatar
Haters crazy
This one http://zzperformance.com/cobalt_ion/...=895&catid=178 looks identical to the Eurocharged and PLM HE's. Cooling specs seem to be the same as well. I want to order today hopefully, really leaning towards this one, unless one of you PROS says otherwise
Old May 16, 2011 | 06:28 AM
komp55's Avatar
ML550
Are any of these an improvement over the Code 3 HE?
Old May 16, 2011 | 07:37 AM
320 dreamer's Avatar
2003 porsche 996 turbo
the zzp has the 2 main factors i looked for in a larger h/e. first being fin area. the more area the better the cooling. the 2nd is inlet diameter and at 3/4 you should be fine. looks like a better quality product than the f/b just my .02
are you able to slide a h/e behind the crash bumper? i relocated my horns and p/s line and was able to slide a 26x16x1 in front of the oem radiator. massive fin area and allows for 100* diff between engine and i/c temps
Old May 16, 2011 | 09:59 AM
Already's Avatar
E55/335i
Im not sure that would even be an issue, If Im not mistaken the ID of the pump inlet is much smaller then it appears as well (cm30), and a closed system like this is going to be limited by single smallest dia./ most restrictive point right!?!
Old May 16, 2011 | 01:24 PM
tbal's Avatar
Haters crazy
Thanks! Gonna pull the trigger on that one than . Reading the specs on the oem he i can't believe how garbage it is and why amg bothered to even use it...
