M1 Lowing Module Plug and Play is here!
For those not familiar with the M1 lowering module. It allows you to control your cars ride height settings from your steering wheel. It is the most stealth system available for Mercedes ELM's. I haven't tried, because I lost my spare key. However this system lets you have ride height setting set to each key to your car. One setting for your key and the other for your spouse. With the touch of your pre-existing steering wheel buttons you can pull up a screen in your instrument cluster that lets you make all sorts of ride height adjustments.
Price is $1649 for the M1
Price for the Harness is $89
Price for both M1 and Harness is $1688 and saving of $50 when you buy both harness and M1.
PM me if you are interested.
Keep in mind this harness ONLY works with the M1. It will not work with any other ELM
Best Regards,
-Mike
M1 Lomo
Quick Connect PnP harness for the M1
Let me look into it. I should know later today
https://mbworld.org/forums/e-class-w...m-install.html
