Update on my 200mm Pulley! (First 200mm?)
Old Sep 9, 2011 | 01:25 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
As mentioned a few months back, after head install, I was going with a 200mm pulley. Well I have this giant flying saucer in my hand now.. What a fricking beast! I think I will just call it the "flying saucer". It may even be close to the size of a Roman battle shield. hehe
I will get everyone more info and pictures soon.
I plan to dyno and tune my current set up and then put the 200mm on and test. One mod at a time..
I spoke with Jerry at EC and he is ready to tune the ported heads and pulley set ups. I prefer road tuning for the Mile, as it was dead on last year! I am buying an EC V2 tune box, so I can store multiple tunes. AKA- 1/4 mile tune, Texas mile tune, Street tune and any other combo that may be needed. If you dont have a tune box like this, it is well worth it! One way or another, you will want your tune changed and no better way. You may even want a proven Texas mile tune, if you have simulair set up. "Just Saying"
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Sep 9, 2011 | 01:40 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Pics or it didnot happen
skratch77's Avatar
2005 E55
good luck with cooling that bad boy lol
I used to mess with liquid nitrogen overclocking my cpu running it -85 c
I would look into buying some ln and pooring it in your ice box in the trunk,that will drop your temps enough to keep the aits under 100 degrees by 180 mph.
Im not even joking and was going to run that **** in my trunk
chawkins2001's Avatar
2006 E55 AMG
I would love to see your beast hit 600rwhp/700rwtq!!!!!!!! I would invest in gum guards and a neck brace, I have a feeling you are going to need it bro
Old Sep 9, 2011 | 01:46 PM
aghakauve's Avatar
GLC63s, W222 S63, W223 S580
Brooke =
Old Sep 9, 2011 | 01:49 PM
skratch77's Avatar
2005 E55
http://www.youtube.com/watch?v=kRejtM3ifjU
Old Sep 9, 2011 | 02:05 PM
shardul's Avatar
Originally Posted by skratch77
very interesting!
Old Sep 9, 2011 | 02:07 PM
skratch77's Avatar
2005 E55
Originally Posted by shardul
very interesting!
only problem is its like 500 bucks for 20 liters
Old Sep 9, 2011 | 02:12 PM
shardul's Avatar
on the streets of Houston I have seen liquid nitrogen tanks being left overnightto pump it underground. maybe i can jack some lol
skratch77's Avatar
2005 E55
you would need to test it out since this stuff can hit -135 c so it will freeze your whole setup,I was thinking of running alchol threw the heat exchanger since that wont freeze easy lol
Ethanol freezes at –110°C so that would be your best bet to run threw your heat exchanger
Old Sep 9, 2011 | 02:57 PM
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
I understand several 205+ pulleys already exist. Problem is, just talk from back East, no concrete proof yet. So looking forward to yours as a complete package. 600RWHP should be very easy on the right dyno and tuning.
To be honest I would dump that water tank you have and go meth mix before going to a larger pulley. Unless I missed a post and you already have.
PLATINUM SPONSOR
2003 CL55
Boost makes heat, so I never said anything about adding anymore boost. hehe Just adding a Roman battle shield 200mm pulley! Sending this pulley of to have pro pictures taken now! It is just that damn cool!
Here the pic for Shardul!
I have witnesses, receipt and this big ****** in my possesion! 200mm, such a nice round number.
Still have to button up the engine , then Evosport light rotors, then 200mm pulley.
Ok ,, have to run and get back to finishing up the CL.
Skratch,,,,,,,,,,,,That cooling gooo stuff is cool. 500 is not bad, if it works great.
__________________
www.ultimatepd.com
Old Sep 9, 2011 | 03:03 PM
instag8tr's Avatar
03 E55
Why not tune it to run e85. It burns a lot cooler , is cheap, and has an octane rating around 108. Plus you can pump it straight in your car .
Old Sep 9, 2011 | 03:47 PM
shardul's Avatar
One of the reasons he is getting a tune box so he can swap files
Old Sep 9, 2011 | 04:02 PM
PLATINUM SPONSOR
2003 CL55
E85 is in the plans but it requires about 15% more injector-ish. E85 also takes up a lot of cylinder volume with being less as effecient as other fuels. Thus the reaon you need to shoot more of it to go witht he same air. It does have it balance and trade offs. So have to set up the new build and and see if I need to go to 750cc or larger.
I really prefer to run a 215MM but waiting on the S/C MFG to get back to me on bearing spec. information.
__________________
www.ultimatepd.com
Old Sep 9, 2011 | 04:50 PM
instag8tr's Avatar
03 E55
That is a downfall of e85 . Also might have to look into pump upgrade
Old Sep 10, 2011 | 05:46 PM
gp500e's Avatar
2006 E55
Im glad to see someone try 200mm pulley; however, it will only be good for a very cool dyno run.
Old Sep 10, 2011 | 07:26 PM
BRABUS786's Avatar
Stage 3 63
Good luck
Old Sep 10, 2011 | 11:21 PM
PLATINUM SPONSOR
2003 CL55
It is only 7.5MM larger per side, than my 185. One way to look at it. Or you could say only 8% larger.
__________________
www.ultimatepd.com
Old Sep 11, 2011 | 12:25 AM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
What is the max speed rating on the blower?
Old Sep 11, 2011 | 12:43 AM
ahmad0658's Avatar
Brabus K8 E55 05
Exotic-Metal55 Speak with Ali from UAE, I think there are some guys run big pulleys around here and he knows about these experience, he can be helpful.
Old Sep 11, 2011 | 11:30 AM
PLATINUM SPONSOR
2003 CL55
Dont know but checking with MFG.
Thanks , we have all heard about the 200 plus mm you guys have run but testing information, pictures and longevity have been hard for us to get. Even boost levels, so I guess I am going to test/Run one in Texas.
__________________
www.ultimatepd.com
Old Sep 11, 2011 | 11:50 AM
Forrest Gump 9's Avatar
shrimp boat
Brooke, you're a crazy man!!
Have you look into making a smaller pulley for the SC?
Old Sep 11, 2011 | 08:48 PM
PLATINUM SPONSOR
2003 CL55
Yes I did look into making a smaller S/C and you can do that but it was easier to just make a larger crank pulley for me.
I drove 8 miles today only and heads are flowing great! IATS are lower on average, boost has come down , as it is suposed to with good heads and most of all LTFT are adding fuel like crazy! That means 02`s sense the extra air. In 8 miles , LTFT adjusted 4% and still moving. Went from taking out minus 3.5% to adding fuel positive 7% so far. That is a big move in only 8 miles.
Cant wait to ge this 200mm on but need to test what I have before throwing the fuel to the wolves!
__________________
www.ultimatepd.com
Old Sep 11, 2011 | 09:15 PM
shrimp boat
that's sick!! I and the rest of the board sitting on the edge of our seats waiting for your new dyno result.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
