Need some experts to look at some data..
here is the data only 8.6 lbs of boost. at 6233 rpm
datetime","Air Intake Temp","Timing Advance","Intake Manifold Pressure","RPM","Boost"
2011-10-26 16:30:53.367,120.2,-21,23.35108,6233,8.655128
And the highest boost reading was 10.3 lbs.
2011-10-26 16:30:52.487,100.4,-19,25.09153,4546,10.39558
All the data through the run
"datetime","Air Intake Temp","Timing Advance","Intake Manifold Pressure","RPM","Boost"
2011-10-26 16:30: 22.809,91.4 ,-5.5, 6.526699, 596,- 8.16925
2011-10-26 16:30:23.702,91.4,-6,6.381661,597,-8.314288
2011-10-26 16:30:24.602,91.4,-9,6.381661,582,-8.314288
2011-10-26 16:30:25.507,91.4,-7.5,6.381661,578,-8.314288
2011-10-26 16:30:26.406,91.4,-18,5.656472,717,-9.039477
2011-10-26 16:30:27.315,91.4,-18,5.221359,846,-9.47459
2011-10-26 16:30:28.234,91.4,-18,4.786245,979,-9.909703
2011-10-26 16:30:29.132,91.4,-19,4.49617,1029,-10.19978
2011-10-26 16:30:30.020,91.4,-19.5,4.786245,1062,-9.909703
2011-10-26 16:30:30.928,91.4,-23.5,5.221359,1185,-9.47459
2011-10-26 16:30:31.818,91.4,-27,5.076321,1414,-9.619628
2011-10-26 16:30:32.716,91.4,-28.5,5.076321,1658,-9.619628
2011-10-26 16:30:33.619,91.4,-30,5.221359,1928,-9.47459
2011-10-26 16:30:34.512,91.4,-31,4.786245,2216,-9.909703
2011-10-26 16:30:35.410,91.4,-31.5,4.786245,2457,-9.909703
2011-10-26 16:30:36.309,91.4,-30,5.511434,2262,-9.184515
2011-10-26 16:30:37.189,91.4,-29.5,5.946548,1881,-8.749401
2011-10-26 16:30:38.099,91.4,-29.5,5.656472,2064,-9.039477
2011-10-26 16:30:39.005,91.4,-30,5.511434,2236,-9.184515
2011-10-26 16:30:39.893,91.4,-31,5.656472,2395,-9.039477
2011-10-26 16:30:40.772,91.4,-31,5.511434,2555,-9.184515
2011-10-26 16:30:41.681,91.4,-31.5,5.511434,2672,-9.184515
2011-10-26 16:30:44.072,91.4,-28.5,6.671736,2086,-8.024213
2011-10-26 16:30:44.972,91.4,-28.5,6.381661,2072,-8.314288
2011-10-26 16:30:45.871,91.4,-28.5,6.671736,2168,-8.024213
2011-10-26 16:30:46.778,91.4,-29.5,6.526699,2270,-8.16925
2011-10-26 16:30:47.705,91.4,-29.5,6.526699,2366,-8.16925
2011-10-26 16:30:48.594,91.4,-29.5,6.816774,2449,-7.879175
2011-10-26 16:30:49.493,93.2,-10,24.80145,2680,10.1055
2011-10-26 16:30:50.392,96.8,-14.5,24.36634,3672,9.670392
2011-10-26 16:30:52.487,100.4,-19,25.09153,4546,10.39558 <max boost
2011-10-26 16:30:53.367,120.2,-21,23.35108,6233,8.655128 <max rpm
2011-10-26 16:30:54.270,122,-18,25.38161,5043,10.68566
2011-10-26 16:30:55.168,120.2,-31,3.045793,4641,-11.65016
2011-10-26 16:30:56.067,116.6,-31,3.045793,4388,-11.65016
2011-10-26 16:30:56.955,114.8,-30,2.900755,4047,-11.79519
2011-10-26 16:30:57.863,113,-29.5,2.900755,3708,-11.79519
2011-10-26 16:30:58.740,111.2,-28,2.900755,3362,-11.79519
2011-10-26 16:30:59.671,109.4,-26.5,3.045793,3032,-11.65016
2011-10-26 16:31:00.920,109.4,-25,2.900755,2684,-11.79519
2011-10-26 16:31:01.828,107.6,-23.5,2.900755,2212,-11.79519
2011-10-26 16:31:02.717,107.6,-22,3.045793,1881,-11.65016
2011-10-26 16:31:03.624,107.6,-19,3.335868,1567,-11.36008
2011-10-26 16:31:04.556,107.6,-2.5,3.770981,1179,-10.92497
2011-10-26 16:31:05.479,107.6,-9,4.786245,907,-9.909703
2011-10-26 16:31:06.371,107.6,-4,5.656472,714,-9.039477
2011-10-26 16:31:07.268,107.6,-4.5,6.381661,696,-8.314288
2011-10-26 16:31:09.465,105.8,-2.5,6.671736,631,-8.024213
2011-10-26 16:31:10.763,105.8,-3,6.381661,619,-8.314288
2011-10-26 16:31:11.671,105.8,-6,6.381661,605,-8.314288
2011-10-26 16:31:12.580,105.8,-7,6.381661,594,-8.314288
2011-10-26 16:31:13.477,105.8,-7,6.236623,587,-8.459326
ps let me know when you go bigger pulley,im looking to go to a 168 setup and I will dyno that vs my 178 pulley.
I know it is but, thats the way the file opens. Your seeing a spike in boost (11lb) because the run was completed and the throttle was let off.
This is my dilemma...
How am I getting 10.39558 boost at 4546rpm and only 8.6lb at 6223rpm. I would think since the motor is spinning at a higher rpm the blower would create more boost.
Is it that the motor runs more efficient at a higher RPM and its maxing out the 168 pulley or is the car bleeding off boost?
If Shardul was here im sure he would chime in and I would make a choice of what to do and the paying sponsors on here would see some business from my end.
Thanks Scratch. I need to be sure of whats going on before I make the next move.
I have same mods as you with the addition of a renntech airbox tb.next time you dyno take the whole intak off with no filters and see if theres more in her.
you lost boost because its flowing more threw the engine and its showing less boost but there is more power to be made with tb and airbox.
The dyno #s you mentioned, are they with the 178 or 168?
Wouldnt a larger TB and AB just make the problem worse as far as boost #s (filling a bigger hole)? If the pulley is too small then thats my next step. I would like to do a single upgrade at a time and dyno for results so I can see how much of a benefit each upgrade made.
Here is a previous scan I made of my car:
This is 2nd and 3rd gear. You can see that at in the 4000ish rpm in 3rd my car sees 14+psi yet at 6000 in 2nd it actually touches 12.9psi. Even at 5,600 in 3rd it goes down to 13.2.
Keep in mind I have a 178mm Pulley.
I do agree that the possibility exist that opening up your throttle body and intake setup should mostly solve this issue ( in my car as well, I have stock TB and airbox ).
Always good...having a bigger pulley. Looks like my car has the 74mm TB(113 141 01 25
) disappointing to find since mine is an early 03 model.GT since your setup is similar what would you go with, the pulley or TB in my case?
then down the road upgrade to a 180 pulley etc.
Just a thought
Are the intakes really that restrictive? There are 55k cars making over 500bhp with stock boxes.
I cant get over the low boost #, anyone have boost reading with a similar combo 168 pulley with stock TB
RPM Boost lbs.
6233 8.655128
