RIP My E55
Rating: Thread Rating: 9 votes, 5.00 average.
Old Jan 3, 2012 | 07:03 PM
  #351
togaclk55's Avatar
CLK55
Accords ain't no joke
Old Jan 3, 2012 | 07:06 PM
  #352
320 dreamer's Avatar
2003 porsche 996 turbo
Originally Posted by Johncy2000
O ya ima start saving immediately. Heads, cams, Weistec supercharger, FUEL RAIL, and supercharger clutch pulley.
if your going to rebuild the engine and go for huge power i have a suggestion. find a builder whether its TTM or motorwerks or shardul or someone else and sit down with them and lay out a game plan on paper. parts cost and time of the build are all important. what are your realistic expectations, and balance the cost vs the return. before you drop a single penny spend a large amount of time RESEARCHING what you will want to build. its easy to throw parts at an engine, harder to build a tight well balanced high hp engine that will last. good luck
Old Jan 3, 2012 | 07:07 PM
  #353
thay are if they are lining up against me
Old Jan 3, 2012 | 08:04 PM
  #354
novae500's Avatar
W211
Don't waste $$$ modding the Honda. Any $$$ spent can go towards the e55 engine/parts
Old Jan 3, 2012 | 08:23 PM
  #355
RedBullJnky's Avatar
you to Hate
This is great advise Johncy. This is what you need to look into IMO. Good luck either way bro. I hope you make this sucker as strong as can be.
Old Jan 3, 2012 | 08:37 PM
  #356
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Johncy, Real sorry to hear about the kaboom. Mine went 11 weeks ago and I see my broken CL in the garage everyday. Like Jack said, just a motor and they will go back together better than every! I am working with the best around to get a super built bottom end for my car and a few others that are in need like us..
Based on your description, you blew a piston or two and blow-by came out our PCV lines/air box and into your engine bay. These cars are real hard to blow head gaskets on (antifreeze vapor).
Don`t beat yourself up over hitting the rev limitor, that is normal and should not damage a motor that is set up right. We all hit it one time or another, and if that was bad, we would all blow up daily! I would say your pistons went at peak load , around 4500 rpm, just a few seconds before you hit the rev limitor.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Jan 3, 2012 | 08:39 PM
  #357
honeyboy9731's Avatar
MBW
Could it be just a blown headgasket? Anyways right now as my car sits in my driveway, I am very scared to start her.
Old Jan 3, 2012 | 10:01 PM
  #358
BlownV8's Avatar
E55, GLS450, GL63, GLE350
So do you guys think I would be spending more money rebuilding my engine or replacing the whole thing?
You will spend way more rebuilding if you have a damaged sleeve. Just replace with a good engine and be on your way.
Old Jan 4, 2012 | 04:43 AM
  #359
Johncy2000's Avatar
2019 GLS63 AMG Diamond White
Thanks for the advise bro. I already have a plan up my sleeve. It will be a beast of an engine.
I need my Rotas!!
Thanks for the advice bro! I hope my block isnt damaged. Do I have to open her up to find out the damage or is there a test I can do?
I need more info on the damage done to my engine to consider a new engine. We'll see.
Old Jan 4, 2012 | 02:02 PM
  #360
Quadcammer's Avatar
96 and 08 911 turbos
Am I the only one who thinks that this kid shouldn't be saving money to modify his cars with aftermarket superchargers and instead should be saving for the future?
Seems like he has very little of his own money and all his savings will be used for car parts while he lives at home.
Doesn't seem very smart.
Old Jan 4, 2012 | 02:12 PM
  #361
Johncy2000's Avatar
True. I should be saving for the future. But I have devoted all my savings to my car. Its just the way it is. I am very greatful for everything that has been given to me.
Old Jan 4, 2012 | 02:16 PM
  #362
urbamworm's Avatar
05 White Pano E55, Cadillac CTS-V
Screw the future, live it up today, tomorrow is not promised to any of us!
I do seriously feel a little this way though because I have 5 or 6 friends who are no longer around that were my age and grew up with and I am only 29 years old now and they started dieing off several years ago. I always tell myself don't stress to much over stuff and enjoy today because who knows what tomorrow may bring. Money doesn't do a lot of good when you are 6 feet under. I would of course save money too, but certainly would not miss out on things just to save money that I may not ever get to use down the road. LIVE LIFE TO THE FULLEST!
Old Jan 4, 2012 | 02:18 PM
  #363
Johncy2000's Avatar
Originally Posted by urbamworm
Screw the future, live it up today, tomorrow is not promissed to any of us!
This!
Old Jan 4, 2012 | 02:22 PM
  #364
skratch77's Avatar
2005 E55
it might be cheaper to buy a used engine and swap it out.you are going to pay an indy about 1k just to tell you whats wrong with your engine.
there is an easy 10+ hours in labor into taking that beast apart to tell you how bad your blew it up.
see if you can buy that used engine in the for sale adds and just drop her in.lower boost to a 168 pulley and enjoy the car.
the bill will start to add up real fast once you have an indy start taking her apart.
Its different if the guy was doing the work but talking this to an indy to tell him whats wrong when we pretty much know what he did is a waste of money.
you might need a new block if the piston ripped the walls apart when it went also.
Old Jan 4, 2012 | 02:32 PM
  #365
Johncy2000's Avatar
So I have to rip the engine open to find out if the block is okay? Or are there some tests that can be done?
Old Jan 4, 2012 | 02:41 PM
  #366
skratch77's Avatar
2005 E55
I think they can put a camera in there to see.Did you talk to any local indys of what and see what options they give ya?
tell them you think you blew up a few pistons and need to find out if the block is okay and see what they weill chage to find out.
I just dont want to see you go down the road of paying an indy to fix it step by step and try to find out how much to get her running total up front from the indy.
Trust me they want the work and explain to him your situation.remember if you buy a used engine you can get back some money parting your old engine.
like the surge tanks for people that want to paint there,tb,stock pulley and the whole blower could get you 1500 bucks if you find a buyer that needs a new blower.
Old Jan 4, 2012 | 02:47 PM
  #367
nanayaw6's Avatar
2006 E55, 2006 saab 93 aero, 2010 glk 4m
..........remember if you buy a used engine you can get back some money parting your old engine.
This
Old Jan 4, 2012 | 02:52 PM
  #368
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
IMO with a used engine you have not solved the problem, with all the mods not being changed it can blow up too
Old Jan 4, 2012 | 02:58 PM
  #369
skratch77's Avatar
2005 E55
Im pretty sure you can part your old crank also.im sure gtr would consider it from his keyway ordeal he went threw.
He would need to fix the issue that did this in the first place even if he rebuilds his engine.
Old Jan 4, 2012 | 03:01 PM
  #370
urbamworm's Avatar
He has stock injectors, sounds like an easy fix, get some bigger injectors to properly fuel the car.
Old Jan 4, 2012 | 03:03 PM
  #371
Johncy2000's Avatar
Do you guys think I should sell my 82mm TB and TTM Fuel Rail kit for some extra cash or should I save them for when my rebuilt engine is done?
Old Jan 4, 2012 | 03:19 PM
  #372
shardul's Avatar
LOL if you say so. The amount of blown E55 engines with supporting cooling / safety mods I have seen
here is pic of a piston from the latest blown motor.
Old Jan 4, 2012 | 03:20 PM
  #373
55fanatic's Avatar
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
keep them, buy a used engine, install used engine, injectors and fuel rail, drive it, part broken engine
Old Jan 4, 2012 | 03:40 PM
  #374
shardul's Avatar
i have 4 cranks if anyone is interested
Old Jan 4, 2012 | 03:55 PM
  #375
urbamworm's Avatar
It is no secret that the stock injectors go static with 180mm pulley and the basic bolt ons which he has, so why wouldn't running larger properly sized injectors for the power level fix this? It does fix it, because many people are running bigger injectors and don't have a problem.
You aren't showing a piston from Exotics engine are you? One that is like comparing apples to grapes considering the difference that car had compared to the norm. And don't forget the tuning issues it had not being able to adjust when things were changed in the tune. That clearly is a problem right there which a run of the mill 180mm pulley bolt on car doesn't have
Lets stay real here.
You have already rated this thread Rating: Thread Rating: 9 votes, 5.00 average.
