RIP My E55
You have a very solid list of mods except the most important which reviewing prior blown motors on this forum subsection appears to be larger injectors. This seems to be a must on a mod'd engine but one that is generally skipped as it is more of a safety item vs. increasing HP (though yes, some state otherwise).
Guess this just proves again the importance of larger injectors-even for #8. Very curious what you find once you pull the heads. Please take solid photos for everyone to view.
You planning on tearing it apart yourself? Pretty easy motor to work on.
Good thing is, when you are done, you will have a better condition motor.
https://mbworld.org/forums/w211-amg/...fuel-rail.html
Cars can be rebuilt. Good thing nothing happened to you during the race.
Why not let the computer make the 3-4 instead of doing it manually? Considering I also run the TCU tune it's way faster when you don't have human error guessing at when to shift.
Also the rev limiter "which I thought was or is engine controlled is different than the shift point you can bounce off the rev limiter and not hit your shift point under full throttle. Please correct me if I am wrong.
Why learn from the past and mistakes of others when we can speculate!
I'm sure EC meant for owners to bounce off the limiter at 130 in cold weather. Right?
TTM rail and injectors will be on my car when I install my pulley/tune. I believe in the safety items first.
I never run in M mode while doing straight line accel runs, only when carving twisties, since I normally am not near redline when doing it. To each his own though
Regardless, John-I am very sorry for what's happened and I hope the damage is as minimal as possible. It always makes me sick to read these threads. I love my car too (my fiance says more than her
) and know you must be hating it. As all others have said, you're ok, and it's just an engine in the end. You'll bring her back stronger, and with the proper fueling mods in place. Good luck and update with results. https://mbworld.org/forums/w211-amg/...fuel-rail.html
Do you have a data logging set up on your car? You have a lot of mods and just larger injectors?
FYI: The TTM Fuel Rail for the M113 and M112 have a provisional patent on both of them.
