Will LSD helps?
I am thinking that should I get LSD or change to 172 pulley, which benefit more ?
What size pulley do you have now? A bigger one will make you spin the tires more easily. A LSD would help, but a good tire may be all you need. Do you drive this car every day? In rain or snow? How many miles or km do you put on the car in a year?
On the 600/65 It depends on how you define traction. On the street there isnt anything thats going to give you more "traction" as defined by "make u spin less", unless you go to a stickier tire. With the amount of torque that these cars put down, nothing is going to help except a tire. On the street you should be able to lay a straight patch from the line, with out a one wheel burnout, that means an LSD isnt going to help you on the street.
OK now onto the strip. With sticky tires, while trying to do a burnout, it is IMPERATIVE that you make sure both wheels are spinning. If you hear a loud hum STOP. Multiple "one wheel burnouts" will grenade your rearend. Yes my rear popped but it was from the burnout procedure. The last 2 years of racing I had a spotter just to make sure both would spin in the water box. Now an LSD will cure this problem of a one wheel burnout and will save your rear. But it will not equate to a better 60ft or out of the hole traction, I hope this helps!
As far as the street the car feels as if it never spins both tires at either slow or faster speeds. My experience with other cars has always been that the back of the car would get sideways if you had a LSD assuming you were forcing the tires to break loose. To me the CL feels as if no matter what only one tire spins and the other 3 keep the car heading straight (this is driving with ESP off). I'm not expecting WOT from low speeds and no spin on the streets, just some better traction under 45 mph. I thought an LSD may give me a fighting chance but it seems your suggesting otherwise.
My next mod will either be this, fuel rails, TB or scoops tubes. Decisions, decisions!
