Quick question about the crash bolts
Where exactly do they get installed? Control arm to front subframe? Steering knuckle to control arm? Also, are 1 or 2 used per side? ![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
P.S. A0003300018 are the right bolts, correct? I believe I found that number in another thread.
To my credit, I did spend some time with the search function before posting, so hopefully I didn't miss this info.
![Embarrassment](https://mbworld.org/forums/images/smilies/redface.gif)
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
The castor & camber fluted 3 way bolts consist of 2 in the caster or thrust arm bushes & 2 in the camber bushes.
![](https://mbworld.org/forums/attachments/c-class-w203/59065d1124825912-installing-front-camber-castor-bolts-thrust-arm-bushings-possible-diy-img_0259.jpg)
![](https://mbworld.org/forums/attachments/c-class-w203/59102d1124858869-installing-front-camber-castor-bolts-thrust-arm-bushings-possible-diy-camber_bolt_install_1_2.jpg)
![](https://mbworld.org/forums/attachments/c-class-w203/59103d1124858869-installing-front-camber-castor-bolts-thrust-arm-bushings-possible-diy-camber_bolt_install_2_2.jpg)
E55, CTS-V Wagon, Duc 1098R
To my credit, I did spend some time with the search function before posting, so hopefully I didn't miss this info.![Embarrassment](https://mbworld.org/forums/images/smilies/redface.gif)
Super Moderator
Remember to tighten the bolts with the suspension loaded or you can herniate the bushes. Remember to hold static bolt while tightening nut so as not to damage bush insert.
Super Moderator
The KMAC eccentric kit is a nice concept if you want to take suspension out of spec & dial in extra negative camber etc. If you want a standard set up they are no good because the eccentrics move the attachment points in multiple plains.
For a street car ??? What are you trying to do - make the car look good, setup for autox, or handle better at high speeds ? Remember if you put too much negative camber, your tire wear will be awful, plus on a street car I doubt you would notice any gains or benefits. I always recommend you keep the alignment within the factory specifications.
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Yes, but if you choose to do so, you can still set the parameters to factory specs. Regardless, the polyurethane KMAC bushings do provide for a noticeable reduction in suspension wiggle.
I personally spend some time and money on the drive train, lighter and wider wheels, lighter rotors, LSD, STAR drop and KMac bushing with a proper, factory spec alignment, and the car handling is transformed...
