82mm t/b install??
Old Jul 12, 2012 | 12:00 PM
305-E55's Avatar
2017 Charger Hellcat
82mm t/b install??
Installing a 82mm t/b,not sure where the two vent hoses go that are from the back of the valve cover gaskets to the stock t/b..The t/b that is being istalled does not have a place for those two hoses,what do we do??
Thanks,
Miguel
Old Jul 12, 2012 | 12:03 PM
jcjmw's Avatar
2005 E55 Wagon
Thanks,
Miguel
The 2 small hoses (one for each side of the back of the valve covers) go into a T that connects to TB. Your 82TB should have nipple to which the T will connect.
03'55AMG's Avatar
AMG
+1, there should be a spot if its a MB TB
Old Jul 12, 2012 | 12:19 PM
305-E55's Avatar
Thank you!!
Old Jul 12, 2012 | 12:35 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
The bosch tbs don't have the inlet, you can just vent the 2 tubes to the atmosphere, just put a small breather filter at the end of them.
Now if you still want to connect it to the tb, drill and tap a hole in the tb after the butterfly and put a threaded brass barb fitting
Old Jul 12, 2012 | 12:51 PM
Bramage's Avatar
F-250
Agreed. Some of the compatible Bosch TB's do not have the breather connection. I would vent to atmosphere, as Shardul said, using a small filter to catch oil, and prevent sucking in dust, dirt, bees
Good luck with install
Old Jul 12, 2012 | 01:36 PM
jcjmw's Avatar
2005 E55 Wagon
Sorry for this stupid question, but if you put a breather on those 2 small tubs from the valve covers and it vents out to the atmosphere...wouldnt smoke come out of the vents?
Old Jul 12, 2012 | 02:33 PM
shardul's Avatar
The breather filter traps some off the oil vapors and you use some longer rubber piping and divert them towards the bottom of the car
Old Jul 12, 2012 | 07:42 PM
305-E55's Avatar
This is what we did,thanks!!
Old Jul 12, 2012 | 11:03 PM
FT-Performance's Avatar
FTP-E55///AMG
Called you back and LVM for you this afternoon, Let us know if you have any other questions Miguel!
Old Jul 13, 2012 | 12:17 AM
jcjmw's Avatar
2005 E55 Wagon
If possible, can u post a pic of what u did?
