did the split today.
Old Feb 26, 2013 | 11:18 AM
  #76
cij911's Avatar
one car at a time
If you are using a reservoir without an inlet and outlet, your setup is less than optimal. Obviously the bigger the reservoir the better....
Old Feb 26, 2013 | 06:16 PM
  #77
SilverStrk's Avatar
05 E55, 07 ML500
Mine is being done as we speak, using the BMW power steering tank...
Old Feb 26, 2013 | 07:36 PM
  #78
Driftvs's Avatar
03 E55, HB Torana
Does your BMW power steering res have a breather hole in the cap?
Old Feb 26, 2013 | 07:37 PM
  #79
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Have you been loggin IATs?
Old Feb 26, 2013 | 08:28 PM
  #80
cij911's Avatar
one car at a time
I have tons of logs before and after the split (using the Cobra reservoir)....I will post some data later if you want. Although there were improvements with the small reservoir, a larger reservoir would be better, especially if the ambient temperature is hot and/or you are doing long and repeated pulls.
Old Feb 26, 2013 | 08:49 PM
  #81
AKnight55's Avatar
That would be great, thanks.. I hear what you are saying, but I dont really want to go with a trunk tank, and im not confident in the FTP engine bay tank as it seems like it isnt a complete kit from what ive heard.
Old Feb 26, 2013 | 09:53 PM
  #82
E55amg/FD3S's Avatar
03 e55
The FTP engine bay reservoir I purchased and received came with everything needed for the install. Only small problem I noticed was the filler lid was leaking a little fluid. A little RTV solved the problem.
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
