Official Weistec M113K 3.0L Supercharger, PICTURES INSIDE!!!
Old Dec 22, 2012 | 04:57 PM
  #501
Gadget's Avatar
06 E55 AMG, 13 C63 AMG
Just got back from putting about 80 miles on it.
Reading the manifold pressure through a scan tool, hits 17.2 PSI right at redline in 3rd.
The car is a powerhouse for sure. I need to find enough road to let it stretch its legs.
Anyone have the procedure for replacing the fuel filter and fuel pump? Might be a good thing to do as the demand for fuel it going up.
G
Old Dec 22, 2012 | 05:04 PM
  #502
e55amgrocket's Avatar
Dirt Scooters
There's plenty of roads down by me Right now most of them have a few hundred thousand cars on them but i know of a perfect straight stretch out of the way. I've done a 182mph (garmon GPS lol) pull there and she was still pulling when i let off. Can't wait to see that thing in person
Old Dec 22, 2012 | 05:13 PM
  #503
Gadget's Avatar
I try to boycott Virginia as much as I can.
I was coming home from a meet in Va Beach at about 0200 up 295. The only car on the road with a 70 MPH speed limit. Got pulled over and charged with reckless driving because I was doing 81 MPH. Yep, simply doing 11 MPH over the posted speed is reckless, a jailable offense. I had to hire a lawyer and had to eat the points because I have a Class A CDL from my fireman days. So, in general I will do everything I can not to spend a dime in VA. The troopers there are just asses. They love writing other police officers.
G
Old Dec 22, 2012 | 06:01 PM
  #504
Tech-Tune's Avatar
2006 CLS55 & 2002 SL55 (R129) Silver Arrow
Now that the blower is clutch-less, how did Weistec fool the ECU into believing its still there.
What did you do to the harness that plugs into the SC clutch?
Old Dec 22, 2012 | 06:44 PM
  #505
Gadget's Avatar
They give you a resistor that gets wired into the clutch harness.
G
Old Dec 22, 2012 | 10:18 PM
  #506
Forrest Gump 9's Avatar
shrimp boat
I'm with you on staying away from VA. They got a brand spanking new V1 from me.
G
G
That's what I thought. Any info/pic of the resistor?
Old Dec 22, 2012 | 10:22 PM
  #507
kustom2k1's Avatar
03SL55
So the SC never shuts down, what happens if your IATs go too high? Does it use the bypass valve.
Old Dec 22, 2012 | 10:37 PM
  #508
Gadget's Avatar
I do not know if they programmed any engine safeguard logic in the ECU to open the bypass valve if things are not right or not. Not likely. If the ECU was not designed for features like that it is not something that can be added.
I did not take many pictures at all, but here are the few I did of the install:
The resistor jumper is that wire thing in the plastic box with the two blue T Taps. It gets tapped into the clutch harness.
The overall installation is very easy. I had it done in a couple of hours and was waiting on the ECU to come back.
Should not be considered part of the installation is reinstalling the stock crank pulley. The pulley is a snap. I do have the MB pulley holding tool. It took more time to wrestle the fan out than to do the pulley.
The stock supercharger comes right off very fast and you simply lay the new one in place and bolt it down. You do have to transfer the bypass valve to the new assembly and install the inlet on top of it before you place the assembly on the engine. In the picture above of the bypass valve you can see the stock MAP sensor. Just under the bypass valve and to the left in the picture is where the stock IAT is installed.
You do have to tap one hole in the front of the engine with an M8x1.25 tap that you will need to have. This converts a blank hole to accept one of the three mounting points for the pulley plate.
I am telling you, this is a very simple installation.
G
Old Dec 22, 2012 | 10:47 PM
  #509
Blk04e55's Avatar
2004 E55 AMG
Nice work dude
Old Dec 22, 2012 | 10:53 PM
  #510
kustom2k1's Avatar
03SL55
Should be fun finding a way to run the intake to the front of the engine.
Old Dec 22, 2012 | 11:04 PM
  #511
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Any plans to hit the 1/4 mile?
Old Dec 22, 2012 | 11:54 PM
  #512
blackbenzz's Avatar
haters crazy
G
Smart man
Old Dec 23, 2012 | 03:34 AM
  #513
Das Geld 2's Avatar
SL55, S500
So what's it run?
Comparison vs stock?
Old Dec 23, 2012 | 06:03 AM
  #514
blackbenzz's Avatar
haters crazy
Originally Posted by Das Geld 2
So what's it run?
Tracks are closed
Old Dec 23, 2012 | 07:00 AM
  #515
PACougar's Avatar
1000Hp Diesel Trucks, 2019 E63s
Originally Posted by blackbenzz
Tracks are closed
Not all tracks are closed, move to a warmer climate.
Old Dec 23, 2012 | 09:16 AM
  #516
blackbenzz's Avatar
haters crazy
I was just saying the tracks around us are closed. Are they open in sac?
Old Dec 23, 2012 | 10:36 AM
  #517
Hammer Down's Avatar
2015 E63S, 2018 E63S
Yes
Old Dec 23, 2012 | 11:03 AM
  #518
berti_00's Avatar
2016 Cls63s AMG
sucks that you lose the look of the engine covers... and that bigg a$$ filter laying right on top of the header sucking some hot lovely air... S/C it selfs looks the **** thooo
Old Dec 23, 2012 | 11:05 AM
  #519
blackbenzz's Avatar
haters crazy
Originally Posted by Hammer Down
Yes
Nice! Lets see some track times pacougar
Old Dec 23, 2012 | 01:46 PM
  #520
badm's Avatar
2019 E 450 4 matic wagon, cadilliac CTS AWD performance ,2018 VW Tiguan SUV 2006 CLS55 030pkg modded
Air intake
I agreed that air intake or HOT AIR INTAKE has got to go. They have to come up with something different . Maybe modifiy old intake tubes or CF tube combination will work to reach the radiator outlets... That has got to be costing hp sucking in hot air ..
Old Dec 23, 2012 | 03:14 PM
  #521
Worth the wait's Avatar
2006 E55
I have a sneaking suspicion that gadget is already working on a CAI for his car.
Old Dec 23, 2012 | 03:20 PM
  #522
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Should cost around 1% hp for every 10 degrees. Yes, not the most ideal location.
Old Dec 23, 2012 | 08:20 PM
  #523
Gadget's Avatar
Wheel spin all the way through 2nd....
Old Dec 23, 2012 | 08:36 PM
  #524
PACougar's Avatar
It keeps raining on Saturday Hopefully next Saturday will be the lucky day.
Old Dec 23, 2012 | 09:05 PM
  #525
hpV12's Avatar
Audi A4
That looks like fun. What other mods do you have?
You have already rated this thread Rating: Thread Rating: 13 votes, 4.69 average.
