Trouble With Emmissions in AZ - Calling All Those That Have Floorfabbed LTH
Really need your help here as I've been working on this for about 3 weeks now but still can't get it resolved and my tags/smog is due 11/15. I'd love to hear from you that have Floor Fabb'ed Long Tube Headers from the group by about 2 years ago.
Here's the key issue:
I continue to throw two ECU codes below which trigger the CEL. The CEL and the codes will of course prevent me from passing emissions.
- P0135 is: O2 sensor heater circuit malfunction Bank 1, sensor 1
- P0155 is: O2 sensor heater circuit malfunction Bank 2, sensor 1
- Sent ECU to Cory at Kleemann who did a full ECU tune/reflash as well as modified the chip that deals with emissions. Even after this both codes and CEL resurfaced. Cory is a complete rockstar by the way.
- Went to Vivid Racing in Gilbert AZ last week who looked at all the wiring, headers and eveything looked good from a visual standpoint. (So no wires were broken, split, frayed, put in incorrectly) and they couldn't tell what the issue was.
- Yesterday I went to DynoComp in Scottsdale who know E55's quite well and had them completley re-do the entire wiring harness, resoldering, reinstulating and checking all wiring. They cleared the codes and CEL, but within an hour of driving home, both resurfaced. (Codes & CEL)
Honestly guys I'm totally out of ideas and would love to hear from those of you that have the FF LTH. I have 15 days to get this fixed but would hate to have to put it back to stock (I didn't save the stock components stupidly) or spend $2,500 on new set of headers that don't have a design flaw.
If any of you are local in AZ and help me pass smog I will buy you more beers than you can handle!
Thanks you VERY much in advance!
Alex
As far as I know, Mikey doesn't throw any codes. I would also be interested in people's input here.
Seriously if you local guys can help me figure this out, I am totally buying drinks for all of you!
Thanks!
Alex
By looking at those codes I would say you either have faulty O2 sensors or there is a problem with the wiring harness going to those sensors. There is no other logical explanation. Also are you 100% sure that the plugs are not switched for the front and rear ones?
I'm not as technical as you many of you are so this helps immensely!
Alex
Thanks!
Alex
I wonder what counts as a driving cycle?
Thanks.
Alex
Oh and the ECU Tune he gave me...it's off the chain powerful...I'm talking like Holy $&^%# when I hit the gas now.
(Nothing against EC mind you, just sharing my person opinion/experience thus far.)
Solutions are this:
1) Wrap headers resulting in a hotter stream-this worked for some people. I take it these are not coated?
2) New O2 sensors as yours are used and not as 'sensitive'. This 'might' resolve the issue.
3) Relocate the o2 bung closer if possible.
4) If a tune allows, increase the delay for the O2 signal as it gets hotter, or possibly increase the voltage is possible. I know on some makes you can do this, unsure on this one. If not see 1-3 above.
Best of luck.
Have you run leaded race gas through the car? If so you should replace them since only time I have seen this code once the ECU has been ruled out is bad sensors, race gas fouling them, or in some cars there is a relay that drives the heater element. I don't think we have a relay but I haven't checked.
Solutions are this:
Best of luck.
Thank you all again, very, very much. Seriously if I get my car to pass, you local AZ peeps are joining me at a local Hooters (I've never been to one if you can believe that) and I'm buying everyone drinks and food! It will be my, "Alex Passed Emissions Party!"
Thank you all!
Alex
Alex
Once I completed those two tasks, all was well, and never got a CEL after that.
Thanks again.
Alex
If this fixes it I'll take it to emmissions, then post the results here.
You've all been immensely helpful to me so I will post in detail the solution I found.
Thanks again!
Alex
Quick question though how do you like your '06 CLS55? I'm at 82K miles now so starting to look at my next AMG.
