Fuel pump assembly??
Rating: Thread Rating: 2 votes, 5.00 average.
Old Nov 9, 2012 | 04:34 PM
Forrest Gump 9's Avatar
shrimp boat
Long story short, I have a friend who is into building turbo kits for mustangs. I asked him about our fuel pump assembly situation and he said he can made a billet unit for our car. I told him when the winter time come around I'll tear my car up and let him borrow the fuel pump assembly. Anyway, he's been bugging me for the last two week (apparently mustang business is also affected by the election too ).
So anyone had replace the stock fuel pump assembly and have the stock old bad one and want to sell. I'll take it and hopefully he can do something with it. Thanks!!
Old Nov 9, 2012 | 04:53 PM
Ronan Mc Cabe's Avatar
Gone but not Forgotten 2006 E55 Renntech
You do know that ultimately it is the tank (and evap tube) that fail and not just the sending unit (or pump assembly)...right
Old Nov 9, 2012 | 05:41 PM
PACougar's Avatar
1000Hp Diesel Trucks, 2019 E63s
David, is he going to have to damage or ruin the pump assembly? If not I have a brand new one I'll send out to you if you can return it when he's done.
Old Nov 9, 2012 | 06:46 PM
shrimp boat
I'm sure he will have to dis-assembly it. All the connections will be billet and aluminum. So, yes it will take care of the fragile plastic ones.
Old Nov 9, 2012 | 07:38 PM
PACougar's Avatar
As long as it it is in working order when I get it back then it's all yours! PM your address.
Old Nov 9, 2012 | 08:37 PM
GT-ER's Avatar
2005 E55 AMG
Has anyone even maxed out the oem pump?
Old Nov 9, 2012 | 09:51 PM
e55amgrocket's Avatar
Dirt Scooters
I haven't that I know of but that was just a 4-5 second dyno run with a decent shot of nitrous. AFR was 10.1-10.7 the entire run so fuel pumps were keeping up.
Old Nov 9, 2012 | 10:02 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Sneaky neon removed his pumps, put duel 044 bosch pumps and duel 8an lines as I recall. Good to David working on fuel pumps, as better to not see where the limits are real time.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Nov 9, 2012 | 10:41 PM
shrimp boat
This is not a performance upgrade, but more of a reliability upgrade. Hopefully with this we, the E55 owners, can finally fill up the car to the brim.
But this will be easily upgrade to dual pumps or bigger pump if ones desired .
Old Nov 10, 2012 | 07:26 AM
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Do not forget that the pressure regulator is located with the OEM pumps.
Old Nov 12, 2012 | 07:50 PM
sneakyneon's Avatar
Bicycle
No its not.
Old Nov 12, 2012 | 07:51 PM
sneakyneon's Avatar
Bicycle
I did but it was 120k mile pump . I'd bet a fresh pump would keep up fine
Old Nov 12, 2012 | 07:54 PM
GT-ER's Avatar
2005 E55 AMG
Originally Posted by sneakyneon
No its not.
Really? I thought it was. Or is it on the sender in the drivers side?
Old Nov 12, 2012 | 07:58 PM
stockC43's Avatar
65 Chevelle Wagon w/ C5 frame, 08 ML63, 04 S600, 04 E55,(sold) 00 ML55,(sold) 98 C43-55K Swap
If I remember correctly its part of the sender/filter assy.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
