Anyone run a square tire setup? 265 or 275 all around?
I'd like to have a square tire setup so I can rotate front to back. I'm thinking about going 265/35/18 all around on a 18x9 rim with 35mm offset.
Is this doable? Can I squeeze 275/30/18 all around.
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Member Jangy, (years ago) ran OEM rears on the front of his E55, claimed it cleared and helped correct under steer.
Here,
https://mbworld.org/forums/w211-amg/...res-front.html
Here,
I know a guy running rear CLS (19x9.5 et 28) wheels on the front of his E55.
If you're really curious swap your wheels front to back and take a look. Shouldn't be an issue.
Do you think a 265/35/18 on a 18x9.5 et35 will fit on the front?
I think it will work on the fender side, but not sure about the inside
