problem solved...hopefully? Attn: Poursha
2003 E55 W211
I wrote in an earlier post that I was hearing a sweeqing noise from the engine on take off and between 1st and 2nd gear shifts. It turns out that that noise is coming from the belt tensioner....too tight.
It will be replaced by the dealer at no cost of course. I made an appointment on Monday and I will post if all is ok.
Take care all.
Take care all.
Originally posted by JTS
No idea, but when I get there on Monday I will post. Stay tuned..
2003 E55 W211
I do know what you mean. The techs at my dealership recognized the problem immediately. So it sounds like they may have seen this before.
2003 E55 W211
What they told me is that the belt tensioner was causing the pulley to slip and make that squeek. Not sure is he said too tight or too loose. They told me that this happens because real life evryday driving is different from factory testing. They see this often and what they do is just replace the whole unit (tension unit).
Hope this helps. Good Luck
2003 E55 W211
Poursha,
Went to pick up my car and my service consultant had left for the day. he told me the problem was fixed. However...problem is not fixed...still same noise. I left a message for him so I will find out more tomorrow. I have attached the work order but it must be something else...
Poursha,
Poursha,
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
2003 E55 W211
Its unbelievable.... Oh well the next available appointment is in 3 weeks..we will see.
let me know what happened with yours.
