Put the gates HD 505 belt on tonight...
Old Aug 26, 2013 | 12:12 AM
  #51
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
My s/c clutch bearing was replaced under my extended warranty at about 50-55k miles.
Old Aug 27, 2013 | 02:57 PM
  #52
rchase's Avatar
2004 E55 (sold) 2012 E350 4M
Any idea why my belt doesn't wrap around my S/C as well as your does. I have the exact same belt with the smaller S/C pulley.... Getting it on was pretty hard it barely slipped over the pulley.
Old Aug 27, 2013 | 03:08 PM
  #53
Critter's Avatar
07 E63 + 07 CLK63CAB
With a smaller sc pulley you have less surface area of the belt in contact with the pulley. The idler is in the same position on both cars so the belt is angled more on yours, also if you have changed your crank pulley to a larger size this will affect the ability to use a smaller length belt. By the sound of your explanation you are running out of tension adjustment by using the shorter belt, is this correct? The small sc pulleys would do a better job with the two pulley belt wrap from a fellow on the net, Shardul I believe is the guy to speak with.
Old Aug 27, 2013 | 03:52 PM
  #54
rchase's Avatar
If you look at Todd's though... Same mods and his comes straight down off the left side. I don't have a crank pulley. Just the sc pulley
Old Aug 27, 2013 | 04:03 PM
  #55
Toadster's Avatar
2005 E55 AMG
Anyone have a good lead on s/c bearings? eBay ones are $80
Old Aug 27, 2013 | 06:46 PM
  #56
rchase's Avatar
Todd you have any idea why my belt looks different then yours? It's the exact same one... Do you have a crank pulley? I'm pretty sure we have the same mods.
Old Aug 28, 2013 | 07:33 AM
  #57
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Originally Posted by berti_00
that belt looks pretty until it gets dirty and tood i cant believe you still don't have the idler pulley kit
ASP's use "Z" rated bearings.
Also, I have been using Goodyear Gator-Back belts with excellent results. They have better grip qualities. Roush uses them exclusively.
Old Aug 28, 2013 | 10:55 AM
  #58
HeissRod's Avatar
Originally Posted by AgSilver
Rausch uses them exclusively.
Do you mean Roush?
Old Aug 28, 2013 | 11:03 AM
  #59
Toadster's Avatar
2005 E55 AMG
Post a pic of yours?
Old Aug 28, 2013 | 11:04 AM
  #60
Toadster's Avatar
2005 E55 AMG
Post a pic of yours? I have a stock crank pulley
Old Aug 28, 2013 | 11:17 AM
  #61
HeissRod's Avatar
See post #52
Old Aug 28, 2013 | 12:15 PM
  #62
Toadster's Avatar
2005 E55 AMG
http://bearingsdirect.com/45BG07S5DL...-45x75x32.html
$38 for a new s/c bearing and only $5 shipping - dang that's a good price!
$44.78 shipped!
Old Aug 28, 2013 | 12:18 PM
  #63
Critter's Avatar
Do not forget to give the idlers a test spin with your finger, chances are they are due also.
Old Aug 28, 2013 | 12:27 PM
  #64
Critter's Avatar
Looks like Nachi bearings is the bearing of choice, the one you ordered is it speed rated and load rated for the use you are going to be using it for?
Old Aug 28, 2013 | 12:31 PM
  #65
Toadster's Avatar
2005 E55 AMG
it's the OEM replacement
Old Aug 28, 2013 | 05:05 PM
  #66
rchase's Avatar
I posted a pic above. post #52
Old Aug 28, 2013 | 05:28 PM
  #67
AgSilver's Avatar
Originally Posted by HeissRod
Do you mean Roush?
Sorry about the typo
Old Aug 28, 2013 | 05:52 PM
  #68
Critter's Avatar
The only reason the belt would look different is that your pulley is smaller in diameter than Toadsters' and the belt wrap would be less with a smaller dia pulley. It is common knowledge that when you change something that is engineered you inadvertently change something else. (Normal pulley OEM size= maximum belt wrap as designed) .
I see little dif in the two setups so the variance is small, get a belt wrap kit, this should solve any issues if you have concerns.
Old Aug 28, 2013 | 06:38 PM
  #69
rchase's Avatar
Todd and I have the exact same mods, both have the SC Pulley and the smaller belt, the exact same belt.... This is why it is odd to me.
Old Aug 28, 2013 | 07:07 PM
  #70
Critter's Avatar
angle of the picture?
Old Aug 28, 2013 | 07:29 PM
  #71
HeissRod's Avatar
No worries. I honestly didn't know if there was a tuner I hadn't heard of.
Old Aug 29, 2013 | 12:41 AM
  #72
Toadster's Avatar
2005 E55 AMG
See post #52
I don't see a huge difference... but I see a little more angle on yours - what length belt are you running? 505? 510? 496?
Attachment 447808
Old Aug 29, 2013 | 01:49 AM
  #73
HeissRod's Avatar
His tensioner pulley is farther to the left than yours.
Old Aug 29, 2013 | 02:12 AM
  #74
rchase's Avatar
well... i thought it was the 505... that is what i ordered, they sent me the wrong belt after finally finding the package. got it swapped out and am good to go.
Old Aug 29, 2013 | 10:30 AM
  #75
AMG E Power's Avatar
E55 amg
I thought u run the stock size belt on the smaller pulley ?
