Quote:
slightly smaller pulley with a smaller belt will help keep the angles setup properly - although, the best method is to go with the belt-wrap kit if you want to ensure you don't lose any power to belt slippageOriginally Posted by AMG E Power
I thought u run the stock size belt on the smaller pulley ?
Quote:
yup, i've been running my stock belt for 15k on the smaller pulley - just refreshed my belt (it was due) so I opted for a slightly smaller one...Originally Posted by AMG E Power
gonna install one today with stock belt, will I be ok ?
it's only 1/2" shorter, not a huge deal
Is it better to have the belt tighter (50.5") or have more surface area contacting the pulley (51")?
Quote:
it's better to have more surface area - check the pics in post #72Originally Posted by BagMan
https://mbworld.org/forums/5763296-post72.html
IMHO I have more surface area on my belt in comparison to the other belt - not sure what size that one was - see the angle difference?
rchase - what size belt was that one?
It was the 496.... I had it swapped out for the 505.
Originally Posted by Toadster
it's better to have more surface area - check the pics in post #72https://mbworld.org/forums/5763296-post72.html
Quote:
I honestly don't know the difference but it is the HD that I haveOriginally Posted by Redw20855amg
so is the K080505HD or K080505 green?
Explore505??? That is to small, you must be missing the belt wrap kit
Quote:
HD is all green, regular is black with green stripeOriginally Posted by Redw20855amg
Ordered my HD Today and a continental OEM Drive Belt from another member here :thumbsup
So is stock Gates K080510HD or Gates K080505HD?
(i.e., stock crank pulley/stock SC pulley/no belt wrap kit)
Toad - Your thread says:
Gates K080505HD V-Belt - close to OEM size $25
Want to confirm before I order, thanks!
Stock belt is 50.74"Originally Posted by GunMoto
So is stock Gates K080510HD or Gates K080505HD?(i.e., stock crank pulley/stock SC pulley/no belt wrap kit)
I have stock pulleys and I think I'm going with a 510. My logic is that the longer belt will allow more belt surface area to be in contact with the SC pulley.
Could be totally wrong though and maybe the higher tension of the shorter 505 belt is better.
Anybody want to chime in?
Quote:
From the Gates website:Originally Posted by Toadster
- K080505HD: 50.49"
- K080510HD: 50.95"
I would think the 505 is the choice to go with.
GunMoto, did you get your belt on yet?
Quote:
Haha, haven't ordered yet...lulz.Originally Posted by BagMan
I just put on a Gates K080496 Green stripe belt. I just got a s/c pulley, the stock belt slides in and out with ease. This belt fits tight as hell.
Quote:
how far do you crank open the tensioner? I felt like I had tons of space to put a belt on - I used an allen wrench to hold the tensioner open Originally Posted by E55AMGGG04
Quote:
I used the 17mm ranch to open the tensioner as far to the left as I could. It was still pretty tight. Of course I'm comparing this to the stock belt size. It still won't take more than a few minutes either way.Originally Posted by Toadster
Quote:
I went with the 505. Definitely the right choice for a stock pulley.Originally Posted by GunMoto
Need to order mine now, lulz. Thanks for the update bro!
Quote:
I'm using the 505 with the 84mm pulley Originally Posted by BagMan
not to thread jack or bring up a old thread but is the same belt used for a cls55? keep being told to check e55 section but this part number doesnt show it works on the cls55, can anyone chime in?
Former Vendor of MBWorld
shardul
close
- Join DateMay 2008
- LocationHouston
iTrader Positive Feedback100
iTrader Feedback Score(1)
- Vehicle(s) I drive2003 W211 E55, 2003 W220 S600
Liked:295 Times in 244 Posts
Quote:
yesOriginally Posted by 06cls55amg
just to re-clarify
OEM size is 51 inches for the S/C belt
belt length is the last 3 digits - so OEM would be a 510 belt (or 51.0")
a shorter belt may be beneficial when using the S/C pulley as it's smaller - so this thread talks about the 505 belt which is 50.5" (so 1/2 inch shorter)
the 496 belt is 49.6" (duh) so it's about 1.4" shorter than the OEM belt
hope this helps!
hope this helps!
