Old Jun 24, 2015, 01:45 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Air Intake and Exhaust Guides
Print Wikipost
90mm Throttle Body install with parts/pics
Old Sep 24, 2013 | 11:27 PM
Denroll's Avatar
'06 E55
Thumbs up 90mm Throttle Body install with parts/pics
It definitely fits, but it's a tight squeeze depending on how you do it. I have not dyno'ed yet, but the ***-dyno tells me it did pick up a really good amount up top. Here's the deets:
First, get a BBK 90mm TB for a 2005-2011 Chrysler Hemi:
Pretty sure you can get it at Jegs. I got mine from ExoticMetal.
Here's a good shot of the part that mates to the Y-pipe. NOTE: My measurement started at the 1" mark on that tape. It's a little over 3.5":
I was able to find a silicone 3.5"-4" boot and was able to snoodle the TB to the Y-pipe. I used a utility knife to trim the boot to make the two parts as close together as possible as there is very little room behind the TB (thanks to the firewall). Two hose clamps ensured an excellent seal.
You will need this connector kit from Chrysler. I got it after convincing the parts guy that their throttle bodies do indeed require a connector. They call it a throttle body plug. Here's what I ordered:
It's a plug with six pre-pinned wires and some extra pins. You don't need the extra pins. This connector requires a special tool to disassemble it. My local Econo Lube N' Tune was able to put the pins in it for me as they had the tool.
The pin numbers are actually inside the connector on the throttle body. They read really weird: bottom to top, left to right (logically). Be sure to read them before you put it on the car. I numbered 1,2,5,6 on the face of the plug with a Sharpie just in case. You will need to splice this connector with the stock Benz cable. You can buy a new one from the dealer for around $100, or you can fully dedicate yourself to the project and use your existing one. The stock one plugs in at the TB and the other end plugs in at the loom down behind the engine. There is enough slack that you can pull the cable up to make it easy to unplug. Gut that beeotch right down the middle and discard the old wire wrap (that black tubing stuff).
Here is what the two plugs on your new cable will look like: MB on the left, Mopar on the right:
There are six wires from each connector that will need to be spliced. The MB plug is numbered at each wire, which makes it easy. Credit goes to Forrest Gump 9 for figuring out the MB to Mopar pinout. It goes:
MB --> Mopar
1-->3
2-->2
3-->6
4-->5
5-->4
6-->1
Since the wires in the Mopar kit are all the same color, I striped each wire to match its pin number. NOTE: put the shrink wrap tubing (included in the kit) on the wires before you make your connections, or you will feel hurr-durr. Unless you don't want to use it. You can solder, use crimp connectors, or the tried-and-true backyard mechanic method of twisting them sum*****es (dang this swear filter!) together and wrapping them in tape. Be sure to double and triple check before you get it all closed up.
Note the stripes I put on there:
Get you some wire tubing/wrap stuff to make it look nice and professional:
Now, for the mounting of the throttle body, you will have to work something out. I have seen two other methods, both different than mine. I am using the OEM (not stock E55) supercharger snout. Mine is hogged out a little to allow for some more airflow. I have a custom machined adapter that tapers from 90mm to 82mm (Thanks, Exotic!).
First, I did a dry run to make sure everything would fit. I used some PermaTex between the snout and the adapter to make a good seal and bolted down the adapter. Then, I used PermaTex between the adapter and TB to make another good seal and bolted the TB to the adapter. NOTE: the bolt holes on the TB do NOT match up to the holes on the snout. Also, the lower two holes on the snout are closer together than the upper two holes.
The other way of doing this is taking the snout (while off the supercharger, obviously) and having it hogged out as much as possible and then mated to the TB either by welding or Elmer's glue (don't use Elmer's).
The silicone boot I had on the TB is really tight. I put it in some hot water for a few minutes to make it soft and pliable to get it on the TB easily. I actually had it on the TB before I mounted it. Make sure the hose clamp will be accessible while TB is mounted.
Then, I had to manhandle the Y-pipe into place. With the adapter making this huge TB even thicker, it means there is very little space between the TB and firewall. If you weld the TB to the snout, you should have a little more room. My airboxes wanted to stay a good inch aft of their normal place. You can get by using the OEM parts, but this setup is just begging for a custom setup. I am using the OEM (not stock E55) Y-pipe and airbox connectors for the 82mm TB until I can get something better going on. I am also considering taking a ball peen hammer to that thin part of the firewall that curves in there at the Y-pipe. It's really crowding the space and doesn't do too much as it is. I've heard some people have used tin snips to clear some space with little to no problems.
Here are the pics:
After you get it all hooked up, perform the throttle body reset:
-Reset ECU with a scan tool.
-Unplug throttle body.
-Turn key to position 2 (right before cranking the engine over) and wait 20 seconds.
-Turn key to position 1 (one click counter-clockwise) and plug in throttle body.
-Turn key to position 2 and wait 3 minutes. You will hear the TB clicking and stuff like that if you keep your mouth shut.
-Start car from position 2.
Going from the 82mm to the 90mm is definitely noticeable and the car pulls even harder up top. If you have a proper intake up to the TB, it should be even more pronounced. Also, my observed fuel economy is up slightly. I mod my car because I am environmentally conscious and eco-friendly, and you should be, too.
Old Sep 24, 2013 | 11:43 PM
marcmaddox's Avatar
2005 E55 AMG, 2012 GL550, 2000 Ford Lightning, 2005 Chevy Silverado 2500HD
Nice write up!
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
Sweet! How soon do you think my break even point would be on the increased mileage?!!?
Old Sep 24, 2013 | 11:54 PM
cm60k's Avatar
Great upgrade bro....,,
Many Thankss for sharing.....
ZAYED,,
Old Sep 25, 2013 | 12:04 AM
justinwrock's Avatar
Ducati
Man, you just really like to snoodle, don't you?
Old Sep 25, 2013 | 12:45 AM
MAN55LE's Avatar
04 E55 AMG
Dude this is great! Thanks for the detailed write up....its funny as **** too.
Old Sep 25, 2013 | 12:48 AM
MAN55LE's Avatar
04 E55 AMG
Do you get the hesitation like the 82mm still? and rough guess on the $ to get this set up in the Beast... 100$ on plug etc...
Old Sep 25, 2013 | 01:19 AM
Denroll's Avatar
'06 E55
Thanks, dudes.
Ummm... 3 tanks of gas? Ha, I might exaggerate a little when I try to justify my mods. But for real, on my drive in to work this morning, from cold start, exiting my garage, sitting at one stop light, and then about 12 miles of highway, I was at an average of 24.4 mpg on the computer. A longer trip might have seen it go higher, too. Disclaimer: I have larger injectors, so this may not be accurate, but I can still use it as a relative measurement and see if something increases or decreases. Doing the heads and the headers also helped when I did them.
Throttle body is ~$450 from Jegs. The plug from Chrysler is about $60. I don't recall how much the snout is off the top of my head, but I want to say it was kinda expensive, around $200 or so. If you get the TB cable from MB, that's almost $100, but that is not needed. The bigger Y-pipe and airbox connectors is also a nice chunk of change, too. Snout and Y-pipe part numbers can be found with a search as they are the same used for the 82mm upgrade. Add a few more bucks for little odds and ends like some nice stainless steel hex bolts, Perma-tex, etc.
Oh, and yes, I still get that forking hiccup! It still happens at the exact same spot on my daily commute. At least I have ruled out the 82mm TB as the cause. It is something else. Maybe getting too choked up with that stock intake.
Old Sep 25, 2013 | 10:04 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Nice job and looks almost stock
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Sep 25, 2013 | 10:24 AM
HeissRod's Avatar
Old Sep 25, 2013 | 11:33 AM
AMG E Power's Avatar
E55 amg
could it be in the tune why ppl get the hiccup ? Ive never heard of anyone with renntech,kleemann ect... having that problem. nice write up, and nice that u are going green with ur mods lol
Old Sep 25, 2013 | 12:26 PM
Roverron's Avatar
ML63
I wish I knew how to get rid of this damn hiccup.
I'm ready to just to go back to a 74
I have a few more things to try before I do that.
Have you guys at EC come up with anything I'm sure you have heard of this issue?
Old Sep 25, 2013 | 01:10 PM
CLKCLK's Avatar
03 C32 gone, 06 CLS55, 16 Tesla X
: I would love to see before/after number? Also is the increasing mpg because you are now running more air (leaner)? Do you log the af ratio? If that is the
case, then it should be retune.
Old Sep 25, 2013 | 01:41 PM
Denroll's Avatar
'06 E55
Yes, I'm logging. I was running a pretty rich mixture before with the meth (actually a little too rich) and this helped out with that.
Old Sep 25, 2013 | 02:58 PM
Pjnash's Avatar
2005 E55
What are you going to do with the 82MM TB?
Old Sep 25, 2013 | 03:11 PM
Denroll's Avatar
'06 E55
Why, I just plan on selling it, that's all... :|
Old Sep 25, 2013 | 03:14 PM
ArmoE55's Avatar
2006 E55
Maybe I'm blind, who did the tune after the install?
NICE WRITEUP!
Old Sep 25, 2013 | 03:16 PM
Pjnash's Avatar
2005 E55
How much do you want for it?
PS that 90mm looks badass
Old Sep 25, 2013 | 03:53 PM
Denroll's Avatar
'06 E55
NICE WRITEUP!
I'm on the EC tune. I'm monitoring my AFR like a hawk. Last time I was at the track on my 82mm, I saw it go as rich as 9.6, so there was plenty of fuel for the 90.
I'l let the bidding start at tree fiddy
Old Sep 25, 2013 | 05:36 PM
E55 amg
Is it a oem Mercedes TB ?
Old Sep 25, 2013 | 05:39 PM
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
Thanks for sharing the details ...
How on earth do you get 24+ mpg? I can't get up to 19! I have 550cc injectors!
You can do mpg adjustment of up to 25% to compensate using DAS.
$60 for a plug? That's robbery.
Hiccup? Some had the theory that the hiccup was due to 82mm Audi TB rotating the opposite way from Mercedes. Does this one open same or opposite way I wonder.
... I was at an average of 24.4 mpg on the computer. ... Disclaimer: I have larger injectors, so this may not be accurate,
... The plug from Chrysler is about $60. ...
Old Sep 25, 2013 | 05:55 PM
Denroll's Avatar
'06 E55
I believe my old one is an Audi unit. I had to swap pins on the connector to make it open the "correct" way.
When I got my car, I never got over 19.x mpg. MBH headers and midsection added a lot. I drove it up to get tuned after installing them (before adding a TB, rail, injectors, etc) and I got around 23mpg driving up to LA. The ported heads with larger valves helped a lot, also.
Old Sep 25, 2013 | 09:35 PM
ArmoE55's Avatar
2006 E55
I hate this thread. It is making want a TB AND HEADERS.
WTF MAN!
Old Sep 25, 2013 | 09:59 PM
BenzoBoi's Avatar
Super Moderator
W221
Nice write up!
Old Sep 25, 2013 | 10:12 PM
Denroll's Avatar
'06 E55
WTF MAN!
Haha, well right now is probably the cheapest you will ever be able to get the MBH headers. Worth it for the sound alone.
