another twin turbo e55 amg is born at BIP
Old Jul 10, 2014 | 03:52 PM
  #276
Joncl's Avatar
E55
Originally Posted by chawkins2001
It is strapped down pretty tight. On one of the runs the car snapped one of the straps on the hit and it almost got ugly. It's not pretty to see that when it is your own sled on there
Thanks so much for all the feedback guys, really appreciate it.
Oh I know bud, I was telling someone else in this thread that the car is not spinning on the rollers that is definitely not the issue as the graph would not look like that.
Do you roll into the throttle or stab it?
Old Jul 10, 2014 | 04:57 PM
  #277
Robert AMG's Avatar
Cls63 & C32
i suggest to return to stock TCU and stock gear ratio.
if u have on the car another TCU, it will not connect clearly with the ECU, and u can verify this with star diag as the tcu will not take coding with the vin/model designation of the car.
Old Jul 14, 2014 | 09:11 AM
  #278
chawkins2001's Avatar
2006 E55 AMG
Update fellas,
We are re-doing the fuel system now to return style. The fuel pressure is dropping during a pull and throwing misfire codes.
The current fuel system is:
1000cc injectors
dual 340lph Division X fuel pumps
modified stock fuel baskets to accept more fuel
brand new sender unit assembly
BIP looped rail with drilled out feed rail opening
The pressure is sitting right at 82psi at idle, and at the end of a pull where is starts to break up, it is 67psi. This is with seeing 13 pounds of boost.
Old Jul 14, 2014 | 09:19 AM
  #279
berti_00's Avatar
2016 Cls63s AMG
Sorry to see you still having issues Craig, hope you get it all sorted out brotha
Old Jul 14, 2014 | 06:55 PM
  #280
Denroll's Avatar
'06 E55
Can the injectors be too big?
Old Jul 15, 2014 | 09:19 AM
  #281
2006 E55 AMG
Changes that were made to the fuel system are as follows:
* Took out the factory sender unit, and removed the stock fuel filter.
* Removed the factory fuel pressure regulator below the sender unit.
* Ran a bigger feed line upfront to the fuel rail, and put in an inline fuel filter.
* Ran a return line back to the gas tank off the loop portion of the fuel rail, with another inline fuel filter.
* Installed an engine bay fuel pressure regulator.
The plan is to have the car strapped back down to the dyno by tomorrow morning. If the fuel pressure holds constant and does not drop, and the car still breaks up, then the kit will be pulled off and sent back to the vendor.
Old Jul 15, 2014 | 09:28 AM
  #282
blackbenzz's Avatar
haters crazy
Yikes! Hope it works out for you Craig
Old Jul 15, 2014 | 09:34 AM
  #283
2006 E55 AMG
Old Jul 15, 2014 | 09:37 AM
  #284
Joncl's Avatar
E55
Chawkins, is all that really needed? Did the vendor tell you to do those fuel mods? What about rbj claiming he didn't mod any fuel system and still having stock injectors? I really do hope you get it sorted out bud.
Old Jul 15, 2014 | 09:44 AM
  #285
2006 E55 AMG
Removed factory regulator and factory fuel filter.
Joncl, the vendor has not given us any feedback on what to do. I have done research along with BIP on our own, and tried to address all the problem areas. RBJ's kit and mine are different, so it is hard to compare why his runs and mine does not. I am not R&D'ing the kit anymore after this fuel pressure issue. It will be pulled off and sent back.
Old Jul 15, 2014 | 09:51 AM
  #286
Joncl's Avatar
E55
Sorry bud, this is the vendors responsibility not yours.
Old Jul 15, 2014 | 09:55 AM
  #287
black06c230's Avatar
mgLipGD
Good luck buddy hope this solves it all
Old Jul 15, 2014 | 11:04 AM
  #288
2006 E55 AMG
Me too bro, one thing I know is that I will be running the car with some combo on there at wannagofast.
Old Jul 15, 2014 | 11:38 AM
  #289
Worth the wait's Avatar
2006 E55
Way to stick with it!
GOOD LUCK
Old Jul 15, 2014 | 12:28 PM
  #290
AMG E Power's Avatar
E55 amg
If you can keep the temps down get a 3.0L blower or better yet just get the Biturbo from AMG what ever path you take I hope you have great results. must suck not driving youre car for over 4 months
Old Jul 15, 2014 | 02:21 PM
  #291
berti_00's Avatar
2016 Cls63s AMG
and spending money left and right to get the thing working
Old Jul 15, 2014 | 02:37 PM
  #292
RedBullJnky's Avatar
you to Hate
I am using stock fuel system. The stock fuel injectors ran out at 11psi and 5800rpms. So we installed the Eurocharged 550 injectors and I'm at 14psi and holding to 6800rpms. Gonna go back to the track this week with 18" MTs and front Skinnies, full interior on 93oct. We are putting in a 3000 stall converter to see if I can get off the line faster. I'll post another thread soon with dyno pulls and other info. Sorry for the wait.
Old Jul 15, 2014 | 02:38 PM
  #293
you to Hate
Craig, I hope you get this worked out. I would hate to see you send the kit back. You've put In a lot on this. Good luck brotha!
Old Jul 15, 2014 | 04:50 PM
  #294
2319's Avatar
2005 E55
I don't understand how the vendor could be at fault. Could you clarify why you believe this?
Old Jul 15, 2014 | 05:07 PM
  #295
Joncl's Avatar
E55
Don't know if that question was meant for me lol but I do think if you buy a product from a vendor and do everything as they say and then use 2 or 3 different tuners to get it to work and it does not work as advertised or agreed to, wouldn't they need to back up their product?
Old Jul 15, 2014 | 05:56 PM
  #296
2006 E55 AMG
all done!
Attached Thumbnails another twin turbo e55 amg is born at BIP-img_3594.jpg   another twin turbo e55 amg is born at BIP-img_3595.jpg   another twin turbo e55 amg is born at BIP-img_3592.jpg   another twin turbo e55 amg is born at BIP-img_3596.jpg
Old Jul 15, 2014 | 06:28 PM
  #297
Joncl's Avatar
E55
Looks super clean bud, good luck
Old Jul 15, 2014 | 07:07 PM
  #298
Roverron's Avatar
ML63
Good Luck...
Old Jul 15, 2014 | 07:12 PM
  #299
mgLipGD
Well then fire it up and report back with the all clear and get Tony to knock a tune out on the beast.
Old Jul 15, 2014 | 07:20 PM
  #300
blackbenzz's Avatar
haters crazy
Looks like that fuel rail inlet is restrictive. Hope to hear some good news from you soon
