another twin turbo e55 amg is born at BIP
I will keep you updated guys.
on a 12lb spring, it made 500rwhp on 93 octane on the dynamics dyno. pulled it back off the dyno to put the 17lb spring in the waste gates.
as a comparison , customers car, full stage 3 on 93 pump with a 195mm cp made 505rwhp on this dyno.
I would suggest that you eventually put a low pressure spring in the waste gate and do a 3d boost controller if you want to drive it at all other than a race car. The tt v8 cars just come on like crazy with very low throttle input. I was tuning a tt challenger transmission that was barely safe to drive on the street. At 25% throttle it would just build full boost and go.
how would a boost controller net you more HP?
putting in the 17lb springs....
And yea I said the same thing about the boost controller lol
It's also a "gauge". Not 2 1/16 like most, but you can still modify a pod to fit it. It's 60mm diameter. Can't wait to keep hearing about the progress man. I'm a snail fan!
