Smells like fuel in the cabin
I pulled the rear seat and checked under both inspection plates and it's bone dry.
What do I do next?
It's intermittent. Sometimes full tank, sometimes quarter tank. Sometimes not at all. Sometimes I think one spark will blow me to smithereens
What do I do next?
i just had my gas tank replaced due to same issue. its a common problem with the E class w211 platform. take it to a trusted mechanic and have them check the car. i had no gas under backseat but had gas smell inside car and off and on. i actually joined a class action lawsuit for this same issue. good luck. here is a link to the thread i started on my problem.
https://mbworld.org/forums/w211-amg/...-mechanic.html
2006 E55 AMG
Good luck!
my tank was $2600 and i just bought my car used in February. i got the dealership where i bought the car to pony up about 95% of the bill. i will upload pics of bad tank
e55
another common fuel leak that often gets over looked is the fuel pressure dampener.it's on the fuel rail at the back of the motor,passanger side, under the throttle body.the oring dries out and it will start leaking.usually when the motor is cold.
you can get a replacement at rockauto http://www.rockauto.com/catalog/more...792&cc=1431058
Ooh, I got in the car today and it didn't smell like fuel. Soon as I turned the air on tho it came pouring out the vents with outside air on. Outside air draws air from the engine bay, through the hood vent, correct?
Does this lead one to think it's not the tank, rather something underhood?
"another common fuel leak that often gets over looked is the fuel pressure dampener.it's on the fuel rail at the back of the motor,passanger side, under the throttle body.the oring dries out and it will start leaking.usually when the motor is cold.
you can get a replacement at rockauto http://www.rockauto.com/catalog/more...792&cc=1431058 "
https://mbworld.org/forums/w211-amg/...ml#post6052982
here is a link to a thread with pics on the topic that jonnyc mentioned. i thought it was my fuel pressure dampner as well but indeed up being the tank. it wouldnt hurt to have your tank looked at by a quality mechanic. he could also check the dampner for you as well. good luck. i get my car back tomorrow and cant wait!
06 E55
Have the same problem the dealer said it was the o rings on the injectors were worn and that's were the fuel smell was coming from so they replaced them $700 later still smells of fuel when it's cold back to the dealer it's a 2006
PLATINUM SPONSOR
Like others mentioned, the tank gas leak is very common.
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
If you read the post from Jonnyc, you'd have your answer...
I've had this very problem. My fpd was leaking gas all down the passenger side of my transmission bell housing right next to the cats. it's a cheap and fairly easy fix.
Ok he checked out the dampener and it looked good however when he pulled the throttle body off to look he said he found fuel inside there. Any ideas why that could be?
I'm going to replace the dampener anyway since it's cheap.
You have gas in the throttle body? Unless I am mistaken, that is impossible.
I'm pointing him in the directions you guys suggest cause I can't seem to get the gas smell to re occur while it's with him and I can't afford to be like "smelled like gas once, fix it. Good luck"
He's actually one of the best mechanics I've ever dealt with. Fair, honest, meticulous.
