New to the board.. had a question on brief lifter noise on startup
Old Jun 5, 2014 | 05:34 PM
CarbonHan's Avatar
E39 M5, E71 X6M, W211 E63 AMG, W218 CLS63 AMG
New to the board.. had a question on brief lifter noise on startup ADDED VIDEO
Hi guys. Just picked up an e63 last night and noticed something weird this morning when i started her up.
Right when the engine fires up, i hear what sounds like lifter noise for a second and then disappears. It's a bit concerning but i'm a total stranger when it comes to this engine so I don't know if it's normal or not. Can anybody chime in and tell me if this is normal or not?
Note: When slowly pressing the go pedal at idle, i don't hear any noise that coincides with RPMs.
edit: Here's the youtube link for the video with sound:
Old Jun 5, 2014 | 06:50 PM
stockC43's Avatar
65 Chevelle Wagon w/ C5 frame, 08 ML63, 04 S600, 04 E55,(sold) 00 ML55,(sold) 98 C43-55K Swap
07 E63? I may have bad news. Hopefully not as bad as this one.
https://mbworld.org/forums/w211-amg/...y-lifters.html
Search the C63 forums. Essentially the same engine. Many cam/lifter issues with early 63's among other things like headbolts etc.
Do you have a extended warranty?
Old Jun 5, 2014 | 08:41 PM
CarbonHan's Avatar
thanks for the reply. the noise is only present for a second.. if that on start up. The noise goes away immediately. On the last post on the first page of thread you linked me, he says that its only if the noise is present at all times at any rpm so im inclined to think that my engine doesn't have that problem
im going to do an oil change first thing when i get a chance. I read that if the oil filter isn't on tight it can make lifter noises at start up.
Old Jun 5, 2014 | 10:06 PM
p30amg08's Avatar
08 E63 AMG P30, 2013 S550, 09 E63, 14 E63 S Wagon, 14 E350 Wagon(current), 13 C63 P31 (current)
I dont think its the lifters good idea on changing the oil soon. Congrats on the car! Post up some pics!
Old Jun 5, 2014 | 10:25 PM
stockC43's Avatar
Could be a lifter starting to stick. Get some fresh Mobil 1 and factory filter in there and drive it how it's meant to be driven. It seems like the cars that never see high rpm's have the most issues. Just keep a eye on it and the coolant level. If any issues come up its best to catch it and repair it ASAP. Putting off repairs on a m156 will cost big money later.
Old Jun 6, 2014 | 02:33 AM
CarbonHan's Avatar
thanks ak. i just need to figure out which oil i need to use.
and i picked up brians car from supreme:
New to the board.. had a question on brief lifter noise on startup-mye633_zps36e08437.jpg
Old Jun 6, 2014 | 07:53 AM
p30amg08's Avatar
Wheels look sick! Nice pick up sir. Ya there are really good guys on this fourm that can help u pick oil. Initial review from m5 to amg?
Old Jun 6, 2014 | 09:29 AM
Le55's Avatar
2004 E55
Add a couple ounces of Marvel Mystery Oil to the oil for 100 miles prior to that oil change.
Old Jun 8, 2014 | 06:46 PM
benzslo's Avatar
C43 5.4, ML320CDI, Fords
Noise is typical and considered normal if just directly at startup like that. Nothing to worry about.
Have you dealer check your vin/engine number for the headbolts though. This would be number one on my list to do if I had an early 63. It's alot cheaper before they break! And you dealer may even goodwill the repair.
Old Jun 8, 2014 | 08:21 PM
p30amg08's Avatar
Just curious did u get a warranty?
Old Jun 10, 2014 | 01:14 PM
CarbonHan's Avatar
Thank you! I'll call and find out.. what are the chances of them good willing this job?
I have a quote good til mid july from USAA thats pretty reasonable. still debating if i should invest in one or just use the money to fix things
Old Jun 10, 2014 | 03:19 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
No lifters on these overhead cam engines but the rockers can be noisy at times. You may want to try an do an oil change and make sure the engine is running the correct mobile one oil weight. Some people may use the wrong weight and cause a lack of lubrication of the cams/rockers at start up.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Jun 10, 2014 | 11:15 PM
CarbonHan's Avatar
I'm going to be doing an oil change with 0w-40 tmrw. For the filter i'm guessing everyone is using OEM?
