B.I.P makes big power in the TEXAS heat
Old Aug 15, 2014 | 03:34 PM
BI-Performance's Avatar
Former Vendor of MBWorld
E55 AMG on Ethanol-Meth; 600rwhp BMW M5
We just finished a customers car, and it made big power
Mods:
  • 185 Pulley
  • SC Pulley
  • MID Built Block by UPD
  • Ported Heads by UPD
  • BWK
  • Cooling
  • Headers
  • Meth
  • T/B
  • B.I.P Tune by Tony Lawshee
602rwhp/625rwtq on a Dynojet
Old Aug 15, 2014 | 03:37 PM
ShazV6's Avatar
17' C43 Coupe
I was just in Buckhead literally one week ago. I completely forgot your shop was in Atlanta, if i remembered i would of visit. Some serious power you guys made!
Old Aug 15, 2014 | 03:45 PM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
That intake is ****
Old Aug 15, 2014 | 05:04 PM
99lightning's Avatar
99 ford lightning
yea that intake is nice
Old Aug 15, 2014 | 05:24 PM
E55Greasemonkey's Avatar
This place is a joke.
SAE or STD correction? Dyno chart is cut off.
Old Aug 15, 2014 | 05:37 PM
c32used's Avatar
LET C32 2002
nice
Old Aug 15, 2014 | 06:09 PM
EREBUS's Avatar
clk63, cls55, ml63, (w210) E55
Jason and Tony @ BIP are freaking awesome. If you don't know them.....you need to.
101 degrees was the temp when we hit 602 rwhp. The techs at Dallas Performance states their dyno is low @25 hp. We were using VP M109. We could of gained more with Q16, but....I'm tired of changing out 02s.
I would like to thank Shardul for showing up. I owe a lot to him. Always there when you need him.
Attached Thumbnails B.I.P makes big power in the TEXAS heat-anthonydyno7.jpg
Old Aug 15, 2014 | 08:38 PM
305-E55's Avatar
2017 Charger Hellcat
Healthy numbers!!
Old Aug 15, 2014 | 09:10 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
The problem with those intakes sucking in hot engine air is that the engine will have a tendency to heat soak very quickly in hot weather. They look good but the power will be greatly decreased when the hood is closed. It does look cool though.
Old Aug 15, 2014 | 11:01 PM
EREBUS's Avatar
First, you need to ask who completely takes off their intakes and filters and who doesn't while on the dyno.
Second, it has been proven that IATs are not greatly effected with open filters that have channeled air flow.
Third, are you telling me @5000 rpms in 4th gear there will be less air flow driving than the shop fan in a 100 degree room?
Old Aug 15, 2014 | 11:05 PM
320 dreamer's Avatar
2003 porsche 996 turbo
spraying meth. won't be a heat issue
Old Aug 15, 2014 | 11:07 PM
Hulk's Avatar
A Merc
How many dead kittens bro lol
Old Aug 15, 2014 | 11:29 PM
EREBUS's Avatar
10. maybe 12.
Old Aug 15, 2014 | 11:41 PM
Grip Grip's Avatar
SLK55 AMG - Renntech Supercharged
Big Kudos to BIP as usual. Tony tuned my old V6 Crossfire to a 11.0 @ 124. It would have been a 10.8 if not for the slipping tranny.
Now they're working on my CL65 tune which has yielded great results on the dyno so far.
Nice work Tony!
Old Aug 15, 2014 | 11:44 PM
BlownV8's Avatar
Will still be an issue but the meth will help mask the heat and reduce detonation. If the intakes were drawing cold air, the car would make more power much like it did on the dyno with the hood open. Drawing in hot air from the engine bay kills power. It should not even be a discussion.
Old Aug 16, 2014 | 12:15 AM
SPatykAMG's Avatar
W211 E55
Did he tune for the meth or just for cooling? What water/meth mix are you running? Great numbers btw
Old Aug 16, 2014 | 01:10 AM
black06c230's Avatar
mgLipGD
Great numbers there! Tony can certainly tune.
Question:
What is the red hose running to/from behind the grill/hood latch area for? Can't make it out. Can tell its not for a trunk tank type setup since that is on the pass side.
Old Aug 16, 2014 | 02:06 AM
Denroll's Avatar
'06 E55
Hot damn, nice... everything!
What are the expected numbers on craptastic 91 octane?
Old Aug 16, 2014 | 07:38 AM
Hulk's Avatar
A Merc
Originally Posted by EREBUS
10. maybe 12.
Ha I was thinking 15-20
Old Aug 16, 2014 | 08:00 AM
jmb614's Avatar
E55 AMG
Car looks strong, way to go BIP! What size UD pulley?
Old Aug 16, 2014 | 09:16 AM
chawkins2001's Avatar
2006 E55 AMG
185mm brotha
shardul's Avatar
2003 W211 E55, 2003 W220 S600
185mm crank pulley and 84mm sc pulley
Old Aug 16, 2014 | 10:17 AM
lm7's Avatar
lm7
2003 E55
Tuned for 109 (adv timing) or just playing it safe? Great numbers awesome setup!!
Old Aug 16, 2014 | 11:06 AM
blackbenzz's Avatar
haters crazy
Congrats, glad you are happy with the results
Couple questions, why are your AFR's in the 9's at the beginning of the pull? Do you know why the power is falling off at the top of the pull? I thought ported heads would prevent this. Nice numbers for such crazy heat!
Old Aug 16, 2014 | 11:23 AM
Hulk's Avatar
A Merc
With 109 you can add timing safely , it's a great anti det fuel and won't destroy O2 like leaded fuels
