So my tech did a "new" dual HE CLS55 build... come on in please
Old Nov 5, 2014 | 07:56 PM
0700700's Avatar
CLS55 AMG
Heya guys, long time no see. Since I got some spare cash recently, I had a
nice shop back home manufacture me an 85mm supercharged pulley. I
went with something that far exceeds any of the pulleys offered on the
market (trust me ive suffered enough)
While waiting for the pulley we discussed with my tech a way to cool down
my car effectively (we race up to 200mph in my country ). As I had
already purchased an aftermarket HE we thought of using both this and my
old one. I gave my tech all the threads here, and he finally told me he had
build an easier and cheaper setup than anything hed seen on here!
So I've got some data logs and a nice little vid for you guys. If you think he
has actually achieved something good, then ill get him to detail all the pics
and the build process so I can share it for other fellow members to see.
If not, then well ill demand my cash back
Im attaching a data log done in 40F weather just now with one
passenger in the car and 2/3rds tank of 100octane fuel.
Data log is for a run from 20mph to 195mph
Mods:
85mm Supercharger Pulley (own make)
Belt Wrap Kit
Eurocharged TCU
Aggressive 100ron Jerry tune
No secondary cats
Ported headers (otherwise stock)
Ported supercharger air intakes (or something like that)
Dual HEs.... one OEM, one Eurocharged
3rd Gen Bosch IC pump
Im also attaching a vid of my car doing a smaller run with just me filming.
Any input would be appreciated, as there are far more knowledgeable tuners here than me (first project )
Attached Thumbnails So my tech did a "new" dual HE CLS55 build... come on in please-datalog.jpg
Old Nov 5, 2014 | 09:03 PM
AMG E Power's Avatar
E55 amg
Why is your traction control going crazy ? I don't get that
Old Nov 5, 2014 | 09:23 PM
Hammer Down's Avatar
2015 E63S, 2018 E63S
I hope that was a joke
Old Nov 5, 2014 | 09:43 PM
02C32guy's Avatar
2005 E55
I dunno, I'm new around here, but I don't see any benefits of your two heat exchanger system on your IAT's versus a person with a tank and one HE. How / where are the heat exchangers mounted? Are they in succession with one pump running the coolant through them both?
Old Nov 5, 2014 | 10:04 PM
stvbreal's Avatar
2007 E63 AMG
Old Nov 5, 2014 | 10:20 PM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
What are you looking at? I didn't see the light come on once.
Old Nov 6, 2014 | 12:19 AM
E55 amg
Lol I meant not coming on
Old Nov 6, 2014 | 12:30 AM
C32owner's Avatar
2018 E63s AMG (Current) 2011 CL63 AMG (Sold) 2005 CLS55 AMG (Sold) 2004 C32 AMG (Sold)
Air intake temp still going up to 66'c so a lot of timing still being pulled.. Check for a data log of someone with just a "regular" HE upgrade setup and see what temps they getting.
Old Nov 6, 2014 | 06:23 AM
0700700's Avatar
CLS55 AMG
Im using some sticky 295s which were properly warmed up prior to my testing
The two HEs are mounted on top of one another, for which we had to re-wire some of the lines for the hydraulic system. They are in succession and one pump is pumping through both. We are discussing using two pumps in a push pull configuration
Im attaching an old data-log of a long pull in 4th gear form about 50-170mph using just the Eurocharged HE and same mods. For a much shorter run the AITs shot to a significantly less friendly temperature. This is why I thought I had made significant progress on the car The vid is also with the old setup, and I think it was significantly slower in the topend
So what you guys think, is it performing well enough for the limited mods I have, or are temps still an issue?
Attached Thumbnails So my tech did a "new" dual HE CLS55 build... come on in please-capture.jpg
Old Nov 6, 2014 | 09:14 AM
uraberg's Avatar
2006 E55 AMG
Timing seems to stay pretty steady?
Is it you lifting at around 25 seconds in, or is the car actually slightly closing the throttle?
Did you log speed? (if you can log time vs speed, then you have a pretty easy way of comparing runs.) I guess you can convert from rpm and gear.
Old Nov 6, 2014 | 10:27 AM
mobhouse's Avatar
Mercedes E55
for running an extra H/E and only dropping 16 degrees F at peak, I don't see the use. I would remove that extra weight and install either an in bay tank, or a trunk tank and run it again.
Old Nov 6, 2014 | 11:00 AM
uraberg's Avatar
2006 E55 AMG
More heatexchanger is always good. You can always (and probably should) combine this with a split off extra tank.
BTW, I suspect having the heatexchangers in parallel should give you best cooling, and I don't think a second pump will do much.
Old Nov 6, 2014 | 12:48 PM
Denroll's Avatar
'06 E55
Let's see some pics of this setup!
Old Nov 6, 2014 | 01:07 PM
JoeNobody's Avatar
Mercedes
post some pictures
Old Nov 6, 2014 | 02:39 PM
Mikeki7's Avatar
CLS63, S55
What they said, would like to see the layout of the setup.
Old Nov 6, 2014 | 07:32 PM
RedBullJnky's Avatar
you to Hate
This ^^^^^
I had an EC front HE w/ Meziere pump, a Cobra HE under my trunk, a 3.5 gal trunk tank with Rule2000 pump AND 1.5 gal water/meth tank in the trunk w/ dual nozzles
Old Nov 10, 2014 | 06:46 PM
0700700's Avatar
CLS55 AMG
No, I didn't. This was with just one HE. Its correlated with high IATs... The car was a bit of a dog at high speeds previously.
My SA also thinks a second pump is redundant in this setup. But I told him I wanna try both setups
Ditto! This weekend we're taking the car apart to clean up the install and I will personally take some nice piccies
Old Nov 11, 2014 | 04:06 PM
JoeNobody's Avatar
Mercedes
Second pump would help, especially if you already have it.
Running the exchangers in parallel would give the highest flow, although more coolant will flow through whichever exchanger has the least resistance, so effectively you may end up with only slightly better than one exchanger. Because of that, I think running them in series would be better (Renntech additional exchanger does it that way).
Old Nov 11, 2014 | 09:42 PM
0700700's Avatar
CLS55 AMG
Reason why my tech doesn't want to use two pumps is because they have a slightly different flow rate. CM30 has a around 30cfm from what I remember and the stock third gen Bosch (i.e. OEM) pump has around 33. I sometimes think whether I really got a grasp of the difference between parallel setups and series, but once I get the car up on jacks ill take some pics for further comments!
Old Nov 12, 2014 | 03:01 AM
viper04's Avatar
Thanks for posting but I have never seen the Renntech additional heat exchanger before(interesting). If you have a pic can you post it. Mercedes also runs this set-up with the S55. From my personal experience was a great set-up. Never had a cooling issue, always wonder why it was never used on the E55? May no room for it?
Old Nov 12, 2014 | 03:23 AM
60nomad's Avatar
2011 CTSV auto, 06 E55 white pano, 87 Grand national, 63 split window
Originally Posted by RedBullJnky
This ^^^^^
So, lemme get this straight, you have NO cooling?
Old Nov 12, 2014 | 12:22 PM
Manuyc's Avatar
19 f-150 limited (w/raptor engine) 06 e55,81SC Targa,08 CLK63 BLK,91 E34 M5
word
Old Nov 12, 2014 | 01:47 PM
JoeNobody's Avatar
Mercedes
can see it here https://mbworld.org/forums/w211-amg/...installed.html
Old Nov 12, 2014 | 01:54 PM
5280CLS55's Avatar
2006 CLS55 AMG, 2008 G55 AMG, 2010 Audi R8 V10, 2010 Ford Raptor, 2005 Porsche 911, 1966 Chevy II
Pics of this car would be nice!
Old Nov 12, 2014 | 01:57 PM
JoeNobody's Avatar
Mercedes
CM30 pump isn't what it's cracked up to be. The quoted flow rate is only with zero flow resistance, and when used in high resistance system (such as an intercooler), it's flow rate plummets. Lingenfelter did a lot of testing with various pumps and the CM30 was dead last (even worse than the factory Bosch 010 pump).
https://mbworld.org/forums/m275-v12-...ml#post5836390
But with that said, running both pumps in series would still be better than a single pump. The difference in flow rates between the pumps won't matter, since neither pump will produce the full rated flow.
