m113k rear main seal and torque spec help
Old Nov 30, 2014 | 10:08 PM
Funk Season's Avatar
06 Mercedes-Benz CLS55 AMG
Got the tranny out so doing rear main seal on the 113k while i'm at it. Got a few questions and need torque specs, tightening sequences and stages
1. Since im doing the whole crank seal retainer and main seal, can I use permatex black or gray? Also should I press the main seal in to the retainer before install or after install? Also need torque on these bolts
2. I realize the flex plate to crank bolts are stretch bolts. After searching for part number I came up with A004 990 3212 which are 25.5mm. After removing mine I found out mine are shorter 18.5mm ones, but I had already bought the longer ones. Can I go ahead and still use the longer ones? Also need torque specs on these bolts
3. Torque specs for flex plate to torque converter bolts?
thanks
Old Dec 1, 2014 | 10:33 PM
bump
Old Dec 2, 2014 | 09:04 PM
figured out the flex plate bolts won't work.
so need help with 1st thing and torque specs for flex plate to crank and felx plate to torque converter
thanks
Old Dec 2, 2014 | 09:16 PM
O-55's Avatar
2005 E55, 2009 VW GLI
Here you go.
Last edited by O-55; Dec 2, 2014 at 09:33 PM. Reason: Added flywheel to crankshaft screw part number.
Old Dec 2, 2014 | 09:35 PM
Chomanche's Avatar
2007 E63 Amg, Heavily modified 1988 Jeep Comanche
The 90 degrees is hard with out the flywheel lock tool. Just tight as *** as long as you replacing em
Old Dec 2, 2014 | 10:26 PM
trackjunky's Avatar
W211 E55 Wagon, E46 M3
Originally Posted by O-55
Here you go.
Where are these instructions/diagrams from?
Old Dec 4, 2014 | 12:35 AM
O-55's Avatar
The snippets are a mix of alldata and epc.
Old Dec 4, 2014 | 09:50 PM
Bigtickets's Avatar
E55K, Black on Black. C63, Black on Black. SRT-10 NightRunner 363of400
How long should this take start to finish?
Old Dec 16, 2014 | 10:31 PM
thank you so much O-55 i really appeciate it
Old Dec 16, 2014 | 10:32 PM
my lock tool lol
Old Dec 17, 2014 | 01:18 AM
Elhonaz's Avatar
W211 E55 2003
Originally Posted by Funk Season
my lock tool lol
Nice!! What parts did you replace? Just the seal or back cover also?
Old Dec 17, 2014 | 09:37 PM
replaced the main seal, the whole retainer and the flex plate bolts. wasn't leaking, had the tranny out so just did it anyways
Old Dec 17, 2014 | 10:39 PM
Chomanche's Avatar
Thats a good lock tool, props.
Old Dec 18, 2014 | 12:41 AM
rockthemullet's Avatar
2005 Mercedes E55 AMG
Great lock tool, thumbs up
Old Dec 18, 2014 | 04:04 AM
Elhonaz's Avatar
W211 E55 2003
Did your dealer tell you that the end plate should be replaced too? Was there any difference between the old one and the new?
Old Dec 18, 2014 | 05:53 PM
don't really talk to dealers. just read sometimes the retainers start leaking so since i have 163k decided to change it.
from what i remember it was pretty similar maybe slightly different
Old Dec 19, 2014 | 01:33 AM
Elhonaz's Avatar
W211 E55 2003
Ok, just trying to figure out if that is it something that is a must to do in order to get it fixed. I got the new seal but theres no info in EPC stating that it needs to be changed with the new seal. Starting to seem like everyone is just changing them for the sake of it, and sure while your in there you just might aswell do it
Old Dec 19, 2014 | 01:42 AM
pretty much might as well replace it while your down there sums it up. its not an expensive part so why not
im even installing headers since im down there lol
Old Dec 19, 2014 | 01:45 AM
Elhonaz's Avatar
W211 E55 2003
Now we're talking
Yeah probably going get it it too, just not that relevant ATM, still waiting for my heads to come back so i can start putting it back together
Old Dec 19, 2014 | 09:18 AM
I've disassembled (4) M113s with varying mileage (all over 100k) and all of them were bone dry. I didn't replace my end plate
