!!! ATTENTION !!!! - FUEL LEAK ISSUE HAS BEEN SETTLED BY DAIMLER-BENZ... 2014.12.23
Old 07-25-2015, 08:04 AM
  #651
Hulk's Avatar
A Merc
Nice bro
Old 07-25-2015, 12:18 PM
  #652
Mackhack's Avatar
How much was it to ship it to Germany?
Old 07-25-2015, 07:57 PM
  #653
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
At the time it was combined in a hi-cube container with furniture and household stuff. I checked recently on the cost of shipping it to the port of Ft. Lauderdale which was about $1500.00.
If you are planning to stay in Europe for more than 6 weeks, it's actually less expensive than renting a car for the same period.
Old 07-25-2015, 08:37 PM
  #654
Mackhack's Avatar
Seems that way but I'm not. I always have families cars in Germany when I go.
Old 07-28-2015, 10:21 AM
  #655
BagMan's Avatar
E55, E320 CDI , CLA250, Jag XJ Supersport
When changing settings to "Xenon present", what is the car actually doing?
Does it just eliminate bulb out errors or is there a change in voltage to the lamps? or something else?
Old 07-28-2015, 10:25 AM
  #656
Super Moderator
MJ50's Avatar
bone stock E55 AMG
it means you can install aftermarket HID kit and it won't throw error code...
Old 07-28-2015, 10:53 AM
  #657
JoeNobody's Avatar
Mercedes
Wrong thread.
Old 08-04-2015, 09:40 AM
  #658
jcjmw's Avatar
2005 E55 Wagon
Thanks to the person who attached the lettered from Mercedes about the fuel tank recall / warranty. It came in very handy when I went to my dealer.
Old 08-04-2015, 02:38 PM
  #659
E55Freak's Avatar
2005 E55 silver
parts are still on backorder according to my dealer...took it in april 30th....anyone else having to wait this long?
Old 08-04-2015, 02:45 PM
  #660
Mackhack's Avatar
I think I mentioned it in this or another threat. PM with your VIN and what parts you want to have replaced and I'll check with my source. I helped others before getting them in between 2 and 7 days. Shipping from my location to you is probably not covered if you go through the claim though. But perhaps better than waiting 6 months
Old 08-10-2015, 11:56 PM
  #661
E55Greasemonkey's Avatar
Received 1,490 Likes on 986 Posts
This place is a joke.
Just to update, our dealership last week received several E55/CLS55 COMPLETE assembled tanks (meaning fuel filter and pumps installed) , including mine. They have been on order for a couple months. For those that are waiting, the complete assembled tanks are starting to show up. Curiously we had one car a month or so ago, that ran poorly after the tank/pump was replaced. We found out one of the 2 pumps was wired backwards inside the tank-causing the pumps to fight each other. The new tanks that just arrived come with a wire harness to correct the wiring of one pump-it swaps the wires positive-negative. I'm not sure what's going on, but I don't want to unseal the tank to find out, I will just use the provided harness or more likely swap pins on my existing wiring to the pump.
Old 08-11-2015, 12:16 AM
  #662
coolchuck's Avatar
2016 E63s
Got a full tank of gas Friday and got code P0456 yesterday. I pulled the seat and there's some gas pooling on the passenger side. taking it to my dealer tomorrow and see how it goes.
Old 08-11-2015, 04:07 PM
  #663
AgSilver's Avatar
Gaads! A harness to correct an incorrect harness.
Old 08-11-2015, 04:17 PM
  #664
Mackhack's Avatar
Order the right parts and no need to do cluster **** workarounds that might not even work.
Old 08-11-2015, 05:18 PM
  #665
Yep. I'm not sure if the error was discovered after all the tanks were assembled by the vendor, and they didn't want to open them all up and have to pressure test them again?? Or ??? A simple pin swap from the car side of the harness is all that is needed. But then, they'd have to update all the wiring diagrams. German Engineers. Who knows...
Did I mention the adapter harness is over 2 feet long?????
Old 08-14-2015, 10:51 PM
  #666
coolchuck's Avatar
2016 E63s
So I took my car in Thursday. I talked with my SA today and he advised that my issue is covered by the extended warranty. The car should be ready by Tuesday
Old 08-14-2015, 11:07 PM
  #667
Bean93x's Avatar
'05 E55, ‘00 ML55, ‘92 500E
Took my car in weds, picked it up thurs. Not one charge to me. Filled it up the brim today and have yet to smell fuel. Will check further tomorrow. Got to clean the carbon off of a 2015 C300 loaner during the duration. 4matic, turbo inline 4 etc...
Old 08-17-2015, 10:48 AM
  #668
LNDMISSL's Avatar
E55 W211, G55 W463, 2010 GT500, 2008 S4 Cab (Wife), LR4
I just dropped mine off this morning and got the same loaner.
Old 08-25-2015, 08:55 PM
  #669
CTSV_OR_E55's Avatar
2004 E55/2011 CTS V coupe
I just purchased an e55 and the previous owner had the fuel pumps replaced for the same reason, paying out of pocket. LOoks like the purchased the pumps from the dealer and had another shop do the install. would he/I be due for a reimbursement from MB?
Old 08-25-2015, 09:02 PM
  #670
Mackhack's Avatar
Yes. Bring everything listed on back of official MB letter to a dealership. Takes 2 weeks to get a check in the mail. I did it the same way. Indy installed it, went to MB, 20 seconds later out the door, 2-3 weeks later check in the mail.
Old 08-25-2015, 09:23 PM
  #671
Excellent news! Thanks!
Old 08-26-2015, 12:31 AM
  #672
Hulk's Avatar
A Merc
The the check will be written out to the name on the receipt
Old 08-26-2015, 12:32 AM
  #673
Mackhack's Avatar
Correct, sorta. It's to the registered owner.
Old 08-26-2015, 01:18 AM
  #674
Well the seller is someone I'd split it with, so is it made out to him since he completed the fix, or to me the new owner? Regardless having them replaced played a part in me purchasing the vehicle.
Old 08-26-2015, 01:28 AM
  #675
Hulk's Avatar
A Merc
Most likely the check will be made out to him since his name is on the receipt
Quick Reply: !!! ATTENTION !!!! - FUEL LEAK ISSUE HAS BEEN SETTLED BY DAIMLER-BENZ... 2014.12.23
