!!! ATTENTION !!!! - FUEL LEAK ISSUE HAS BEEN SETTLED BY DAIMLER-BENZ... 2014.12.23
I wonder if there will be an official recall now? Aren't they just replacing with the same defective parts?
I'm having a new tank installed for the 2nd time.
"From what I’ve boiled this issue down to, I believe the fuel odor is being caused by the temperature in the tank being above normal, which I can only attribute to the aftermarket exhaust. When the vehicle runs for a few hours at idle in the work bay and I also have the heat turned on in the vehicle I can get fuel odor to come out of the vent valve in the charcoal canister. I believe that due to the expanding gasses in the tank, the charcoal canister traps a certain amount of vapors (which it is designed to do) and the purge function cannot keep up with the amount of vapor that’s being pushed into the canister. The purge function is working, however I think that it cannot keep up with the amount of vapor being put into the canister."
" Fuel tank has been replaced twice· Charcoal canister has been replaced twice· Fuel filler neck has been replaced · Vehicle is equipped with aftermarket tune, supercharger pulley, and exhaust.· Aftermarket exhaust has short tube headers and does not have catalytic converters.· Manifold pressure at idle is 280 hPa (absolute pressure) – proper for this engine· Purge function is operating at idle (no spec provided by MB as to when engine control unit activates purge)· Once vehicle is at operating temp, the exhaust below the fuel tank is around 140-150 degrees. The heat shields covering the fuel tank are the same, the parts of the fuel tank that are visible are near 110 degrees. I do not have a like vehicle to compare with. · As vehicle/fuel tank heats up, the amount of expansion is as follows:o 10 min running, shut off valve closed for 5 min: 10hPa gaino 90 min running, shut off valve closed for 5 min: 12hPa gaino 120 min running, shut off valve closed for 5 min: 16hPa gaino 180 min running, shut off valve closed for 5 min: 24hPa gain· Due to this expansion in the fuel tank, I believe the purge function is having a hard time competing with the pressurization (purging works off engine vacuum) allowing the excess vapors to escape the canister."
http://www.detroitnews.com/story/bus...robe/20800823/
Looks like MBZ will now cover all repairs for MY2003 -2009 E Class for up to 15 years (and unlimited mileage) for fuel leaks....
Get those fuel tanks fixed, gents!!!
And for those of you who paid out-of-pocket: Go ask for your refund!!!!
-G
I'm a new member to this forum and found this post about Mercedes covering the gas leak problem.
I have a 2007 C280 4matic and would like to know if it is covered?
Thank you,
just got the call this morning that they will be replacing the entire fuel take assembly. i was worried as my car was modified and he assured me that as long as the modifications were not in relation to the fuel system I would be covered. he did mention the fuel take assembly costs somewhere along the lines of $4,500.
This is why you idiots that keep calling this a recall here on the boards need to get your **** straight and call it what it is, an extended warranty.
A recall and an extended warranty are completely different things.
At that point your muffler guy should be kicked in the nuts.
