W211 Front Suspension / control arms / ball joints torque specs
Old Apr 28, 2016 | 03:22 AM
BBBSS's Avatar
03 E55 AMG, 06 Harley Road King Custom 06 Ram 2500 Cummins, 97 Firebird Race Car, 88 Cutlass Supreme
I've spent a couple days going over various how to's and trying to get torque specs for the various front end components and I keep finding missing or mixed info on torque specs.
Does anyone have a list of the torque specs for the various suspension components? I tried to title this thread in a way to help others searching for this info in the future.
I specifically will be replacing the thrust arms, complete upper arms with upper ball joints as my 03 has the early style non-replaceable upper ball joint, and lower ball joints from the rear lower control arm to the knuckle. Any other specs would be helpful as well though.
Thanks to anyone that can help get some good specs out there for others that will be looking for this info.
Old Aug 24, 2016 | 05:12 PM
albenjoseph's Avatar
2015 E63s, 2015 GL63, 1987 2.3-16
anyone? i also need sway bar end link torque, along with the lower control arm, and lower ball joint torque specs.
thanks,
aj
Old Aug 24, 2016 | 06:08 PM
TheTherapist's Avatar
2004 W211 E55 AMG >>gone but not forgotten > W123 280E > W124 E280 > W126 380SE
Tie Rod Lock nut, tie rod on inner tie rod........60 Nm
This was the only one I located when doing a quick search but all torque specs should be listed somewhere under this heading:
ALIGNMENT SPECS
http://workshop-manuals.com/mercedes...ignment_specs/
When someone finds the specific pages it would be good to update this thread with a direct link...
Old Nov 11, 2017 | 09:49 PM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
Check out mercedesmedic.com
Old Jul 3, 2018 | 11:44 AM
Rovel's Avatar
2007 E63 Amg
Will be replacing the front strut today on 2007 E63. Does anyone know torque specs for upper control arm ball joint and for lower shock mounting bolt?
Can't find anywhere.
Old Nov 21, 2019 | 01:10 AM
theblackhole's Avatar
E320
Torque Specs. I found this.
Old Dec 2, 2019 | 07:48 PM
briandavis06's Avatar
AMG E63
Super helpful
Originally Posted by theblackhole
THANK YOU!!
Old Nov 3, 2021 | 05:07 PM
BigMikeLv's Avatar
2008 Mercedes E350
Exactly what i was looking for! Thanks a bunch
Originally Posted by briandavis06
THANK YOU!!
cant stress how hard it was to locate this! Thanks so much.
Old Nov 14, 2021 | 10:25 PM
Overheated's Avatar
1998 E320 Wagon, 2003 W211 E500, 2003 W211 E500, 1999 W210 E55 AMG
Valuable data. As I'm preparing to inspect and re-torque E500 '03 suspension, I've seen on this and other DIYs that some torque settings are done in phases with a second phase expressed in degrees. Am I correct that this means that the specified first phase torque is added to by the specified degree or how does that work, huh?
Old Nov 14, 2021 | 10:48 PM
GinDistiller's Avatar
2019 M5 Comp, 2005 Ariel Atom 2
Yes, torque to spec then add the indicated degree turn. I should also note, when installing new ball joints, check and retorque after a couple hundred miles, sometimes the seat can loosen a little over potholes etc.
Old Nov 22, 2021 | 05:50 PM
E63007's Avatar
07' E63
The one Torque Setting that's missing in that PIC in the one for the Front AirSpring to the Control Arm, which is 165 Nm (the Rear AirSpring is 150Nm FYI). Really tough to torque that much from under the car. Hell, the 80Nm + 120 is a B _ T _ _ too!!! And I hate having to use my DeWalt Hammer Drill to get there, but it works in a pinch!!
Old Apr 5, 2022 | 02:55 AM
Pralla's Avatar
W460(82)
are this the same torque as what I've circled? And is it the same torque on w205? (2012 350e)
Old May 23, 2023 | 09:47 PM
dabawi2's Avatar
2016 GL450
This is awesome, but my Vehicle is 4matic. Wonder if anyone has this diagram for a 4matic?
Thank you
