E63 rotor replacement - saved thousands
Old Apr 3, 2017 | 03:54 PM
Island_Moose's Avatar
2007 E63 AMG
I replaced my E63 rotors at all 4 corners with 1 piece C63 rotors. I realise for the purists this is horrible, but this is my daily driver, not a track car. The difference in handling and braking, even in hard driving, is zero. It made no difference at all except better braking due to new components.
I did have to prep and paint the centre sections after installation when I realised that iron obviously corrodes. This escaped my attention at the time. The painting was very straightforward. I masked the calipers only, and used a razor blade and thinner to clean the rings of any overspray. The feedback I'm getting is positive.
I saved $4000 over factory parts, and $1500 over the cheapest aftermarket E63 parts.
Attached Thumbnails E63 rotor replacement - saved thousands-image1.jpg   E63 rotor replacement - saved thousands-image2.jpg
Old Apr 3, 2017 | 06:15 PM
BrakeFade's Avatar
'04 E55 AMG
Old Apr 3, 2017 | 08:15 PM
PutNavid's Avatar
06' E55 AMG, 03' E55 AMG
Originally Posted by BrakeFade
My e55 is my daily. When I finally get down to reconditioning the calipers, I will be going to one piece rotors myself.
E55s never came with two piece rotors.
Old Apr 3, 2017 | 08:20 PM
BrakeFade's Avatar
'04 E55 AMG
Really? Didn't know that. I haven't owned the e55 very long. I thought they were 2 piece rotors due to the 8 piston caliper. Learn something new everyday. My SRT Charger has 2 piece rotors, I may be mixing them up in my brain....
Old Apr 3, 2017 | 08:22 PM
PutNavid's Avatar
Yup just good old 1 piece. Just be sure to get akebono pads to get rid of the brake dust problem!
Old Apr 3, 2017 | 08:53 PM
Skizz's Avatar
'20 GLE450; '06 CL65
AND I believe you may have SBC. If you change rotors and pads yourself, danger Will Robinson! My E63 doesn't have SBC, but I understand that you need to be cautious when you have the pads/rotors out if you haven't pulled the batter cable. Step on the pedal and out pops the pistons.
Should be able to find plenty of info here on it.
Old Apr 3, 2017 | 09:09 PM
PutNavid's Avatar
No worries about SBC. All you have to do is unplug the SBC unit. Or if you choose to unplug the battery be sure to unplug BOTH batteries. One in the trunk and one under the cabin air filter.
Old Apr 5, 2017 | 11:37 PM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
E63 does not have SBC.
OP, good for you. Was wondering when someone was going to do this. I have had exchanges on the forum exactly to this point. If you are not going to track it, use the one piece rotors.
Me getting to replace my front rotors very soon for the second time. Bought RB and just changing the iron rather than the whole thing save a lot as well. Will post when I do.
Old Apr 7, 2017 | 06:30 PM
zubin.p's Avatar
cls55
Thats awesome man. Im about to do fronts on my cls55 with P030 and its got 380mm 2 piece upfront. I think the E63 also had the same setup. Any parts numbers for the rotors?
Old Apr 14, 2017 | 06:09 AM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
FCP Euro sells brembo one piece and two piece with lifetime warranties. Great pricing as well.
Old Apr 14, 2017 | 03:07 PM
Z_de_Suisse's Avatar
W211 E63 AMG / W124 E500 / Lancia Delta Integrale Evo2 / Lotus Elise 111s MK1
That's awesome !!!
My rotor are good to be changed very soon (34mm left for 33mm minimal thickness), would be good to get more details about the part you used ? part n° or year of the C63 parts you used.
Thanks !
Old Apr 17, 2017 | 07:03 PM
Infiniti's Avatar
a unicorn tuned p30 e63
http://www.ebay.com/itm/Mercedes-C63...JYPYNJ&vxp=mtr
why wouldn't these work?
Old Apr 17, 2017 | 08:03 PM
hachiroku's Avatar
SPONSOR
those are the same as FCP Euro but without lifetime warranty. essentially OEM rotors as OEM is exactly the same other than the box stating Brembo vs Mercedes.
https://www.fcpeuro.com/products/bra...mbo-2194210212
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Apr 17, 2017 | 09:17 PM
Ls1toAMG's Avatar
2004 E55.98 SS Camaro.Jetta TDI. Expedition
On the E55 you don't have to step on the brakes to activate open a door or anything and it activates. You must unhook both battery's or unplug Sbc. Too dangerous if you dont
Old Apr 18, 2017 | 04:02 PM
2007 E63 AMG
I just bought aftermarket rotors for a 2007 C63 AMG. The brand name was Icer, same with the pads.
Prices in New Zealand dollars, NZD $1 = 70 cents USD
Front Rotors (360mm X Drilled): $399.00 pair incl gst
Rear Rotors (330mm X Drilled): $299.00 pair incl gst
Sensors: $9.90 incl gst each
Icer Front Brake Pads: $219 incl gst a set
Icer Rear Brake Pads: $179 incl gst a set
Old Apr 19, 2017 | 05:19 PM
Infiniti's Avatar
will the 390mm cls PP rotors work?
Old Apr 24, 2017 | 11:46 AM
You want to put 390mm disc instead of 360mm !? That's not going to work unless you change the calipers as well.
Old Apr 26, 2017 | 05:16 AM
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
I believe the cls pp rotors are 380mm, and rare as hens teeth with a price to match.
Old Apr 27, 2017 | 08:14 AM
hayseed's Avatar
04 e55
just planning ahead a little and thinking of getting a 2012+ E63 and wondering if you can do the same thing with the brakes on those from a c series or are they completely different ?
Old Apr 27, 2017 | 08:45 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
Why are you trying to retrofit C Class brakes on a E Class ? Is it the ultimate goal to save money? My 07 E63 is going to need new brakes by next year, instead of spending $1156 per front rotor from the stealership, I found the correct set of two piece rotors on eBay for $798 Man, this was out freaking standing. I couldn't see putting E55 or C63 one piece rotors on my car.
Old Apr 27, 2017 | 11:36 AM
hayseed's Avatar
04 e55
for me, I have never had good luck with rotors that were not from the OEM, I have had many warp or get spots/wheel shake after a short period of time. I will only purchase OEM from now on even if they are direct suppliers - not all the castings and metal content are the same so you don't always get the best quality - I would hate to have a rotor crack braking hard at 130/140mph -- just my thoughts.
Old Apr 27, 2017 | 11:53 AM
Yuille36's Avatar
I certainly understand your situation, I bought my rotors from Parts Container, they are OEM rotors. And I save big $$$$ For an E63 the front rotors are the major expense item. The rears are the same as an E55, so pretty cheap. OEM Rotors and pads are the best way to go, but OEM Pads are dusty as hell, they use a high carbon content. After a few days your wheels are black with the dust. They are better pads that offer increase grip and less dust.
