Finished conductor plate install and now won't move
Car is 2005 E55 AMG
Did you do a full fluid change or just dump what you needed for the conductor plate?
Car is 2005 E55 AMG
The only clue I've found online for you is here: http://www.benzworld.org/forums/w203...ml#post3793337
Car is 2005 E55 AMG
Dave
Car is 2005 E55 AMG
It can be easy to miss the groove on the plastic guide on the manual valve and get on one side or another. If gear position moves on dash, jack car up make sure its stable on 4 jack stands or lift. Then loosen the clip on the shift linkage lever on the side of the trans. Have someone put it in D right as you put it in D, Does it go?
Same for R make sure your timing is close on the shifts, unsure if there is any C-Can feedback on shifter lever compared to manual actuation by hand.
You will be able to feel with your hand better about whats going on. If its soft one way to go into D then you are prolly off and it just is sliding past without moving the valve would be my guess... Honestly without re-inspecting or seeing fluid level its hard to diagnose things like this.
Is the shift to R smooth or is there a harsh garage shift (clunk)?
Just put " 722.6 .pdf " in google and get a copy of the manual it will show you exactly where they all go and give more intel than you could ever desire
Man, this is a dooozy
Whoever owned the car before me decided to put the red dipstick cap on the engine oil tube. The notes on how to fill tranny fluid stated the red cap tube is where the fluid goes and so the issue was all the *** tranny fluid was poured into the gosh darn crank case. Super upset with my Indy about that but what can I do? It's done, the mistake was made and caused me a lot of stress, but it's over now. The actual owner of the shop finally got involved and figured out that the tranny dipstick tube is out of sight on the back of the engine bay. So, he changed out the oil and filter on his own dime because of the mistake and filled the correct dipstick tube with fresh pentosin that he payed for as well.
So let me ask you guys,... how much did they hurt my motor by running it in the garage with wayyy too much oil in the crankcase and none in the transmission. It was only started and ran a few times to try and shift it out of gear, which of course it wouldn't do, but should I be worried about any long term damage here? This whole thing broke my heart as I'm trying to do everything right on this car .. please leave some comments as to wether or not I should be freaked out or not over this error of gross negligence.
amazing....
amazing....
Now please, if someone (with appropriate candor and class) can offer some wisdom as to my last question about how worried I should be about the effects of this mistake, please do so.
+1 on short oil change interval (500 miles?)
May be a good time to justify a crank case/oil flush
Heard Good things about liquid moly products...
Hell, a can of Seafoam could dumped in right before your next oil change would give me peace of mind.
Happy you got to the bottom of it!
Any how change your oil NOW. not 100-500 miles....now !! It's cheap and piece of mind.
