I should have replaced the SC pulley bearing at the 150K service
Old Sep 8, 2018 | 01:15 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
<Sigh>
Supercharger clutch pulley bearing failed 700 miles after I performed the 150K service.
https://mbworld.org/forums/w211-amg/...ummary-2k.html
My bad. I have the bearing on the shelf and should have replaced it while I had the engine compartment opened up. Now I get to tear it apart again.
Nachi 45BG07S5A1G-2DL
Already found a good DIY. Love this forum!
https://mbworld.org/forums/w211-amg/...g-install.html
Old Sep 9, 2018 | 01:07 AM
gjunon's Avatar
04 E55 AMG
Ouch man... I feel ya. Just remember to torque that SC pulley bolt down hard with some blue loctite.
Old Sep 9, 2018 | 08:57 PM
tw2's Avatar
tw2
Not good. I bought an 83mm pulley so I didn't have to do this for a while. Glad you got it fixed. It's nice having the parts lying around too.
Old Sep 9, 2018 | 09:25 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Supercharger clutch options; suggestions please!
Replaced the bearing but the clutch material on the supercharger looked really bad and worn out. Picture a manual transmission clutch at 200K miles...not many options out there. Looking for ideas. Car is functional for now but the supercharger clutch is going to be metal-on-metal soon (and it is already showing signs of that). I'm looking for suggestions here, team mates. It's not the pulley, it's the portion with the clutch material on the plate that is attached to the impellers. At this time, I know of no way to replace that portion of the supercharger. Pull the stock supercharger off and install a Weistec for $8000? Brainstorming appreciated, please. This is a potential business opportunity for an entrepeneur.
Old Sep 9, 2018 | 09:39 PM
tw2's Avatar
tw2
I know you will hate the idea but fixed pulley is a last resort. Otherwise there must be a way to attach friction material, some sort of thin machined plate and custom shims for the pulley. You can get new clutches but its not cheap, they actually come with new pulleys.
Old Sep 9, 2018 | 09:43 PM
hayseed's Avatar
04 e55
I am sure you can find a used oem in better condition than yours,, I still think FSP is the way to go for short money without worrying about weedwacker damage, I have not installed my 83mm yet but think that should yield a couple of additional HP/TRQ without generating to much heat.
Old Sep 11, 2018 | 07:55 AM
MACEDON's Avatar
05 E55, 98 CLK320
Mine looks like that too. An OEM supercharger replacement might work... no clue how that donut is replaced, I've seen the VRP posts where they remove it for a FSP, but I also read that you need a special tool to pull it off correctly
Old Sep 11, 2018 | 01:50 PM
JoeJErnst's Avatar
2019 Jeep Trackhawk, 2002 CLK55, 2014 911 Carrera
That friction material is easy to pick out of the coupler. If we could find someone who can chuck up some friction stock in a lathe and turn two rings it could possibly be a DIY job to re-friction those couplers.
Old Sep 11, 2018 | 02:17 PM
KAMG's Avatar
2005 C55 AMG (sold), 2005 E55 AMG
I'm not sure if anybody has replaced the just the clutch material. Used stock pulleys come up for sale from time to time; I think that'd be the cheapest route. If you're getting a complete new pulley, might as well go for a smaller one. Or go all out with Weistec
Old Sep 11, 2018 | 02:38 PM
JoeJErnst's Avatar
The friction material is not on the pulley, it's only on the coupler, which typically stays on the SC when changing pulleys.
Old Sep 11, 2018 | 02:52 PM
KAMG's Avatar
Yeah I just re-read the post now lol. Either a used stock blower or Weistec I guess. Not sure how I feel about a fixed pulley
Old Sep 11, 2018 | 04:01 PM
new55's Avatar
04 55
well weistec is a fixed pulley setup and my understanding they offer tunes if you put a fixed pulley on the mb OEM setup as does Race IQ and possibly EC (not sure about them),,, you could always go twin turbo - guessing that would be about half the cost of the Weistec
Old Sep 11, 2018 | 04:59 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
This is an excellent idea! Unfortunately for me, I have no idea at this moment where I would find a cylinder of friction material that is a bit over 5 inches in diameter. A lathe I can find or buy.
Anyone have the coupler off of a scrapped supercharger? I'd be willing to try to come up with some measurements on what is needed and see if it is feasible.
Old Sep 11, 2018 | 05:01 PM
KAMG's Avatar
Yes Weistec is a fixed pulley set up, I'm just not sure about switching to a fixed pulley on the stock blower (even though many have done it). From what I've been hearing/reading, EC does not tune fixed pulley set ups
Old Sep 11, 2018 | 05:03 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
A Weistec would be fun but then I'd want a limited slip differential and JoeJErnst's subframe modification. And, I'm sure shortly after that I'd be wanting another transmission because I'd put some wear on mine!
Old Sep 12, 2018 | 06:26 AM
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
It might be more likely that you could find it in sheets/plates.
