comparing 3 heat exchangers - which is recommended in 2019
Old Nov 25, 2019 | 08:42 PM
dblock110's Avatar
C32 AMG
I'm looking for a plug and play setup and no crazy drilling/damaging . I plan to buy one of these on black Friday :-) - 2 more added
Eurocharged $321 Shipped
https://www.eurocharged.com/ecutunin...heat-exchanger
PLM $345 Shipped
https://www.privatelabelmfg.com/heat...-exchanger.htm
PLM XL $395 Shipped
https://www.privatelabelmfg.com/heat...changer-xl.htm
VRP Speed $300
https://www.vrpspeed.com/product/vrp-v2-heat-exchanger/
Weistec $426 Shipped
https://www.weistec.com/dual-pass-heat-exchanger.html
Old Nov 25, 2019 | 09:12 PM
Das_it16's Avatar
2004 E55 AMG
The PLM heat exchanger is the only one that's a true bolt on with hangers for the oil cooler. The rest will have the oil cooler hanging.
Look into the XL version that 2.96 inches thick vs the smaller 2.36 inch.
Old Nov 26, 2019 | 01:21 AM
Fountain35's Avatar
I purchased the PLM XL and it is well built, and bolted right up. I did grind about a 1/8 of an inch off one of the corners where it bolted to the bumper. Didn't have to but I am a perfectionist.
This might be slightly better, but I didn't want anything in front of my radiator.
http://www.projectb5.com/product/dtk...heat-exchanger
I also replaced my HE pump with the Bosch 010 which I would suggest unless you know yours has been replaced in the last 15,000 miles or so. They are cheap at $ 106.00 from FCP Euro.
Old Nov 26, 2019 | 06:08 AM
new55's Avatar
04 55
PLM $345 Shipped
i have a eurocharged he for sale if interested ,,, new in box. opened for pics only
$180 shipped to lower US
Old Nov 26, 2019 | 09:47 AM
gheorghe's Avatar
E55 AMG
Is VRP a no go in this comparison?
Old Nov 26, 2019 | 12:47 PM
dblock110's Avatar
C32 AMG
true. first post edited
Old Nov 26, 2019 | 07:24 PM
tw2's Avatar
tw2
PLM here, pretty easy install. No cutting except the black plastic air guides don't fit properly afterwards.
Old Nov 26, 2019 | 07:48 PM
VictoryRoadPerformance's Avatar
SPONSOR
E55 C63
Hello Hello!
PLM Standard is a Direct Replacement HE and provides minimal cooling improvement. We consider this a stock replacement
PLM XL is a large Heat exchanger that will increase capacity and improve cooling. It is well constructed, rigid, and mounts easily. includes oil cooler mount
FTP HE is a boat anchor. It is Extremely heavy, Painted, And inneficient, no cooler mount -its a Frozenboost.com core
"PB5" Aka "DTK Reseller" Is a used radiator off of a bmw, The welds are absolutely atrocious and the inlet outlet placing is flawed.
Eurocharged unit is about the same as the PLM Standard without the direct fit or oil cooler mounting.
Weistec i have no comment on as i have no experience with it. no cooler mount
VRP Unit is a Dual Pass Tube and Fin design. It is the Largest Lower mounting heat exchanger on the market. The major advantage of our HE is that is the least restrictive unit you can buy. Lower restriction means faster flowing coolant which means lower temps. We have sold over 300 of this unit There is no cooler mount on this unit.
The VRP secondary HE is the single best HE you can buy. If you had to choose one of the above HEs and thats it choose NONE. Add a secondary HE ontop of your primary HE and you have the largest surface area largest capacity HE system per $.
Ofcourse the best option is a VRP secondary + A Primary of your choice.
Fin constuction is very important aswell. Generally the More Durable the fins the less efficient, The thinner fins cool more efficiently.
For a HE you want a Tube and Fin design VS a bar and plate. You want as little restriction for the fluid as possible.
Here is a chart we made by changing heat exchangers at the track. More than anything this chart shows the effect of reduced restriction in the circuit by swapping out a cooler or upgrading a pump. This is an old chart before we started making bay tanks and upgraded intercoolers. but it still holds true
Old Nov 28, 2019 | 01:32 AM
Das_it16's Avatar
2004 E55 AMG
Top is a PLM XL heat exchanger
lower is a Weistec heat exchanger
The PLM bolts your oil cooler to it. The Weistec leaves it hanging and will eventually get damaged.
Old Nov 28, 2019 | 02:24 PM
KAMG's Avatar
2005 C55 AMG (sold), 2005 E55 AMG
OP does your car have the oil cooler? I think some time during 2004 they added them
Old Apr 9, 2021 | 07:26 PM
Tylerhayles's Avatar
Sl55 amg 2002
@Das_it16
the plm
looks absolutely massive compared to weistec? Or isit just photo angle? Im
torn between the 2 what would
you recommend
thanks
Old Apr 10, 2021 | 06:27 AM
UncleBenz55's Avatar
W211 E220, W211 E55, W203 C55
FYI the 2.25l water capacity stated on the PLM XL is not correct. In reality it's about 1.3L. I got one last year and was disappointed when I measured it. I messaged PLM about it and they said it should have 2.25l in theory. Well practically not.
Old Apr 10, 2021 | 07:22 AM
87geeinn's Avatar
2006 E55 AMG
Originally Posted by VictoryRoadPerformance
Lower restriction means faster flowing coolant which means lower temps. You want as little restriction for the fluid as possible.
This is a common misconception. Not trying to start a flame war, this just needs to be clarified. Yes, sometimes faster flowing = better cooling but sometimes you can even have overcooling. Not necessarily an issue in our vehicles but just ask anyone who has ever had a thermostat stuck open. There is an optimal flow rate for any cooling system. The coolant needs a certain amount of time in the given heat exchanger/radiator to expel heat. If you're just blasting coolant through and it has very little time in the heat exchanger, then you're going to have heat soak. This is a grossly oversimplified explanation but basically the point is: more flow ≠ better cooling in every instance.
Inb4 anyone tries to take this out of context. Yes, in our particular M113k setup, we generally strive for a little more flow and increased surface area for improved cooling.
Old Apr 10, 2021 | 01:32 PM
Fountain35's Avatar
The question is whether or not the temperature is lowered over the stock set up versus the PLM XL heat exchanger. Did you ever check to see?
Now you have me wondering...
Old Apr 10, 2021 | 02:52 PM
It will be better, since the OEM one has 0.6l capacity and less material, so worse heat exchange. By how much compared to the stock one I don't know, since I never mounted my plm one, but sold it
Old Apr 10, 2021 | 03:05 PM
black06c230's Avatar
mgLipGD
Forget larger HE just get a Killer Chiller. Then a trunk tank to keep larger capacity ready for use.
